Project: 2665 (Run 1, Clone 850, Gen 51) 5 times on step 28
sYnAnjin
Post by sYnAnjin »
Hi this wu has eue'd on me 5 times all at the same step, thought this was supposed to stop after 3 failures. Down the core twice, in any case think it is a bad wu.
[18:25:52] Completed 65000 out of 250000 steps  (26 percent)
[18:44:24] Writing local files
[18:44:24] Completed 67500 out of 250000 steps  (27 percent)
[19:02:58] Writing local files
[19:02:58] Completed 70000 out of 250000 steps  (28 percent)
[19:19:04] Warning:  long 1-4 interactions
[19:19:05] Quit 101 - NaN detected: (ener[20])
[19:19:05]
[19:19:05] Simulation instability has been encountered. The run has entered a
[19:19:05]   state from which no further progress can be made.
[19:19:05] This may be the correct result of the simulation, however if you
[19:19:05]   often see other project units terminating early like this
[19:19:05]   too, you may wish to check the stability of your computer (issues
[19:19:05]   such as high temperature, overclocking, etc.).
[19:19:05] Going to send back what have done.
[19:19:05] logfile size: 11375
[19:19:05] - Writing 11925 bytes of core data to disk...
[19:19:05]   ... Done.
[19:21:05]
[19:21:05] Folding@home Core Shutdown: EARLY_UNIT_END
[19:21:05]
[19:21:09] CoreStatus = 7B (123)
[19:21:09] Client-core communications error: ERROR 0x7b
[19:21:09] - Attempting to download new core...
[19:21:09] + Downloading new core: FahCore_a1.exe
Mike
Re: Project: 2665 (Run 1, Clone 850, Gen 51) 5 times on step 28
Have you tried qfix to submit partial results ?
There's no other records in the DB for this WU yet ...
sYnAnjin wrote:Hi this wu has eue'd on me 5 times all at the same step, thought this was supposed to stop after 3 failures. Down the core twice, in any case think it is a bad wu.
You may have gotten that incorrect information from me or one of the other Mods, but apparently the "stop after 3 failures" isn't really true, and we don't really know what is true. It may be that after a certain amount of time you'll get a new WU but some of it is strictly chance (i.e.- up to the Assignment Server's choices). The only thing that is certain is that if you upload a partial result (either with the help of qfix or not) it won't be assigned to you again.
