(lost) Project: 3858 (Run 1760, Clone 0, Gen 12)
rooty2k1
Post by rooty2k1 »
Hi,
this is a part of my log-file:
>[23:50:12] Folding@home Core Shutdown: FINISHED_UNIT
>[23:50:16] CoreStatus = 64 (100)
>[23:50:16] Sending work to server
>[23:50:16] Project: 3858 (Run 1760, Clone 0, Gen 12)
>[00:03:14] + Attempting to send results [September 26 00:03:14 UTC]
>[00:06:26] + Results successfully sent
>[00:06:26] Thank you for your contribution to Folding@Home.
that means: finished on 25.Sept, sent on 26.Sept and deadline date is 28.Oct.
But, my user-stats only show: Date of last work unit 2008-09-20 12:11:33
Is this a known problem? Does this happen sometimes? (wouldn't be nice)
I usually wouldn't have realised this if I hadn't installed a new client because of permanent connecting problems with my very very old one and joined a team ;)
Perhaps You can do something or tell me, what was going wrong.
Daniel
PS: This is the first time, this happened with the new client. Username and team-ID are correct.
Re: (lost) Project: 3858 (Run 1760, Clone 0, Gen 12)
This project is known to have credit issue (the work server has trouble communicating with stats DB server) ... your WU will appear when the next manual recredit occurs.
rooty2k1
Post by rooty2k1 »
Okay, Thank You for your answer toTOW!
Daniel
