shadeyB
Posts: 4 Joined: Thu Oct 02, 2008 11:34 am
Post
by shadeyB » Thu Oct 02, 2008 3:01 pm
please excuse my ignorance if this is not what is required ?
i'm not sure how to use the "Code " Tags
please advise
thanks
Barry
--- Opening Log file [October 2 13:13:38 UTC]
# Windows CPU Systray Edition #################################################
Folding@Home Client Version 6.20
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Hotel Cladhan\Application Data\Folding@home-x86
[13:13:38] - Ask before connecting: No
[13:13:38] - User name: shadeyB2 (Team 146167)
[13:13:38] - User ID: 35E9FA8072644CD8
[13:13:38] - Machine ID: 1
[13:13:38]
[13:13:38] Loaded queue successfully.
[13:13:38] Initialization complete
[13:13:38]
[13:13:38] + Processing work unit
[13:13:38] Core required: FahCore_78.exe
[13:13:38] Core found.
[13:13:38] Working on queue slot 01 [October 2 13:13:38 UTC]
[13:13:38] + Working ...
[13:13:38]
[13:13:38] *------------------------------*
[13:13:38] Folding@Home Gromacs Core
[13:13:38] Version 1.90 (March 8, 2006)
[13:13:38]
[13:13:38] Preparing to commence simulation
[13:13:38] - Looking at optimizations...
[13:13:38] - Files status OK
[13:13:42] - Expanded 654038 -> 14061929 (decompressed 2150.0 percent)
[13:13:42]
[13:13:42] Project: 2620 (Run 81, Clone 4, Gen 0)
[13:13:42]
[13:14:04] Assembly optimizations on if available.
[13:14:04] Entering M.D.
[13:14:11] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[13:14:11]
[13:14:11] Writing local files
[14:33:46] Gromacs error.
[14:33:46]
[14:33:46] Folding@home Core Shutdown: UNKNOWN_ERROR
[14:33:50] CoreStatus = 79 (121)
[14:33:50] Client-core communications error: ERROR 0x79
[14:33:50] This is a sign of more serious problems, shutting down.
--- Opening Log file [October 2 14:40:10 UTC]
7im on Sat Oct 04, 2008 6:08 am, edited 2 times in total.
Reason: Added code tags.
Posts: 6498 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Thu Oct 02, 2008 6:24 pm
It seems to be a bad WU ... you can delete your /work folder, and queue.dat file. Don't worry if the WU is reassigned to you up to five times, the server should move to another WU after.
anko1
Posts: 438 Joined: Mon Dec 03, 2007 1:31 am
Hardware configuration: Old Faithful CPU: Windows Graphical 5.03; Intel Pentium 4 Processor 540 (3.2GHz) HT;Windows XP Big Red: Windows SMP Console 6.29; Windows GPU console 6.20r1; Intel Q9450 2.66G; ASUS P5Q 775 P45; [BFG 9800GTX+ old graphics card] NVidia GeForce 8800 GTX [as of 5/9/09]; Windows XP Pro SP3 Lenovo Think Pad: Windows 6.29 w/ SMP; Windows GPU Console 6.20r1 systray; Intel QX9300; NVIDIA Quadro FX-3700M; Windows XP Professional
Post
by anko1 » Fri Oct 03, 2008 4:41 am
To use the code tags put code at the start and /code at the end using brackets:
shadeyB
Post
by shadeyB » Fri Oct 03, 2008 9:43 am
i'm not sure how to delete the work unit ??
i opend current folder and deleted that ? hope thats right ??
this project has been assigned 8 times so far
when and how does the server moive on to next unit
anko1
Post
by anko1 » Fri Oct 03, 2008 4:51 pm
If you don't have any unsent units, right click on the work folder, then delete. Do the same for the queue.dat file. Good luck!
Post
by toTOW » Fri Oct 03, 2008 10:53 pm
Thanks, you're not alone with this problem : viewtopic.php?f=19&t=6010
As I don't know what could cause the error, I've alerted the people in charge of this project.
shadeyB
Post
by shadeyB » Tue Oct 07, 2008 10:31 am
anko1 wrote: If you don't have any unsent units, right click on the work folder, then delete. Do the same for the queue.dat file. Good luck!
thankz guyz n galz
this seems to have sorted the problem "DUMP THE LOT"
hopefully it'll keep on folding
