Project: 3064 (Run 5, Clone 219, Gen 5)
Insidious
Post by Insidious »
Looks like this one is borked.
[17:20:23] Connecting to http://assign.stanford.edu:8080/
[17:20:24] Posted data.
[17:20:24] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[17:20:24] + News From Folding@Home: Welcome to Folding@Home
[17:20:24] Loaded queue successfully.
[17:20:24] Connecting to http://171.64.65.63:8080/
[17:20:25] Posted data.
[17:20:25] Initial: 0000; - Receiving payload (expected size: 610201)
[17:20:27] - Downloaded at ~297 kB/s
[17:20:27] - Averaged speed for that direction ~375 kB/s
[17:20:27] + Received work.
[17:20:27] Trying to send all finished work units
[17:20:27] + No unsent completed units remaining.
[17:20:27] + Closed connections
[17:20:27]
[17:20:27] + Processing work unit
[17:20:27] Work type a1 not eligible for variable processors
[17:20:27] Core required: FahCore_a1.exe
[17:20:27] Core found.
[17:20:27] Using generic mpiexec calls
[17:20:27] Working on queue slot 05 [September 16 17:20:27 UTC]
[17:20:27] + Working ...
[17:20:27] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 05 -checkpoint 15 -forceasm -verbose -lifeline 1092 -version 622'
[17:20:27]
[17:20:27] *------------------------------*
[17:20:27] Folding@Home Gromacs SMP Core
[17:20:27] Version 1.74 (March 10, 2007)
[17:20:27]
[17:20:27] Preparing to commence simulation
[17:20:27] - Ensuring status. Please wait.
[17:20:44] - Assembly optimizations manually forced on.
[17:20:44] - Not checking prior termination.
[17:20:45] - Expanded 609689 -> 3260933 (decompressed 534.8 percent)
[17:20:45] - Starting from initial work packet
[17:20:45]
[17:20:45] Project: 3064 (Run 5, Clone 219, Gen 5)
[17:20:45]
[17:20:45] Assembly optimizations on if available.
[17:20:45] Entering M.D.
[17:20:51] Protein: p3064_lambdaProteinWriting local files
[17:20:51] Extra SSE boost OK.
[17:20:51]
[17:20:51] Writing local files
[17:20:51] Completed 0 out of 5000000 steps  (0 percent)
[17:32:02] Writing local files
[17:32:02] Completed 50000 out of 5000000 steps  (1 percent)
[17:33:11] delete work/wudata_05.arc
[17:33:11] Warning:  check for stray files
[17:33:11] 5.xtc
[17:33:11] No C.P. to delete.
[17:33:11] - Failed to delete work/wudata_05.bed
[17:33:11] - Failed to delete work/wudata_05.sas
[17:33:11] - Failed to delete work/wudata_05.pdo
[17:33:11] - Failed to delete work/wudata_05.xvg
[17:33:11] lete work/wudata_05.pdo
[17:33:11]
[17:33:11] Folding@home Core Shutdown: EARLY_UNIT_END
[17:33:11]
[17:33:14] CoreStatus = 7B (123)
[17:33:14] Client-core communications error: ERROR 0x7b
[17:33:14] Deleting current work unit & continuing...
[17:33:14] Using generic mpiexec calls
[17:35:34] - Warning: Could not delete all work unit files (5): Core returned invalid code
[17:35:34] Trying to send all finished work units
[17:35:34] + No unsent completed units remaining.
[17:35:34] - Preparing to get new work unit...
[17:35:34] + Attempting to get work packet
[17:35:34] - Will indicate memory of 2046 MB
[17:35:34] - Connecting to assignment server
[17:35:34] Connecting to http://assign.stanford.edu:8080/
[17:35:34] Posted data.
[17:35:34] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[17:35:34] + News From Folding@Home: Welcome to Folding@Home
[17:35:34] Loaded queue successfully.
[17:35:34] Connecting to http://171.64.65.63:8080/
[17:35:35] Posted data.
[17:35:35] Initial: 0000; - Receiving payload (expected size: 610201)
[17:35:37] - Downloaded at ~297 kB/s
[17:35:37] - Averaged speed for that direction ~359 kB/s
[17:35:37] + Received work.
[17:35:37] + Closed connections
[17:35:42]
[17:35:42] + Processing work unit
[17:35:42] Work type a1 not eligible for variable processors
[17:35:42] Core required: FahCore_a1.exe
[17:35:42] Core found.
[17:35:42] Using generic mpiexec calls
[17:35:42] Working on queue slot 06 [September 16 17:35:42 UTC]
[17:35:42] + Working ...
[17:35:42] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline 1092 -version 622'
[17:35:42]
[17:35:42] *------------------------------*
[17:35:42] Folding@Home Gromacs SMP Core
[17:35:42] Version 1.74 (March 10, 2007)
[17:35:42]
[17:35:42] Preparing to commence simulation
[17:35:42] - Ensuring status. Please wait.
[17:35:59] - Assembly optimizations manually forced on.
[17:35:59] - Not checking prior termination.
[17:36:00] - Expanded 609689 -> 3260933 (decompressed 534.8 percent)
[17:36:00] - Starting from initial work packet
[17:36:00]
[17:36:00] Project: 3064 (Run 5, Clone 219, Gen 5)
[17:36:00]
[17:36:00] Assembly optimizations on if available.
[17:36:00] Entering M.D.
[17:36:00] ne 219, Gen 5)
[17:36:00]
[17:36:06] xtra SSE boost OK.
[17:36:06] Writing local files
[17:36:06] Completed 0 out of 5000000 steps  (0 percent)
[17:47:17] Writing local files
[17:47:17] Completed 50000 out of 5000000 steps  (1 percent)
[17:48:26] delete work/wudata_06.arc
[17:48:26] - Failed to delete work/wudata_06.xvg
[17:48:26] Warning:  check for stray files
[17:48:26] elete work/wudata_06.sas
[17:48:26] - Failed to delete work/wudata_06.goe
[17:48:26] - Failed to delete work/wudata_06.pdo
[17:48:26]
[17:48:26] Folding@home Core Shutdown: EARLY_UNIT_END
[17:48:26] Finalizing output
[17:48:26] wudata_06.xvg
[17:50:26] @home Core Shutdown: EARLY_UNIT_END
[17:50:26] NIT_END
[17:50:26] Finalizing output
[17:50:30] CoreStatus = 7B (123)
[17:50:30] Client-core communications error: ERROR 0x7b
[17:50:30] Deleting current work unit & continuing...
[17:50:30] Using generic mpiexec calls
[17:52:50] - Warning: Could not delete all work unit files (6): Core returned invalid code
[17:52:50] Trying to send all finished work units
[17:52:50] + No unsent completed units remaining.
[17:52:50] - Preparing to get new work unit...
[17:52:50] + Attempting to get work packet
[17:52:50] - Will indicate memory of 2046 MB
[17:52:50] - Connecting to assignment server
[17:52:50] Connecting to http://assign.stanford.edu:8080/
[17:52:51] Posted data.
[17:52:51] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[17:52:51] + News From Folding@Home: Welcome to Folding@Home
[17:52:51] Loaded queue successfully.
[17:52:51] Connecting to http://171.64.65.63:8080/
[17:52:52] Posted data.
[17:52:52] Initial: 0000; - Receiving payload (expected size: 610201)
[17:52:53] - Downloaded at ~595 kB/s
[17:52:53] - Averaged speed for that direction ~407 kB/s
[17:52:53] + Received work.
[17:52:53] + Closed connections
[17:52:58]
[17:52:58] + Processing work unit
[17:52:58] Work type a1 not eligible for variable processors
[17:52:58] Core required: FahCore_a1.exe
[17:52:58] Core found.
[17:52:58] Using generic mpiexec calls
[17:52:58] Working on queue slot 07 [September 16 17:52:58 UTC]
[17:52:58] + Working ...
[17:52:58] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 15 -forceasm -verbose -lifeline 1092 -version 622'
[17:52:59]
[17:52:59] *------------------------------*
[17:52:59] Folding@Home Gromacs SMP Core
[17:52:59] Version 1.74 (March 10, 2007)
[17:52:59]
[17:52:59] Preparing to commence simulation
[17:52:59] - Ensuring status. Please wait.
[17:53:16] - Assembly optimizations manually forced on.
[17:53:16] - Not checking prior termination.
[17:53:16] - Expanded 609689 -> 3260933 (decompressed 534.8 percent)
[17:53:16] - Starting from initial work packet
[17:53:16]
[17:53:16] Project: 3064 (Run 5, Clone 219, Gen 5)
[17:53:16]
[17:53:16] Assembly optimizations on if available.
[17:53:16] Entering M.D.
[17:53:22] Rejecting checkpoint
[17:53:23] ProteinWriting local files
[17:53:23] Extra SSE boost OK.
[17:53:23]
[17:53:23] Writing local files
[17:53:23] Completed 0 out of 5000000 steps  (0 percent)
[18:04:20] Writing local files
[18:04:20] Completed 50000 out of 5000000 steps  (1 percent)
[18:05:29] delete work/wudata_07.arc
[18:05:29] No C.P. to delete.
[18:05:29] - Failed to delete work/wudata_07.goe
[18:05:29] - Failed to delete work/wudata_07.pdo
[18:05:29] Warning:  check for stray files
[18:05:29] elete work/wudata_07.xvg
[18:05:29] lete work/wudata_07.goe
[18:05:29] - Failed to delete work/wudata_07.xvg
[18:05:29]
[18:05:29] Folding@home Core Shutdown: EARLY_UNIT_END
[18:05:29]
[18:05:33] CoreStatus = 7B (123)
[18:05:33] Client-core communications error: ERROR 0x7b
[18:05:33] - Attempting to download new core...
WindowsXP, MPICH version of SMP client
Re: Project: 3064 (Run 5, Clone 219, Gen 5)
There's no report in the DB for that WU yet.
You might want to submit your partial results with qfix : viewtopic.php?f=8&t=191
Insidious
Post by Insidious »
Thanks ToTOW,
I'm not really too worried about the points. My client has moved on to other stuff.
-Sid
These two lines seemed weird:
I was surprised there was no indication of why the client just decided to delete the work
