Project: 2665 (Run 3, Clone 827, Gen 25) 0% eue 3 times
mikeb12
Post by mikeb12 »
Vista 64 6.22r3
Bad Wu: fail 3 times in a row at 0%
submitted qfix result for the eue...
[12:54:05] Folding@home Core Shutdown: FINISHED_UNIT
[12:54:08] CoreStatus = 64 (100)
[12:54:08] Sending work to server
[12:54:08] Project: 2665 (Run 1, Clone 333, Gen 51)
[12:54:08] + Attempting to send results [September 24 12:54:08 UTC]
[12:59:48] + Results successfully sent
[12:59:48] Thank you for your contribution to Folding@Home.
[12:59:48] + Number of Units Completed: 27
[12:59:49] Using generic mpiexec calls
[13:01:53] - Preparing to get new work unit...
[13:01:53] + Attempting to get work packet
[13:01:53] - Connecting to assignment server
[13:01:53] - Successful: assigned to (171.64.65.64).
[13:01:53] + News From Folding@Home: Welcome to Folding@Home
[13:01:54] Loaded queue successfully.
[13:02:24] + Closed connections
[13:02:24]
[13:02:24] + Processing work unit
[13:02:24] Work type a1 not eligible for variable processors
[13:02:24] Core required: FahCore_a1.exe
[13:02:24] Core found.
[13:02:24] Using generic mpiexec calls
[13:02:24] Working on queue slot 04 [September 24 13:02:24 UTC]
[13:02:24] + Working ...
[13:02:24]
[13:02:24] *------------------------------*
[13:02:24] Folding@Home Gromacs SMP Core
[13:02:24] Version 1.74 (March 10, 2007)
[13:02:24]
[13:02:24] Preparing to commence simulation
[13:02:24] - Ensuring status. Please wait.
[13:02:29] - Starting from initial work packet
[13:02:29]
[13:02:29] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:02:29]
[13:02:30] Assembly optimizations on if available.
[13:02:30] Entering M.D.
[13:02:50] al work packet
[13:02:50]
[13:02:50] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:02:50]
[13:02:50] 65 (Run 3, Clone 827, Gen 25)
[13:02:50]
[13:02:50] Entering M.D.
[13:02:59] Rejecting checkpoint
[13:03:00] Protein: HGG in water
[13:03:00] Writing local files
[13:03:08] Extra SSE boost OK.
[13:03:08] Writing local files
[13:03:08] Completed 0 out of 250000 steps  (0 percent)
[13:12:10] Gromacs cannot continue further.
[13:12:10] Going to send back what have done.
[13:12:10] logfile size: 9421
[13:12:10] - Writing 9957 bytes of core data to disk...
[13:12:10]   ... Done.
[13:12:10]
[13:12:10] Warning:  check for stray files
[13:12:11] .sas
[13:12:11] - Failed to delete work/wudata_04.goe
[13:12:11] Warning:  check for stray files
[13:12:11]
[13:12:11] Folding@home Core Shutdown: EARLY_UNIT_END
[13:12:11]
[13:12:14] CoreStatus = 7B (123)
[13:12:14] Client-core communications error: ERROR 0x7b
[13:12:14] Deleting current work unit & continuing...
[13:12:14] Using generic mpiexec calls
[13:14:18] - Preparing to get new work unit...
[13:14:18] + Attempting to get work packet
[13:14:18] - Connecting to assignment server
[13:14:19] - Successful: assigned to (171.64.65.64).
[13:14:19] + News From Folding@Home: Welcome to Folding@Home
[13:14:19] Loaded queue successfully.
[13:14:50] + Closed connections
[13:14:55]
[13:14:55] + Processing work unit
[13:14:55] Work type a1 not eligible for variable processors
[13:14:55] Core required: FahCore_a1.exe
[13:14:55] Core found.
[13:14:55] Using generic mpiexec calls
[13:14:55] Working on queue slot 05 [September 24 13:14:55 UTC]
[13:14:55] + Working ...
[13:14:55]
[13:14:55] *------------------------------*
[13:14:55] Folding@Home Gromacs SMP Core
[13:14:55] Version 1.74 (March 10, 2007)
[13:14:55]
[13:14:55] Preparing to commence simulation
[13:14:55] - Ensuring status. Please wait.
[13:15:00] - Starting from initial work packet
[13:15:00]
[13:15:00] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:15:00]
[13:15:00] Assembly optimizations on if available.
[13:15:00] Entering M.D.
[13:15:20]  percent)
[13:15:21] - Starting from initial work packet
[13:15:21]
[13:15:21] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:15:21]
[13:15:21] Entering M.D.
[13:15:29] Rejecting checkpoint
[13:15:30]
[13:15:30] Writing local files
[13:15:31]
[13:15:31] Writing local files
[13:15:38] Extra SSE boost OK.
[13:15:38] Writing local files
[13:15:39] Completed 0 out of 250000 steps  (0 percent)
[13:25:10] Gromacs cannot continue further.
[13:25:10] Going to send back what have done.
[13:25:10] logfile size: 9422
[13:25:10] - Writing 9958 bytes of core data to disk...
[13:25:10]   ... Done.
[13:25:10] - Failed to delete work/wudata_05.sas
[13:25:10] - Failed to delete work/wudata_05.goe
[13:25:10] Warning:  check for stray files
[13:27:10]
[13:27:10] Folding@home Core Shutdown: EARLY_UNIT_END
[13:27:10]
[13:27:13] CoreStatus = 7B (123)
[13:27:13] Client-core communications error: ERROR 0x7b
[13:27:13] Deleting current work unit & continuing...
[13:27:13] Using generic mpiexec calls
[13:29:17] - Preparing to get new work unit...
[13:29:17] + Attempting to get work packet
[13:29:17] - Connecting to assignment server
[13:29:17] - Successful: assigned to (171.64.65.64).
[13:29:17] + News From Folding@Home: Welcome to Folding@Home
[13:29:17] Loaded queue successfully.
[13:29:51] + Closed connections
[13:29:56]
[13:29:56] + Processing work unit
[13:29:56] Work type a1 not eligible for variable processors
[13:29:56] Core required: FahCore_a1.exe
[13:29:56] Core found.
[13:29:56] Using generic mpiexec calls
[13:29:56] Working on queue slot 06 [September 24 13:29:56 UTC]
[13:29:56] + Working ...
[13:29:56]
[13:29:56] *------------------------------*
[13:29:56] Folding@Home Gromacs SMP Core
[13:29:56] Version 1.74 (March 10, 2007)
[13:29:56]
[13:29:56] Preparing to commence simulation
[13:29:56] - Ensuring status. Please wait.
[13:30:01] - Starting from initial work packet
[13:30:02]
[13:30:02] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:30:02]
[13:30:02] Assembly optimizations on if available.
[13:30:02] Entering M.D.
[13:30:22]  percent)
[13:30:22] - Starting from initial work packet
[13:30:22]
[13:30:22] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:30:22]
[13:30:23] Entering M.D.
[13:30:29] Rejecting checkpoint
[13:30:31]
[13:30:31] Writing local files
[13:30:31]
[13:30:38] Extra SSE boost OK.
[13:30:39] Writing local files
[13:30:39] Completed 0 out of 250000 steps  (0 percent)
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [September 24 13:38:27 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: D:\Software\Folding\smp1
Executable: D:\Software\Folding\smp1\Folding@home-Win32-x86.exe
Arguments: -delete 06
[13:38:27] - Ask before connecting: No
[13:38:27] - User name: mikeb12 (Team 36362)
[13:38:27] - User ID: 504D8E7326393487
[13:38:27] - Machine ID: 1
[13:38:27]
[13:38:27] Loaded queue successfully.
[13:38:27] Deleting work unit #6 from work queue...
[13:38:47] - Failed to delete the requested work unit
--- Opening Log file [September 24 13:39:48 UTC]
Arguments: -send all
[13:39:48] - Ask before connecting: No
[13:39:48] - User name: mikeb12 (Team 36362)
[13:39:48] - User ID: 504D8E7326393487
[13:39:48] - Machine ID: 1
[13:39:48]
[13:39:48] Loaded queue successfully.
[13:39:48] Attempting to return result(s) to server...
[13:39:48] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:39:48] + Attempting to send results [September 24 13:39:48 UTC]
[13:39:50] + Results successfully sent
[13:39:50] Thank you for your contribution to Folding@Home.
[13:39:50] + Number of Units Completed: 28
[13:39:50] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:39:50] + Attempting to send results [September 24 13:39:50 UTC]
[13:39:51] + Results successfully sent
[13:39:51] Thank you for your contribution to Folding@Home.
[13:39:51] + Number of Units Completed: 29
[13:39:51] Project: 2665 (Run 3, Clone 827, Gen 25)
[13:39:51] + Attempting to send results [September 24 13:39:51 UTC]
[13:39:52] + Results successfully sent
[13:39:52] Thank you for your contribution to Folding@Home.
[13:39:52] + Number of Units Completed: 30
--- Opening Log file [September 24 13:40:05 UTC]
Arguments: -smp -local
[13:40:05] - Ask before connecting: No
[13:40:05] - User name: mikeb12 (Team 36362)
[13:40:05] - User ID: 504D8E7326393487
[13:40:05] - Machine ID: 1
[13:40:05]
[13:40:05] Loaded queue successfully.
[13:40:05] - Preparing to get new work unit...
[13:40:05] + Attempting to get work packet
[13:40:05] - Connecting to assignment server
[13:40:06] - Successful: assigned to (171.64.65.64).
[13:40:06] + News From Folding@Home: Welcome to Folding@Home
[13:40:06] Loaded queue successfully.
[13:40:37] + Closed connections
[13:40:37]
[13:40:37] + Processing work unit
[13:40:37] Work type a1 not eligible for variable processors
[13:40:37] Core required: FahCore_a1.exe
[13:40:37] Core found.
[13:40:37] Using generic mpiexec calls
[13:40:37] Working on queue slot 07 [September 24 13:40:37 UTC]
[13:40:37] + Working ...
[13:40:37]
[13:40:37] *------------------------------*
[13:40:37] Folding@Home Gromacs SMP Core
[13:40:37] Version 1.74 (March 10, 2007)
[13:40:37]
[13:40:37] Preparing to commence simulation
[13:40:37] - Ensuring status. Please wait.
[13:40:54] - Looking at optimizations...
[13:40:54] - Working with standard loops on this execution.
[13:40:54] - Previous termination of core was improper.
[13:40:54] - Going to use standard loops.
[13:40:54] - Files status OK
[13:41:08] - Expanded 4761602 -> 24426905 (decompressed 512.9 percent)
[13:41:09] cket
[13:41:09]
[13:41:09] Project: 2665 (Run 3, Clone 491, Gen 52)
[13:41:09]
[13:41:09] 65 (Run 3, Clone 491, Gen 52)
[13:41:09]
[13:41:10] Entering M.D.
[13:41:16] Rejecting checkpoint
[13:41:17] Protein: HGG in water
[13:41:17] Writing local files
[13:41:24] Extra SSE boost OK.
[13:41:25] Writing local files
[13:41:25] Completed 0 out of 250000 steps  (0 percent)
Re: Project: 2665 (Run 3, Clone 827, Gen 25) 0% eue 3 times
This is a bad WU ... multiple reports of failure, no successes :(
One of my machines tried to fold it and I got 1.92 points for this one :lol:
