time/frame
hardhead
time/frame
Post by hardhead »
This may be a stupid question, but I barely know a computer from a washing machine. My time/frame varies from about 13min/frame to more than 42 min/frame, often when the computer isn't being used for anything else. The first 2 WU each took about 4 days, and the current one looks like about the same. Is this variation normal, or does it indicate the computer might be about to have problems?
Thank you,
Hardhead
John_Weatherman
Re: time/frame
Post by John_Weatherman »
It is normal with different times to complete workunits. There is sometimes a large variation between different projects too.
Re: time/frame
This is normal : FAH releases your CPU power to allow your other application to run as fast as usual ;)
So you can still use your computer without noticing that FAH is running :)
