Project: 5015 (Run 7, Clone 39, Gen 84)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Core internal error with a special exit; tried to resume and then EUEd:
[13:01:06] + Closed connections
[13:01:06]
[13:01:06] + Processing work unit
[13:01:06] Core required: FahCore_11.exe
[13:01:06] Core found.
[13:01:06] Working on queue slot 06 [September 19 13:01:06 UTC]
[13:01:06] + Working ...
[13:01:06] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 15 -verbose -lifeline 2084 -version 620'
[13:01:07]
[13:01:07] *------------------------------*
[13:01:07] Folding@Home GPU Core - Beta
[13:01:07] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:01:07]
[13:01:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:01:07] Build host: amoeba
[13:01:07] Board Type: Nvidia
[13:01:07] Core      :
[13:01:07] Preparing to commence simulation
[13:01:07] - Looking at optimizations...
[13:01:07] - Created dyn
[13:01:07] - Files status OK
[13:01:07] - Expanded 44114 -> 244433 (decompressed 554.0 percent)
[13:01:07] Called DecompressByteArray: compressed_data_size=44114 data_size=244433, decompressed_data_size=244433 diff=0
[13:01:07] - Digital signature verified
[13:01:07]
[13:01:07] Project: 5015 (Run 7, Clone 39, Gen 84)
[13:01:07]
[13:01:07] Assembly optimizations on if available.
[13:01:07] Entering M.D.
[13:01:13] Working on 576 p5005_supervillin_e1
[13:01:14] Client config found, loading data.
[13:01:14] Starting GUI Server
[13:02:45] Completed 1%
     {snip}
[14:21:26] Completed 51%
[14:22:59] Unit 3's deadline (September 19 09:48) has passed.
[14:23:01] Completed 52%
[14:23:11] - Autosending finished units... [September 19 14:23:11 UTC]
[14:23:11] Trying to send all finished work units
[14:23:11] Project: 5229 (Run 3, Clone 16, Gen 41)
[14:23:11] - Read packet limit of 540015616... Set to 524286976.
[14:23:11] + Attempting to send results [September 19 14:23:11 UTC]
[14:23:11] - Reading file work/wuresults_02.dat from core
[14:23:11]   (Read 1158027 bytes from disk)
[14:23:11] Connecting to http://171.64.122.74:8080/
[14:23:11] CoreStatus = 65 (101)
[14:23:11] Core internal error: SPECIAL_EXIT
[14:23:16]
[14:23:16] + Processing work unit
[14:23:16] Core required: FahCore_11.exe
[14:23:16] Core found.
[14:23:16] Working on queue slot 06 [September 19 14:23:16 UTC]
[14:23:16] + Working ...
[14:23:16] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 15 -verbose -lifeline 2084 -version 620'
[14:23:16]
[14:23:16] *------------------------------*
[14:23:16] Folding@Home GPU Core - Beta
[14:23:16] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[14:23:16]
[14:23:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:23:16] Build host: amoeba
[14:23:16] Board Type: Nvidia
[14:23:16] Core      :
[14:23:16] Preparing to commence simulation
[14:23:16] - Looking at optimizations...
[14:23:16] - Previous termination of core was improper.
[14:23:16] - Files status OK
[14:23:16] - Expanded 44114 -> 244433 (decompressed 554.0 percent)
[14:23:16] Called DecompressByteArray: compressed_data_size=44114 data_size=244433, decompressed_data_size=244433 diff=0
[14:23:16] - Digital signature verified
[14:23:16]
[14:23:16] Project: 5015 (Run 7, Clone 39, Gen 84)
[14:23:16]
[14:23:16] Entering M.D.
[14:23:22] Will resume from checkpoint file
[14:23:22] Working on 576 p5005_supervillin_e1
[14:23:23] Client config found, loading data.
[14:23:23] Resuming from checkpoint
[14:23:23] Gromacs cannot continue further.
[14:23:23] Going to send back what have done.
[14:23:23] Starting GUI Server
[14:23:24] logfile size: 71265 info=71265 bed=0 hdr=23
[14:23:24] - Writing 71801 bytes of core data to disk...
[14:23:24] Done: 71289 -> 8893 (compressed to 12.4 percent)
[14:23:24]   ... Done.
[14:23:24]
[14:23:24] Folding@home Core Shutdown: EARLY_UNIT_END
[14:23:26] CoreStatus = 72 (114)
[14:23:26] Sending work to server
[14:23:26] - Already sending work
[14:23:26] Trying to send all finished work units
[14:23:26] + Sent 0 of 3 completed units to the server
[14:23:26] - Preparing to get new work unit...
[14:23:26] + Attempting to get work packet
[14:23:26] - Will indicate memory of 3326 MB
[14:23:26] - Connecting to assignment server
What little there was got sent back:
[14:27:23] Project: 5015 (Run 7, Clone 39, Gen 84)
[14:27:23] - Read packet limit of 540015616... Set to 524286976.
[14:27:23] + Attempting to send results [September 19 14:27:23 UTC]
[14:27:23] - Reading file work/wuresults_06.dat from core
[14:27:23]   (Read 9405 bytes from disk)
[14:27:23] Connecting to http://171.64.65.20:8080/
[14:27:23] Posted data.
[14:27:24] Initial: 0000; - Uploaded at ~10 kB/s
[14:27:24] - Averaged speed for that direction ~41 kB/s
[14:27:24] + Results successfully sent
[14:27:24] Thank you for your contribution to Folding@Home.
Re: Project: 5015 (Run 7, Clone 39, Gen 84)
Hi anko1 (team 47815),
Your WU (P5015 R7 C39 G84) was added to the stats database on 2008-09-19 08:36:31 for 0 points of credit.
Someone else got full credit for it ...
anko1
Post by anko1 »
Thanks for checking toTOW. With only 9,405 bytes, I'm not surprised I got 0 points, though I would have thought that at 52% there'd be more data, but perhaps that was caused by the core error.
