Project: 2665 (Run 0, Clone 18, Gen 41)
ChelseaOilman
Post by ChelseaOilman »
Seems to be a bad WU. I checked the WU database, 16 people have had similar results. I had to use qfix to upload the results.
[14:22:43] Working on queue slot 04 [September 14 14:22:43 UTC]
[14:22:43] + Working ...
[14:22:43] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline 2876 -version 622'
[14:22:43]
[14:22:43] *------------------------------*
[14:22:43] Folding@Home Gromacs SMP Core
[14:22:43] Version 1.74 (March 10, 2007)
[14:22:43]
[14:22:43] Preparing to commence simulation
[14:22:43] - Ensuring status. Please wait.
[14:23:01] - Assembly optimizations manually forced on.
[14:23:01] - Not checking prior termination.
[14:23:14] - Expanded 4734263 -> 24426905 (decompressed 515.9 percent)
[14:23:14] - Starting from initial work packet
[14:23:14]
[14:23:14] Project: 2665 (Run 0, Clone 18, Gen 41)
[14:23:14]
[14:23:18] Assembly optimizations on if available.
[14:23:18] Entering M.D.
[14:23:24] Rejecting checkpoint
[14:23:26] Protein: HGG in water
[14:23:26] Writing local files
[14:23:33] Extra SSE boost OK.
[14:23:34] Writing local files
[14:23:34] Completed 0 out of 250000 steps  (0 percent)
[14:29:54] Warning:  long 1-4 interactions
[14:29:54] hich no further progress can be made.
[14:29:54] This may be the correct result of the simulation, however if you
[14:29:54]   often see other project units terminating early like this
[14:29:54]   too, you may wish to check the stability of your computer (issues
[14:29:54]   such as high temperature, overclocking, etc.).
[14:29:54] Going to send back what have done.
[14:29:54] logfile size: 9422
[14:29:54] - Writing 9972 bytes of core data to disk...
[14:29:54]   ... Done.
[14:29:54] - Failed to delete work/wudata_04.arc
[14:29:54] No C.P. to delete.
[14:29:54] Warning:  check for stray files
[14:29:54] .
[14:29:54]
[14:29:54] Folding@home Core Shutdown: EARLY_UNIT_END
[14:29:54] Finalizing output
[14:29:54] check for stray files
[14:31:54]
[14:31:54] Folding@home Core Shutdown: EARLY_UNIT_END
[14:31:54]
[14:31:57] CoreStatus = 7B (123)
[14:31:57] Client-core communications error: ERROR 0x7b
[14:31:57] Deleting current work unit & continuing...
nwkelley
Pande Group Member
Re: Project: 2665 (Run 0, Clone 18, Gen 41)
Post by nwkelley »
i'll take it out, thanks!
