Hello,
I would like to ask, what happened to my ID, or why there are no credits credited to my F@H ID "Melissa007", I've requested that passkey to my mail, which came in few moments, but after finishing work on laptop and also desktop, I still have 0 credits.
I'm wondering if that could be problem with passkey. Without that I was folding 3 days, (also changed 3 usernames) and everything was fine. But as I have already that passkey, I'm afraid that without passkey it would not cound any credits at all.
Thanks
No credits for work
Re: No credits for work
Is this you?
http://fah-web.stanford.edu/cgi-bin/mai ... Melissa007
The PK has nothing to do with your account getting credit. You have to make sure that you have the donor name and team # exactly the same on all clients that you are running.
You can look at the client.cfg files on the lappy and desktop to see if they are the same.
-=MB=-
Yes, its me
It gave me points for one work, after I deleted PK. :-S (maybe just coinsidence)
Maybe there was some another error, which caused the problem. Next WU should be done in 6 hours,
so I will cehck if that will go without problems
The lappy work was not credited at all, but the log files show it was sent.
And that client.cfg is same at both.
Thanks for answer
Thanks for answer
