Project: 5015 (Run 6, Clone 211, Gen 173)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
or: third time's a charm (special exit w/ out of date unit; EUE, but the third time to 100%)
[11:04:14] Project: 5015 (Run 6, Clone 211, Gen 173)
[11:04:14]
[11:04:14] Assembly optimizations on if available.
[11:04:14] Entering M.D.
[11:04:21] Working on 576 p5005_supervillin_e1
[11:04:21] Client config found, loading data.
[11:04:21] Starting GUI Server
[11:05:52] Completed 1%
     {snip}
[12:35:27] Completed 59%
[12:36:04] Unit 2's deadline (October 5 09:19) has passed.
[12:36:16] - Autosending finished units... [October 5 12:36:16 UTC]
[12:36:16] Trying to send all finished work units
[12:36:16] Project: 5230 (Run 9, Clone 51, Gen 18)
[12:36:16] - Read packet limit of 540015616... Set to 524286976.
[12:36:16] + Attempting to send results [October 5 12:36:16 UTC]
[12:36:16] - Reading file work/wuresults_06.dat from core
[12:36:16]   (Read 1157861 bytes from disk)
[12:36:16] Connecting to http://171.64.122.74:8080/
[12:36:16] CoreStatus = 65 (101)
[12:36:16] Core internal error: SPECIAL_EXIT
[12:36:21]
[12:36:21] + Processing work unit
[12:36:21] Core required: FahCore_11.exe
[12:36:21] Core found.
[12:36:21] Working on queue slot 00 [October 5 12:36:21 UTC]
[12:36:21] + Working ...
[12:36:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -checkpoint 15 -verbose -lifeline 2756 -version 620'
[12:36:22]
[12:36:22] *------------------------------*
[12:36:22] Folding@Home GPU Core - Beta
[12:36:22] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[12:36:22]
[12:36:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:36:22] Build host: amoeba
[12:36:22] Board Type: Nvidia
[12:36:22] Core      :
[12:36:22] Preparing to commence simulation
[12:36:22] - Looking at optimizations...
[12:36:22] - Previous termination of core was improper.
[12:36:22] - Files status OK
[12:36:22] - Expanded 44162 -> 244433 (decompressed 553.4 percent)
[12:36:22] Called DecompressByteArray: compressed_data_size=44162 data_size=244433, decompressed_data_size=244433 diff=0
[12:36:22] - Digital signature verified
[12:36:22]
[12:36:22] Project: 5015 (Run 6, Clone 211, Gen 173)
[12:36:22]
[12:36:22] Entering M.D.
[12:36:28] Will resume from checkpoint file
[12:36:28] Working on 576 p5005_supervillin_e1
[12:36:29] Client config found, loading data.
[12:36:29] Resuming from checkpoint
[12:36:29] Gromacs cannot continue further.
[12:36:29] Going to send back what have done.
[12:36:29] Starting GUI Server
[12:36:30] logfile size: 79809 info=79809 bed=0 hdr=23
[12:36:30] - Writing 80345 bytes of core data to disk...
[12:36:30] Done: 79833 -> 9425 (compressed to 11.8 percent)
[12:36:30]   ... Done.
[12:36:30]
[12:36:30] Folding@home Core Shutdown: EARLY_UNIT_END
[12:36:32] CoreStatus = 72 (114)
[12:36:32] Sending work to server
[12:36:32] - Already sending work
[12:36:32] Trying to send all finished work units
[12:36:32] + Sent 0 of 2 completed units to the server
[12:36:32] - Preparing to get new work unit...
[12:36:32] + Attempting to get work packet
[12:36:32] - Will indicate memory of 3326 MB
[12:36:32] - Connecting to assignment server
[12:36:32] Connecting to http://assign-GPU.stanford.edu:8080/
[12:36:32] Posted data.
[12:36:32] Initial: 40AB; - Successful: assigned to (171.64.65.20).
[12:36:32] + News From Folding@Home: GPU folding beta
[12:36:32] Loaded queue successfully.
[12:36:32] Connecting to http://171.64.65.20:8080/
[12:36:32] Initial: 0000; - Receiving payload (expected size: 44674)
[12:36:32] Conversation time very short, giving reduced weight in bandwidth avg
[12:36:32] - Downloaded at ~87 kB/s
[12:36:32] - Averaged speed for that direction ~81 kB/s
[12:36:32] + Received work.
[12:36:32] + Closed connections
[12:36:38]
[12:36:38] + Processing work unit
[12:36:38] Core required: FahCore_11.exe
[12:36:38] Core found.
[12:36:38] Working on queue slot 01 [October 5 12:36:38 UTC]
[12:36:38] + Working ...
[12:36:38] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 2756 -version 620'
[12:36:38]
[12:36:38] *------------------------------*
[12:36:38] Folding@Home GPU Core - Beta
[12:36:38] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[12:36:38]
[12:36:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:36:38] Build host: amoeba
[12:36:38] Board Type: Nvidia
[12:36:38] Core      :
[12:36:38] Preparing to commence simulation
[12:36:38] - Looking at optimizations...
[12:36:38] - Created dyn
[12:36:38] - Files status OK
[12:36:38] - Expanded 44162 -> 244433 (decompressed 553.4 percent)
[12:36:38] Called DecompressByteArray: compressed_data_size=44162 data_size=244433, decompressed_data_size=244433 diff=0
[12:36:38] - Digital signature verified
[12:36:38]
[12:36:38] Project: 5015 (Run 6, Clone 211, Gen 173)
[12:36:38]
[12:36:38] Assembly optimizations on if available.
[12:36:38] Entering M.D.
[12:36:44] Working on 576 p5005_supervillin_e1
[12:36:45] Client config found, loading data.
[12:36:45] Starting GUI Server
[12:38:19] - Couldn't send HTTP request to server
[12:38:19] + Could not connect to Work Server (results)
[12:38:19]     (171.64.122.74:8080)
[12:38:19] + Retrying using alternative port
[12:38:19] Connecting to http://171.64.122.74:80/
[12:39:09] Completed 1%
[12:40:28] - Couldn't send HTTP request to server
[12:40:28] + Could not connect to Work Server (results)
[12:40:28]     (171.64.122.74:80)
[12:40:28] - Error: Could not transmit unit 06 (completed October 2) to work server.
[12:40:28] - 51 failed uploads of this unit.
[12:40:28] - Read packet limit of 540015616... Set to 524286976.
[12:40:28] + Attempting to send results [October 5 12:40:28 UTC]
[12:40:28] - Reading file work/wuresults_06.dat from core
[12:40:28]   (Read 1157861 bytes from disk)
[12:40:28] Connecting to http://171.64.122.86:8080/
[12:40:28]   (Got status 503)
[12:40:28]     (171.64.122.86:8080)
[12:40:28] + Retrying using alternative port
[12:40:28] Connecting to http://171.64.122.86:80/
[12:40:28]     (171.64.122.86:80)
[12:40:28]   Could not transmit unit 06 to Collection server; keeping in queue.
[12:40:28] + Sent 0 of 1 completed units to the server
[12:40:28] - Autosend completed
[12:41:34] Completed 2%
      {snip}
[15:45:37] Completed 100%
[15:46:37]
[15:46:37] Finished Work Unit:
[15:46:37] - Reading up to 34800 from "work/wudata_01.trr": Read 34800
[15:46:37] trr file hash check passed.
[15:46:37] - Reading up to 1126964 from "work/wudata_01.xtc": Read 1126964
[15:46:37] xtc file hash check passed.
[15:46:37] edr file hash check passed.
[15:46:37] logfile size: 130435
[15:46:37] Leaving Run
[15:46:38] - Writing 1293271 bytes of core data to disk...
[15:46:38] Done: 1292759 -> 1154483 (compressed to 89.3 percent)
[15:46:38]   ... Done.
[15:46:38] - Shutting down core
[15:46:38]
[15:46:38] Folding@home Core Shutdown: FINISHED_UNIT
[15:46:42] CoreStatus = 64 (100)
[15:46:42] Unit 1 finished with 96 percent of time to deadline remaining.
[15:46:42] Updated performance fraction: 0.961723
[15:46:42] Sending work to server
[15:46:42] Project: 5015 (Run 6, Clone 211, Gen 173)
[15:46:42] - Read packet limit of 540015616... Set to 524286976.
[15:46:42] + Attempting to send results [October 5 15:46:42 UTC]
[15:46:42] - Reading file work/wuresults_01.dat from core
[15:46:42]   (Read 1154995 bytes from disk)
[15:46:42] Connecting to http://171.64.65.20:8080/
[15:47:03] Posted data.
[15:47:03] Initial: 0000; - Uploaded at ~51 kB/s
[15:47:04] - Averaged speed for that direction ~51 kB/s
[15:47:04] + Results successfully sent
[15:47:04] Thank you for your contribution to Folding@Home.
[15:47:04] + Number of Units Completed: 496
I noticed that the EUE said it would send back what was done. Did I get only whatever partial credit that was worth, or did I get the whole credit for the later completed unit?
Re: Project: 5015 (Run 6, Clone 211, Gen 173)
Hi anko1 (team 47815),
Your WU (P5015 R6 C211 G173) was added to the stats database on 2008-10-05 10:57:40 for 480 points of credit.
40 seconds later (in the logs) :
Your WU (P5015 R6 C211 G173) was added to the stats database on 2008-10-05 10:57:40 for 0 points of credit.
anko1
Post by anko1 »
Thanks, toTOW. Looks like I got lucky and the full unit beat the partial one back. :-)
