"view your posts"
Locked
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
"view your posts"
Post by SKeptical_Thinker »
Is there any reason that clicking "view your posts" doesn't give me a list of my posts? It appears to give me a list of the threads that I have posted to. While that is likely something that I would use, it isn't what I expected. I can get a list of my posts from the avdvance search page, so this isn't an earth-shattering issue.
Re: "view your posts"
It shows all topics where you posted at least one message.
If you want to find the threads you started, you need to go to the search page, and use the ésearch by athor" function.
SKeptical_Thinker
EVGA 8800 GS
Ninja Mini CPU HS
toTOW wrote:It shows all topics where you posted at least one message.
Yes, that's what I said.
uncle_fungus
Post by uncle_fungus »
Its just the way phpbb works. The "view your posts" link just directs to a custom parameter of the search page.
You can get to the "by post" view by clicking the link on you profile page (Search user’s posts).
SKeptical_Thinker
EVGA 8800 GS
Ninja Mini CPU HS
So, am I the only one literal minded enough to expect that clicking on "view your posts" would show me my posts? If it said "view the threads you have contributed to" I wouldn't have thought the results to be unexpected.
anandhanju
Post by anandhanju »
SKeptical_Thinker wrote:So, am I the only one literal minded enough to expect that clicking on "view your posts" would show me my posts? If it said "view the threads you have contributed to" I wouldn't have thought the results to be unexpected.
I'm with you, only have got used to this little quirk :wink:
No, probably not, but your question is outside the scope of this Folding Support forum. ;)
Sorry, we just rent phpBB for this forum, we don't code it. You might try asking the developers in the phpBB support forums.
Locked
