Finished WU not sent
[Inpact]_Gautam
Post by [Inpact]_Gautam »
Hi,
I finished a normal WU with FAH Console, but when the program wanted to send it, it didn't work, I think there were 8 tries.
So I had to close FAH and restart it. But when it restarted it downloaded a new WU, and it didn't send the previous finished WU.
Do you know if it will upload it some time ? Or is lost ?
Thanks in advance :wink:
gwildperson
Re: Finished WU not sent
Post by gwildperson »
During the restart process it probably tried to upload it again. It will keep trying until the server can accept it.
Stanford has been having some networking problems that blocks access to certain servers and somebody has been working on it. It's very unlikely that there's anything you can do except wait.
We need to see the FAHlog.txt file ...
By the way, the client will automatically try to send finished WU every 6 hours.
[Inpact]_Gautam
toTOW wrote:We need to see the FAHlog.txt file ...
Well I checked the log file, and as I expected it didn't try to send it when I restarted FAH. It started directly to download a new WU.
I'll have to wait to see what happens :)
MstrBlstr
Post by MstrBlstr »
It would help if we could see the FAHlog.txt, or the output from -queueinfo.
The client WILL attempt to send anything that is in your queue:
  1. At startup
  2. Every six hours that the client is running.
  3. At the end (and beginning), of every WU.
You may have to set the -verbosity 9 flag to see all the attempts to upload.
-=MB=-
[Inpact]_Gautam
Thanks for your answer, I set the -verbosity 9 flag, and I got this :
[08:58:00] - Autosending finished units...
[08:58:00] Trying to send all finished work units
[08:58:00] + No unsent completed units remaining.
[08:58:00] - Autosend completed
[08:58:00] + Processing work unit
[08:58:00] Core required: FahCore_82.exe
[08:58:00] Core found.
I also checked the LOG file and my previous WU were sent a few hours ago.
So the problem is fixed, thank you all :D
