Project: 2665 (Run 3, Clone 656, Gen 46) 9% 0x7b qfix submit
mikeb12
Post by mikeb12 »
Vista 64 6.22r3
0x7b at 9%, qfix result submitted
[18:59:58] Folding@home Core Shutdown: FINISHED_UNIT
[19:00:02] CoreStatus = 64 (100)
[19:00:02] Sending work to server
[19:00:02] Project: 2665 (Run 0, Clone 3, Gen 52)
[19:00:02] + Attempting to send results [September 25 19:00:02 UTC]
[19:05:46] + Results successfully sent
[19:05:46] Thank you for your contribution to Folding@Home.
[19:05:46] + Number of Units Completed: 26
[19:05:50] Using generic mpiexec calls
[19:07:54] - Preparing to get new work unit...
[19:07:54] + Attempting to get work packet
[19:07:54] - Connecting to assignment server
[19:07:55] - Successful: assigned to (171.64.65.64).
[19:07:55] + News From Folding@Home: Welcome to Folding@Home
[19:07:55] Loaded queue successfully.
[19:08:28] + Closed connections
[19:08:28]
[19:08:28] + Processing work unit
[19:08:28] Work type a1 not eligible for variable processors
[19:08:28] Core required: FahCore_a1.exe
[19:08:28] Core found.
[19:08:28] Using generic mpiexec calls
[19:08:28] Working on queue slot 02 [September 25 19:08:28 UTC]
[19:08:28] + Working ...
[19:08:29]
[19:08:29] *------------------------------*
[19:08:29] Folding@Home Gromacs SMP Core
[19:08:29] Version 1.74 (March 10, 2007)
[19:08:29]
[19:08:29] Preparing to commence simulation
[19:08:29] - Ensuring status. Please wait.
[19:08:34] - Starting from initial work packet
[19:08:34]
[19:08:34] Project: 2665 (Run 3, Clone 656, Gen 46)
[19:08:34]
[19:08:34] Assembly optimizations on if available.
[19:08:34] Entering M.D.
[19:08:55]  percent)
[19:08:55] - Starting from initial work packet
[19:08:55]
[19:08:55] Project: 2665 (Run 3, Clone 656, Gen 46)
[19:08:55]
[19:08:57] Entering M.D.
[19:09:03] Rejecting checkpoint
[19:09:04] Protein: HGG in water
[19:09:04] Writing local files
[19:09:12] Extra SSE boost OK.
[19:09:12] Writing local files
[19:09:12] Completed 0 out of 250000 steps  (0 percent)
[19:26:24] Writing local files
[19:26:24] Completed 2500 out of 250000 steps  (1 percent)
[19:43:04] Writing local files
[19:43:04] Completed 5000 out of 250000 steps  (2 percent)
[20:00:00] Writing local files
[20:00:00] Completed 7500 out of 250000 steps  (3 percent)
[20:16:55] Writing local files
[20:16:56] Completed 10000 out of 250000 steps  (4 percent)
[20:33:55] Writing local files
[20:33:55] Completed 12500 out of 250000 steps  (5 percent)
[20:50:42] Writing local files
[20:50:42] Completed 15000 out of 250000 steps  (6 percent)
[21:07:35] Writing local files
[21:07:35] Completed 17500 out of 250000 steps  (7 percent)
[21:24:26] Writing local files
[21:24:27] Completed 20000 out of 250000 steps  (8 percent)
[21:41:40] Writing local files
[21:41:40] Completed 22500 out of 250000 steps  (9 percent)
[21:53:13] Warning:  long 1-4 interactions
[21:53:13] Gromacs cannot continue further.
[21:53:13] Going to send back what have done.
[21:53:13] logfile size: 26304
[21:53:13] - Writing 26840 bytes of core data to disk...
[21:53:13]   ... Done.
[21:53:13] - Failed to delete work/wudata_02.sas
[21:53:13] - Failed to delete work/wudata_02.goe
[21:53:13] Warning:  check for stray files
[21:55:13]
[21:55:13] Folding@home Core Shutdown: EARLY_UNIT_END
[21:55:13]
[21:55:16] CoreStatus = 7B (123)
[21:55:16] Client-core communications error: ERROR 0x7b
[21:55:16] Deleting current work unit & continuing...
[21:55:16] Using generic mpiexec calls
[21:57:20] - Preparing to get new work unit...
[21:57:20] + Attempting to get work packet
[21:57:20] - Connecting to assignment server
[21:57:21] - Successful: assigned to (171.64.65.64).
[21:57:21] + News From Folding@Home: Welcome to Folding@Home
[21:57:21] Loaded queue successfully.
[21:57:52] + Closed connections
[21:57:57]
[21:57:57] + Processing work unit
[21:57:57] Work type a1 not eligible for variable processors
[21:57:57] Core required: FahCore_a1.exe
[21:57:57] Core found.
[21:57:57] Using generic mpiexec calls
[21:57:57] Working on queue slot 03 [September 25 21:57:57 UTC]
[21:57:57] + Working ...
[21:57:57]
[21:57:57] *------------------------------*
[21:57:57] Folding@Home Gromacs SMP Core
[21:57:57] Version 1.74 (March 10, 2007)
[21:57:57]
[21:57:57] Preparing to commence simulation
[21:57:57] - Ensuring status. Please wait.
[21:58:02] - Starting from initial work packet
[21:58:02]
[21:58:02] Project: 2665 (Run 3, Clone 656, Gen 46)
[21:58:02]
[21:58:03] Assembly optimizations on if available.
[21:58:03] Entering M.D.
[21:58:23]  percent)
[21:58:23] - Starting from initial work packet
[21:58:23]
[21:58:23] Project: 2665 (Run 3, Clone 656, Gen 46)
[21:58:23]
[21:58:25] Entering M.D.
[21:58:32] Rejecting checkpoint
[21:58:35] Protein: HGG in water
[21:58:35] Writing local files
[21:58:43] Extra SSE boost OK.
[21:58:43] Writing local files
[21:58:43] Completed 0 out of 250000 steps  (0 percent)
[22:16:31] Writing local files
[22:16:32] Completed 2500 out of 250000 steps  (1 percent)
[22:33:26] Writing local files
[22:33:27] Completed 5000 out of 250000 steps  (2 percent)
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [September 25 22:45:23 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: D:\Software\Folding\smp2
Executable: D:\Software\Folding\smp2\Folding@home-Win32-x86.exe
Arguments: -send all
[22:45:23] - Ask before connecting: No
[22:45:23] - User name: mikeb12 (Team 36362)
[22:45:23] - User ID: 504D8E7326393487
[22:45:23] - Machine ID: 2
[22:45:23]
[22:45:23] Loaded queue successfully.
[22:45:23] Attempting to return result(s) to server...
[22:45:23] Project: 2665 (Run 3, Clone 656, Gen 46)
[22:45:23] + Attempting to send results [September 25 22:45:23 UTC]
[22:45:25] + Results successfully sent
[22:45:25] Thank you for your contribution to Folding@Home.
[22:45:25] + Number of Units Completed: 27
--- Opening Log file [September 25 22:46:08 UTC]
Arguments: -smp -local
[22:46:08] - Ask before connecting: No
[22:46:08] - User name: mikeb12 (Team 36362)
[22:46:08] - User ID: 504D8E7326393487
[22:46:08] - Machine ID: 2
[22:46:08]
[22:46:08] Loaded queue successfully.
[22:46:08] - Preparing to get new work unit...
[22:46:08] + Attempting to get work packet
[22:46:08] - Connecting to assignment server
[22:46:09] - Successful: assigned to (171.64.65.64).
[22:46:09] + News From Folding@Home: Welcome to Folding@Home
[22:46:09] Loaded queue successfully.
[22:46:42] + Closed connections
[22:46:42]
[22:46:42] + Processing work unit
[22:46:42] Work type a1 not eligible for variable processors
[22:46:42] Core required: FahCore_a1.exe
[22:46:42] Core found.
[22:46:42] Using generic mpiexec calls
[22:46:42] Working on queue slot 04 [September 25 22:46:42 UTC]
[22:46:42] + Working ...
[22:46:42]
[22:46:42] *------------------------------*
[22:46:42] Folding@Home Gromacs SMP Core
[22:46:42] Version 1.74 (March 10, 2007)
[22:46:42]
[22:46:42] Preparing to commence simulation
[22:46:42] - Ensuring status. Please wait.
[22:46:59] - Looking at optimizations...
[22:46:59] - Working with standard loops on this execution.
[22:46:59] - Previous termination of core was improper.
[22:46:59] - Going to use standard loops.
[22:46:59] - Files status OK
[22:47:10] - Expanded 4669053 -> 24111057 (decompressed 516.4 percent)
[22:47:10] - Starting from initial work packet
[22:47:10]
[22:47:10] Project: 2665 (Run 1, Clone 60, Gen 53)
[22:47:10]
[22:47:11] Entering M.D.
[22:47:18] Rejecting checkpoint
[22:47:20] Protein: IBX in water
[22:47:20] Writing local files
[22:47:27] Extra SSE boost OK.
[22:47:28] Writing local files
[22:47:28] Completed 0 out of 250000 steps  (0 percent)
Re: Project: 2665 (Run 3, Clone 656, Gen 46) 9% 0x7b qfix submit
No one was able to complete this WU (all reports are EUE) ... this is probably a bad one :(
