Project: 5506 (Run 7, Clone 198, Gen 76)
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
Another EUE sandwiched between two WUs that completed correctly:
[03:55:12] Completed 97%
[03:56:35] Completed 98%
[03:57:57] Completed 99%
[03:59:20] Completed 100%
[04:00:20]
[04:00:20] Finished Work Unit:
[04:00:20] - Reading up to 34800 from "work/wudata_08.trr": Read 34800
[04:00:20] trr file hash check passed.
[04:00:20] - Reading up to 1127356 from "work/wudata_08.xtc": Read 1127356
[04:00:20] xtc file hash check passed.
[04:00:20] edr file hash check passed.
[04:00:20] logfile size: 130462
[04:00:20] Leaving Run
[04:00:23] - Writing 1293690 bytes of core data to disk...
[04:00:24] Done: 1293178 -> 1155489 (compressed to 89.3 percent)
[04:00:24]   ... Done.
[04:00:24] - Shutting down core
[04:00:24]
[04:00:24] Folding@home Core Shutdown: FINISHED_UNIT
[04:00:28] CoreStatus = 64 (100)
[04:00:28] Sending work to server
[04:00:28] Project: 5015 (Run 5, Clone 836, Gen 81)
[04:00:28] - Read packet limit of 540015616... Set to 524286976.
[04:00:28] + Attempting to send results [September 9 04:00:28 UTC]
[04:00:51] + Results successfully sent
[04:00:51] Thank you for your contribution to Folding@Home.
[04:00:51] + Number of Units Completed: 260
[04:00:55] - Preparing to get new work unit...
[04:00:55] + Attempting to get work packet
[04:00:55] - Connecting to assignment server
[04:00:55] - Successful: assigned to (171.64.65.106).
[04:00:55] + News From Folding@Home: GPU folding beta
[04:00:56] Loaded queue successfully.
[04:00:57] + Closed connections
[04:00:57]
[04:00:57] + Processing work unit
[04:00:57] Core required: FahCore_11.exe
[04:00:57] Core found.
[04:00:57] Working on queue slot 09 [September 9 04:00:57 UTC]
[04:00:57] + Working ...
[04:00:57]
[04:00:57] *------------------------------*
[04:00:57] Folding@Home GPU Core - Beta
[04:00:57] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[04:00:57]
[04:00:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:00:57] Build host: amoeba
[04:00:57] Board Type: Nvidia
[04:00:57] Core      :
[04:00:57] Preparing to commence simulation
[04:00:57] - Looking at optimizations...
[04:00:57] - Created dyn
[04:00:57] - Files status OK
[04:00:57] - Expanded 45453 -> 246249 (decompressed 541.7 percent)
[04:00:57] Called DecompressByteArray: compressed_data_size=45453 data_size=246249, decompressed_data_size=246249 diff=0
[04:00:57] - Digital signature verified
[04:00:57]
[04:00:57] Project: 5506 (Run 7, Clone 198, Gen 76)
[04:00:57]
[04:00:57] Assembly optimizations on if available.
[04:00:57] Entering M.D.
[04:01:03] Working on p5506_supervillin_e1
[04:01:04] Client config found, loading data.
[04:01:04] Starting GUI Server
[04:02:27] Completed 1%
[04:03:50] Completed 2%
[04:05:13] Completed 3%
[04:06:36] Completed 4%
[04:07:59] Completed 5%
[04:09:22] Completed 6%
[04:10:45] Completed 7%
[04:12:08] Completed 8%
[04:13:31] Completed 9%
[04:14:55] Completed 10%
[04:15:09] mdrun_gpu returned -1
[04:15:09] Going to send back what have done.
[04:15:10] logfile size: 22305 info=22305 bed=0 hdr=25
[04:15:10] - Writing 22843 bytes of core data to disk...
[04:15:10] Done: 22331 -> 5152 (compressed to 23.0 percent)
[04:15:10]   ... Done.
[04:15:10]
[04:15:10] Folding@home Core Shutdown: EARLY_UNIT_END
[04:15:13] CoreStatus = 72 (114)
[04:15:13] Sending work to server
[04:15:13] Project: 5506 (Run 7, Clone 198, Gen 76)
[04:15:13] - Read packet limit of 540015616... Set to 524286976.
[04:15:13] + Attempting to send results [September 9 04:15:13 UTC]
[04:15:13] + Results successfully sent
[04:15:13] Thank you for your contribution to Folding@Home.
[04:15:17] - Preparing to get new work unit...
[04:15:17] + Attempting to get work packet
[04:15:17] - Connecting to assignment server
[04:15:18] - Successful: assigned to (171.64.65.106).
[04:15:18] + News From Folding@Home: GPU folding beta
[04:15:18] Loaded queue successfully.
[04:15:19] + Closed connections
[04:15:24]
[04:15:24] + Processing work unit
[04:15:24] Core required: FahCore_11.exe
[04:15:24] Core found.
[04:15:24] Working on queue slot 00 [September 9 04:15:24 UTC]
[04:15:24] + Working ...
[04:15:24]
[04:15:24] *------------------------------*
[04:15:24] Folding@Home GPU Core - Beta
[04:15:24] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[04:15:24]
[04:15:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:15:24] Build host: amoeba
[04:15:24] Board Type: Nvidia
[04:15:24] Core      :
[04:15:24] Preparing to commence simulation
[04:15:24] - Looking at optimizations...
[04:15:24] - Created dyn
[04:15:24] - Files status OK
[04:15:24] - Expanded 84750 -> 447228 (decompressed 527.7 percent)
[04:15:24] Called DecompressByteArray: compressed_data_size=84750 data_size=447228, decompressed_data_size=447228 diff=0
[04:15:24] - Digital signature verified
[04:15:24]
[04:15:24] Project: 5508 (Run 5, Clone 155, Gen 0)
[04:15:24]
[04:15:24] Assembly optimizations on if available.
[04:15:24] Entering M.D.
[04:15:31] Working on p5508_lam5w_300K_g91
[04:15:33] Client config found, loading data.
[04:15:33] Starting GUI Server
[04:17:34] Completed 1%
[04:19:35] Completed 2%
[04:21:36] Completed 3%
[04:23:37] Completed 4%
[04:25:37] Completed 5%
[04:27:38] Completed 6%
[04:29:39] Completed 7%
[04:31:40] Completed 8%
[04:33:41] Completed 9%
[04:35:42] Completed 10%
[04:37:43] Completed 11%
[04:39:43] Completed 12%
[04:41:44] Completed 13%
[04:43:45] Completed 14%
[04:45:46] Completed 15%
[04:47:47] Completed 16%
[04:49:48] Completed 17%
[04:51:48] Completed 18%
[04:53:49] Completed 19%
[04:55:50] Completed 20%
[04:57:51] Completed 21%
[04:59:52] Completed 22%
[05:01:53] Completed 23%
[05:03:54] Completed 24%
[05:05:55] Completed 25%
[05:07:56] Completed 26%
[05:09:38] + Working...
[05:09:57] Completed 27%
[05:11:58] Completed 28%
[05:13:59] Completed 29%
[05:15:59] Completed 30%
[05:18:00] Completed 31%
[05:20:01] Completed 32%
[05:22:02] Completed 33%
[05:24:03] Completed 34%
[05:26:04] Completed 35%
[05:28:04] Completed 36%
[05:30:05] Completed 37%
[05:32:06] Completed 38%
[05:34:07] Completed 39%
[05:36:08] Completed 40%
[05:38:09] Completed 41%
[05:40:09] Completed 42%
[05:42:10] Completed 43%
[05:44:11] Completed 44%
[05:46:12] Completed 45%
[05:48:13] Completed 46%
[05:50:14] Completed 47%
[05:52:15] Completed 48%
[05:54:16] Completed 49%
[05:56:16] Completed 50%
[05:58:17] Completed 51%
[06:00:19] Completed 52%
[06:02:20] Completed 53%
[06:04:20] Completed 54%
[06:06:21] Completed 55%
[06:08:22] Completed 56%
[06:10:23] Completed 57%
[06:12:24] Completed 58%
[06:14:25] Completed 59%
[06:16:26] Completed 60%
[06:18:27] Completed 61%
[06:20:27] Completed 62%
[06:22:28] Completed 63%
[06:24:29] Completed 64%
[06:26:30] Completed 65%
[06:28:31] Completed 66%
[06:30:32] Completed 67%
[06:32:32] Completed 68%
[06:34:33] Completed 69%
[06:36:34] Completed 70%
[06:38:35] Completed 71%
[06:40:36] Completed 72%
[06:42:37] Completed 73%
[06:44:38] Completed 74%
[06:46:39] Completed 75%
[06:48:39] Completed 76%
[06:50:40] Completed 77%
[06:52:41] Completed 78%
[06:54:42] Completed 79%
[06:56:43] Completed 80%
[06:58:44] Completed 81%
[07:00:45] Completed 82%
[07:02:46] Completed 83%
[07:04:47] Completed 84%
[07:06:48] Completed 85%
[07:08:49] Completed 86%
[07:10:50] Completed 87%
[07:12:50] Completed 88%
[07:14:51] Completed 89%
[07:16:52] Completed 90%
[07:18:53] Completed 91%
[07:20:54] Completed 92%
[07:22:55] Completed 93%
[07:24:56] Completed 94%
[07:26:57] Completed 95%
[07:28:57] Completed 96%
[07:30:58] Completed 97%
[07:32:59] Completed 98%
[07:35:00] Completed 99%
[07:37:01] Completed 100%
[07:38:01]
Re: Project: 5506 (Run 7, Clone 198, Gen 76)
Two people completed this WU successfully. Don't ask me why it has been reissued twice :? ...
