Project: 2665 (Run 3, Clone 418, Gen 45)
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
--- Opening Log file [September 12 03:41:27 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: C:\fah-shm
Executable: C:\fah-shm\fah6.22-2r3.exe
Arguments: -smp -deino -advmethods -forceasm -verbosity 9 -oneunit
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[03:41:27] - Ask before connecting: No
[03:41:27] - User name: SKeptical_Thinker (Team 31574)
[03:41:27] - User ID: 13EBF4092BD8FB00
[03:41:27] - Machine ID: 1
[03:41:27]
[03:41:27] Loaded queue successfully.
[03:41:27] - Preparing to get new work unit...
[03:41:27] + Attempting to get work packet
[03:41:27] - Autosending finished units... [03:41:27]
[03:41:27] Trying to send all finished work units
[03:41:27] - Will indicate memory of 3326 MB
[03:41:27] + No unsent completed units remaining.
[03:41:27] - Detect CPU.[03:41:27] - Autosend completed
 Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[03:41:27] - Connecting to assignment server
[03:41:27] Connecting to http://assign.stanford.edu:8080/
[03:41:27] Posted data.
[03:41:27] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[03:41:27] + News From Folding@Home: Welcome to Folding@Home
[03:41:28] Loaded queue successfully.
[03:41:28] Connecting to http://171.64.65.64:8080/
[03:41:33] Posted data.
[03:41:33] Initial: 0000; - Receiving payload (expected size: 4718782)
[03:41:49] - Downloaded at ~288 kB/s
[03:41:49] - Averaged speed for that direction ~286 kB/s
[03:41:49] + Received work.
[03:41:49] + Closed connections
[03:41:49]
[03:41:49] + Processing work unit
[03:41:49] Work type a1 not eligible for variable processors
[03:41:49] Core required: FahCore_a1.exe
[03:41:49] Core found.
[03:41:49] Working on queue slot 02 [September 12 03:41:49 UTC]
[03:41:49] + Working ...
[03:41:49] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 02 -checkpoint 15 -forceasm -verbose -lifeline 5184 -version 622'
[03:41:50]
[03:41:50] *------------------------------*
[03:41:50] Folding@Home Gromacs SMP Core
[03:41:50] Version 1.76 (February 23, 2008)
[03:41:50]
[03:41:50] Preparing to commence simulation
[03:41:50] - Ensuring status. Please wait.
[03:42:07] - Assembly optimizations manually forced on.
[03:42:07] - Not checking prior termination.
[03:42:23] - Expanded 4718270 -> 24426905 (decompressed 517.7 percent)
[03:42:24] - Starting from initial work packet
[03:42:24]
[03:42:24] Project: 2665 (Run 3, Clone 418, Gen 45)
[03:42:24]
[03:42:28] Assembly optimizations on if available.
[03:42:28] Entering M.D.
[03:42:35] Rejecting checkpoint
[03:42:37]
[03:42:37] Writing local files
[03:42:38]
[03:42:38] Writing local files
[03:42:48] Extra SSE boost OK.
[03:42:49] Writing local files
[03:42:49] Completed 0 out of 250000 steps  (0 percent)
[03:57:50] Timered checkpoint triggered.
[04:12:52] Timered checkpoint triggered.
[04:26:36] Writing local files
[04:26:36] Completed 2500 out of 250000 steps  (1 percent)
[04:41:37] Timered checkpoint triggered.
[04:56:39] Timered checkpoint triggered.
[05:10:08] Writing local files
[05:10:08] Completed 5000 out of 250000 steps  (2 percent)
[05:25:10] Timered checkpoint triggered.
[05:40:11] Timered checkpoint triggered.
[05:53:18] Writing local files
[05:53:19] Completed 7500 out of 250000 steps  (3 percent)
[06:08:19] Timered checkpoint triggered.
[06:23:21] Timered checkpoint triggered.
[06:36:43] Writing local files
[06:36:44] Completed 10000 out of 250000 steps  (4 percent)
[06:51:46] Timered checkpoint triggered.
[07:06:47] Timered checkpoint triggered.
[07:20:18] Writing local files
[07:20:18] Completed 12500 out of 250000 steps  (5 percent)
[07:35:22] Timered checkpoint triggered.
[07:50:23] Timered checkpoint triggered.
[08:03:52] Writing local files
[08:03:52] Completed 15000 out of 250000 steps  (6 percent)
[08:18:54] Timered checkpoint triggered.
[08:33:55] Timered checkpoint triggered.
[08:46:11] Writing local files
[08:46:11] Completed 17500 out of 250000 steps  (7 percent)
[09:01:12] Timered checkpoint triggered.
[09:16:13] Timered checkpoint triggered.
[09:25:16] Writing local files
[09:25:17] Completed 20000 out of 250000 steps  (8 percent)
[09:40:17] Timered checkpoint triggered.
[09:41:27] - Autosending finished units... [September 12 09:41:27 UTC]
[09:41:27] Trying to send all finished work units
[09:41:27] + No unsent completed units remaining.
[09:41:27] - Autosend completed
[09:45:29] Warning:  long 1-4 interactions
[09:45:29] Quit 101 - NaN detected: (ener[20])
[09:45:29]
[09:45:29] Simulation instability has been encountered. The run has entered a
[09:45:29]   state from which no further progress can be made.
[09:45:29] This may be the correct result of the simulation, however if you
[09:45:29]   often see other project units terminating early like this
[09:45:29]   too, you may wish to check the stability of your computer (issues
[09:45:29]   such as high temperature, overclocking, etc.).
[09:45:29] Going to send back what have done.
[09:45:29] logfile size: 24812
[09:45:29] - Writing 25362 bytes of core data to disk...
[09:45:29]   ... Done.
[09:45:29] No C.P. to delete.
[09:45:30] - Failed to delete work/wudata_02.sas
[09:45:30] Warning:  check for stray files
[09:45:30]
[09:45:30] Folding@home Core Shutdown: EARLY_UNIT_END
[09:45:30]
[09:45:35] CoreStatus = 63 (99)
[09:45:35] + Error starting Folding@Home core.
[09:45:40]
[09:45:40] + Processing work unit
[09:45:40] Work type a1 not eligible for variable processors
[09:45:40] Core required: FahCore_a1.exe
[09:45:40] Core found.
[09:45:40] Working on queue slot 02 [September 12 09:45:40 UTC]
[09:45:40] + Working ...
[09:45:40] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 02 -checkpoint 15 -forceasm -verbose -lifeline 5184 -version 622'
[09:45:42]
[09:45:42] *------------------------------*
[09:45:42] Folding@Home Gromacs SMP Core
[09:45:42] Version 1.76 (February 23, 2008)
[09:45:42]
[09:45:42] Preparing to commence simulation
[09:45:42] - Assembly optimizations manually forced on.
[09:45:42] - Not checking prior termination.
[09:45:42]
[09:45:42] Folding@home Core Shutdown: MISSING_WORK_FILES
[09:45:42] Finalizing output
[09:47:59] NG_WORK_FILES
[09:47:59] Finalizing output
[09:48:03] CoreStatus = 1 (1)
[09:48:03] Client-core communications error: ERROR 0x1
[09:48:03] Deleting current work unit & continuing...
[09:50:25] - Warning: Could not delete all work unit files (2): Core returned invalid code
[09:50:25] Trying to send all finished work units
[09:50:25] + No unsent completed units remaining.
[09:50:25] - Preparing to get new work unit...
[09:50:25] + Attempting to get work packet
[09:50:25] - Will indicate memory of 3326 MB
[09:50:25] - Connecting to assignment server
[09:50:25] Connecting to http://assign.stanford.edu:8080/
[09:50:25] Posted data.
[09:50:25] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[09:50:25] + News From Folding@Home: Welcome to Folding@Home
[09:50:25] Loaded queue successfully.
[09:50:25] Connecting to http://171.64.65.64:8080/
[09:50:31] Posted data.
[09:50:31] Initial: 0000; - Receiving payload (expected size: 4718782)
[09:50:45] - Downloaded at ~329 kB/s
[09:50:45] - Averaged speed for that direction ~300 kB/s
[09:50:45] + Received work.
[09:50:46] + Closed connections
[09:50:51]
[09:50:51] + Processing work unit
[09:50:51] Work type a1 not eligible for variable processors
[09:50:51] Core required: FahCore_a1.exe
[09:50:51] Core found.
[09:50:51] Working on queue slot 03 [September 12 09:50:51 UTC]
[09:50:51] + Working ...
[09:50:51] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline 5184 -version 622'
[09:50:52]
[09:50:52] *------------------------------*
[09:50:52] Folding@Home Gromacs SMP Core
[09:50:52] Version 1.76 (February 23, 2008)
[09:50:52]
[09:50:52] Preparing to commence simulation
[09:50:52] - Ensuring status. Please wait.
[09:51:09] - Assembly optimizations manually forced on.
[09:51:09] - Not checking prior termination.
[09:51:25] - Expanded 4718270 -> 24426905 (decompressed 517.7 percent)
[09:51:26] - Starting from initial work packet
[09:51:26]
[09:51:26] Project: 2665 (Run 3, Clone 418, Gen 45)
[09:51:26]
[09:51:28] Assembly optimizations on if available.
[09:51:28] Entering M.D.
[09:51:35] Rejecting checkpoint
[09:51:37]
[09:51:37] Writing local files
[09:51:37]
[09:51:48] Extra SSE boost OK.
[09:51:49] Writing local files
[09:51:49] Completed 0 out of 250000 steps  (0 percent)
[10:06:50] Timered checkpoint triggered.
[10:21:52] Timered checkpoint triggered.
[10:36:24] Writing local files
[10:36:25] Completed 2500 out of 250000 steps  (1 percent)
[10:51:25] Timered checkpoint triggered.
Last edited by SKeptical_Thinker on Fri Sep 12, 2008 11:08 am, edited 1 time in total.
Re: Project: 2665 (Run 3, Clone 418, Gen 45)
Well, no one was able to complete this one yet : a partial credit, and a 0 point credit.
rbrandman
Pande Group Member
Post by rbrandman »
Thanks for the post. I'll alert the researcher in charge of this project, Peter Kasson, so he can check this work unit.
Relly
