Project: 3064 (Run 2, Clone 84, Gen 61)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
xtc? EUEd.
--- Opening Log file [September 18 20:01:12 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: C:\SMP\Folding@Home Windows SMP Client V1.01
Executable: C:\SMP\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe
Arguments: -verbosity 9 -smp
[20:01:12] - Ask before connecting: No
[20:01:12] - User name: anko1 (Team 47815)
[20:01:12] - User ID: 6E38A8D328AF4A1B
[20:01:12] - Machine ID: 1
[20:01:12]
[20:01:12] Loaded queue successfully.
[20:01:12]
[20:01:12] - Autosending finished units... [September 18 20:01:12 UTC]
[20:01:12] + Processing work unit
[20:01:12] Trying to send all finished work units
[20:01:12] Work type a1 not eligible for variable processors
[20:01:12] + No unsent completed units remaining.
[20:01:12] Core required: FahCore_a1.exe
[20:01:12] - Autosend completed
[20:01:12] Core found.
[20:01:12] Using generic mpiexec calls
[20:01:12] Working on queue slot 07 [September 18 20:01:12 UTC]
[20:01:12] + Working ...
[20:01:12] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 2472 -version 622'
[20:01:12]
[20:01:12] *------------------------------*
[20:01:12] Folding@Home Gromacs SMP Core
[20:01:12] Version 1.74 (March 10, 2007)
[20:01:12]
[20:01:12] Preparing to commence simulation
[20:01:12] - Ensuring status. Please wait.
[20:01:29] - Looking at optimizations...
[20:01:29] - Working with standard loops on this execution.
[20:01:29] - Previous termination of core was improper.
[20:01:29] - Going to use standard loops.
[20:01:29] - Files status OK
[20:01:30] - Expanded 609864 -> 3263429 (decompressed 535.1 percent)
[20:01:30]
[20:01:30] Project: 3064 (Run 2, Clone 84, Gen 61)
[20:01:30]
[20:01:30] Entering M.D.
[20:01:36] Calling FAH init
[20:01:36] mbda5_2003
[20:01:36] Writing local files
[20:01:36] Completed 3550000 out of 5000000 steps  (71 percent)
[20:01:36] Extra SSE boost OK.
[20:01:36]
[20:12:19] Writing local files
[20:12:19] Completed 3600000 out of 5000000 steps  (72 percent)
[20:23:30] Writing local files
[20:23:30] Completed 3650000 out of 5000000 steps  (73 percent)
[20:27:26] xtc
[20:27:26] - Failed to delete work/wudata_07.bed
[20:27:26] - Failed to delete work/wudata_07.sas
[20:27:26] - Failed to delete work/wudata_07.goe
[20:27:26] Warning:  check for stray files
[20:27:26]
[20:27:26] Folding@home Core Shutdown: EARLY_UNIT_END
[20:27:26] Finalizing output
[20:27:26] 7.sas
[20:29:26]
[20:29:26] Folding@home Core Shutdown: EARLY_UNIT_END
[20:29:26]
[20:29:31] CoreStatus = 7B (123)
[20:29:31] Client-core communications error: ERROR 0x7b
[20:29:31] Deleting current work unit & continuing...
[20:29:32] Using generic mpiexec calls
[20:31:36] - Warning: Could not delete all work unit files (7): Core returned invalid code
[20:31:36] Trying to send all finished work units
[20:31:36] + No unsent completed units remaining.
[20:31:36] - Preparing to get new work unit...
Used qfix to send in whatever was in the results file:
[04:45:16] + Attempting to send results [September 19 04:45:16 UTC]
[04:45:16] - Reading file work/wuresults_07.dat from core
[04:45:16]   (Read 108844 bytes from disk)
[04:45:16] Connecting to http://171.64.65.63:8080/
[04:45:16] Working on queue slot 08 [September 19 04:45:16 UTC]
[04:45:16] + Working ...
[04:45:16] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 2392 -version 622'
[04:45:16]
[04:45:16] *------------------------------*
[04:45:16] Folding@Home Gromacs SMP Core
[04:45:16] Version 1.74 (March 10, 2007)
[04:45:16]
[04:45:16] Preparing to commence simulation
[04:45:16] - Ensuring status. Please wait.
[04:45:18] Posted data.
[04:45:18] Initial: 0000; - Uploaded at ~53 kB/s
[04:45:18] - Averaged speed for that direction ~51 kB/s
[04:45:18] + Results successfully sent
[04:45:18] Thank you for your contribution to Folding@Home.
[04:45:18] + Number of Units Completed: 34
Re: Project: 3064 (Run 2, Clone 84, Gen 61)
Hi anko1 (team 47815),
Your WU (P3064 R2 C84 G61) was added to the stats database on 2008-09-18 22:27:11 for 920.53 points of credit.
The error code in the DB is strange, I never saw it before, so I don't know what happened :(
anko1
Post by anko1 »
Thanks for checking. Yeah, usually I complete the 3064s successfully, not that I've had that many.
