Project 2665 : (Run 2, Clone 256 Gen 39)
bossa_nova
Post by bossa_nova »
I have recieved this WU 7 times in a row and it always stops at 78%. How can I get the server to stop sending the same WU?
[06:18:05] Completed 195000 out of 250000 steps  (78 percent)
[06:23:18] Warning:  long 1-4 interactions
[06:31:27] - Autosending finished units... [October 5 06:31:27 UTC]
[06:31:27] Trying to send all finished work units
[06:31:27] + No unsent completed units remaining.
[06:31:27] - Autosend completed
[09:18:05] At least 3 hours since checkpoint written...
[09:20:05]
[09:20:05] Folding@home Core Shutdown: EARLY_UNIT_END
[09:20:05]
[09:20:09] CoreStatus = 7B (123)
[09:20:09] Client-core communications error: ERROR 0x7b
[09:20:09] Deleting current work unit & continuing...
[09:20:09] Using generic mpiexec calls
[09:22:12] - Warning: Could not delete all work unit files (4): Core returned invalid code
[09:22:12] Trying to send all finished work units
[09:22:12] + No unsent completed units remaining.
[09:22:12] - Preparing to get new work unit...
[09:22:12] + Attempting to get work packet
[09:22:12] - Will indicate memory of 3324 MB
[09:22:12] - Connecting to assignment server
[09:22:12] Connecting to http://assign.stanford.edu:8080/
[09:22:13] Posted data.
[09:22:13] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[09:22:13] + News From Folding@Home: Welcome to Folding@Home
[09:22:13] Loaded queue successfully.
[09:22:13] Connecting to http://171.64.65.64:8080/
[09:22:18] Posted data.
[09:22:18] Initial: 0000; - Receiving payload (expected size: 4812189)
[09:22:34] - Downloaded at ~293 kB/s
[09:22:34] - Averaged speed for that direction ~287 kB/s
[09:22:34] + Received work.
[09:22:34] + Closed connections
[09:22:39]
[09:22:39] + Processing work unit
[09:22:39] Work type a1 not eligible for variable processors
[09:22:39] Core required: FahCore_a1.exe
[09:22:39] Core found.
[09:22:39] Using generic mpiexec calls
[09:22:39] Working on queue slot 05 [October 5 09:22:39 UTC]
[09:22:39] + Working ...
[09:22:39] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 7172 -version 622'
[09:22:39]
[09:22:39] *------------------------------*
[09:22:39] Folding@Home Gromacs SMP Core
[09:22:39] Version 1.74 (March 10, 2007)
[09:22:39]
[09:22:39] Preparing to commence simulation
[09:22:39] - Ensuring status. Please wait.
[09:22:46] - Starting from initial work packet
[09:22:46]
[09:22:46] Project: 2665 (Run 2, Clone 256, Gen 39)
[09:22:46]
[09:22:46] Assembly optimizations on if available.
[09:22:46] Entering M.D.
[09:23:09]  percent)
[09:23:10] - Starting from initial work packet
[09:23:10]
[09:23:10] Project: 2665 (Run 2, Clone 256, Gen 39)
[09:23:10]
[09:23:11] Entering M.D.
[09:23:17] Rejecting checkpoint
[09:23:19] Protein: HGG with glycosylations
[09:23:19] Writing local files
[09:23:29] Extra SSE boost OK.
[09:23:29] Writing local files
[09:23:29] Completed 0 out of 250000 steps  (0 percent)
anko1
(3.2GHz) HT;Windows XP
Re: Project 2665 : (Run 2, Clone 256 Gen 39)
Post by anko1 »
If you use qfix as soon as you see an EUE, in theory you won't get the same WU back, plus you get some points for your work.
There's no data for this WU in the DB.
You can submit your partial results using qfix : viewtopic.php?f=8&t=191
bossa_nova
Qfix worked and I was finally able to a different WU after 6 EUE's of the same one. Thank you both for you help.
