Project: 2665 (Run 0, Clone 338, Gen 48) ERROR 0x7b
joce
Post by joce »
XP64, 6.22 SMP Beta 2
[00:31:00] *------------------------------*
[00:31:00] Folding@Home Gromacs SMP Core
[00:31:00] Version 1.74 (March 10, 2007)
[00:31:00]
[00:31:00] Preparing to commence simulation
[00:31:00] - Ensuring status. Please wait.
[00:31:17] - Assembly optimizations manually forced on.
[00:31:17] - Not checking prior termination.
[00:31:32] - Expanded 4773013 -> 24426905 (decompressed 511.7 percent)
[00:31:32] - Starting from initial work packet
[00:31:32]
[00:31:32] Project: 2665 (Run 0, Clone 338, Gen 48)
[00:31:32]
[00:31:33] Assembly optimizations on if available.
[00:31:33] Entering M.D.
[00:31:39] Rejecting checkpoint
[00:31:41] Protein: HGG in water
[00:31:41] Writing local files
[00:31:48] Extra SSE boost OK.
[00:31:49] Writing local files
[00:31:49] Completed 0 out of 250000 steps  (0 percent)
[00:46:22] Writing local files
[00:46:22] Completed 2500 out of 250000 steps  (1 percent)
[00:55:16]  to delete work/wudata_02.arc
[00:55:16] No C.P. to delete.
[00:55:16] Warning:  check for stray files
[00:55:16] 2.sas
[00:55:16] - Failed to delete work/wudata_02.pdo
[00:55:16] 2.xvg
[00:55:16] e work/wudata_02.pdo
[00:55:16] - Failed to delete work/wudata_02.xvg
[00:55:16]
[00:55:16] Folding@home Core Shutdown: EARLY_UNIT_END
[00:55:16]
[00:55:20] CoreStatus = 7B (123)
[00:55:20] Client-core communications error: ERROR 0x7b
[00:55:20] This is a sign of more serious problems, shutting down.
[05:40:07] - Autosending finished units... [September 29 05:40:07 UTC]
[05:40:07] Trying to send all finished work units
[05:40:07] + No unsent completed units remaining.
[05:40:07] - Autosend completed
Macpro 2,66 GHz Quad, 6 Go DDR3, ATI Radeon HD 4870 512 Mo
Re: Project: 2665 (Run 0, Clone 338, Gen 48) ERROR 0x7b
This one is probably a BadWU, no one made it to 100% :(
nwkelley
Pande Group Member
Post by nwkelley »
thanks for the heads up, i'll remove it from the queue!
