Project: 3062 (Run 5, Clone 169, Gen 23) Error 0x7b
BrgHW
Post by BrgHW »
Writing local files
[10:48:00] Completed 1200000 out of 5000000 steps (24 percent)
[11:03:32] Writing local files
[11:03:32] Completed 1250000 out of 5000000 steps (25 percent)
[11:19:00] Writing local files
[11:19:00] Completed 1300000 out of 5000000 steps (26 percent)
[11:34:34] Writing local files
[11:34:34] Completed 1350000 out of 5000000 steps (27 percent)
[11:50:06] Writing local files
[11:50:06] Completed 1400000 out of 5000000 steps (28 percent)
[12:05:41] Writing local files
[12:05:41] Completed 1450000 out of 5000000 steps (29 percent)
[12:14:18] Warning: long 1-4 interactions
[12:14:18] Gromacs cannot continue further.
[12:14:18] Going to send back what have done.
[12:14:18] logfile size: 45439
[12:14:18] - Could not open results file
[12:14:18] - Failed to delete work/wudata_07.bed
[12:14:18] - Failed to delete work/wudata_07.sas
[12:14:18] - Failed to delete work/wudata_07.goe
[12:14:18] Warning: check for stray files
[12:14:18]
[12:14:18] Folding@home Core Shutdown: EARLY_UNIT_END
[12:14:18]
[12:14:22] CoreStatus = 7B (123)
[12:14:22] Client-core communications error: ERROR 0x7b
[12:14:22] This is a sign of more serious problems, shutting down.
Re: Project: 3062,R5,Clone 169, Gen 23. Error 0x7b
There's no data for this WU in the stats DB, but you can try qfix to submit your partial results : viewtopic.php?f=8&t=191
BrgHW
Post by BrgHW »
I did try that.
Using CMD window.
Running qfix.
Starting FAH with -send all tag
FAH starting and shuts down after 5 sec.
Folding@Home Client Version 6.22 SMP Beta2
http://folding.stanford.edu
Launch directory: G:\Programfiler\Folding@Home Windows SMP Client V1.01
Executable: Folding@home-Win32-x86.exe
Arguments: -send all
[15:33:32] - Ask before connecting: No
[15:33:32] - User name: BrgHW (Team 37651)
[15:33:32] - User ID: 555B5181794A3E62
[15:33:32] - Machine ID: 1
[15:33:32]
[15:33:32] Loaded queue successfully.
[15:33:32] Attempting to return result(s) to server...
Folding@Home Client Shutdown.
What was the output from qfix?
I guess it's the output after restarting the client after qfix was used.
The qfix output (in the terminal window) is important, too.
BrgHW
Post by BrgHW »
Sorry, have deleted the work and moved on. Can't stop folding.
Next time I'll save the Qfix output.
anko1
(3.2GHz) HT;Windows XP
Re: Project: 3062 (Run 5, Clone 169, Gen 23) Error 0x7b
Post by anko1 »
BrgHW - it appears that you're not using the latest SMP client: beta 2r3. That's largely alleviated the client shutting down after an EUE for me.
BrgHW
Post by BrgHW »
No new client is on the download. Only the release from 08.08.08
Check this one : viewtopic.php?f=46&t=4913
