Project: 5019 (Run 5, Clone 15, Gen 3) UM after completion
ThunderRd
Post by ThunderRd »
Same problem that ^w^ing reported here: viewtopic.php?f=19&t=5465
has been reported by a teammate on this WU
[06:29:04] Completed 98%
[06:31:49] Completed 99%
[06:34:34] Completed 100%
[06:35:34]
[06:35:34] Finished Work Unit:
[06:35:34] - Reading up to 30216 from "work/wudata_06.trr": Read 30216
[06:35:34] trr file hash check passed.
[06:35:34] - Reading up to 199240 from "work/wudata_06.xtc": Read 199240
[06:35:34] xtc file hash check passed.
[06:35:34] edr file hash check passed.
[06:35:34] logfile size: 35998
[06:35:34] Gromacs cannot continue further.
[06:35:34] Going to send back what have done.
[06:35:35] logfile size: 35998 info=35998 bed=0 hdr=23
[06:35:35] - Writing 36534 bytes of core data to disk...
[06:35:35] Done: 36022 -> 7214 (compressed to 20.0 percent)
[06:35:35]   ... Done.
[06:35:35]
[06:35:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:35:38] CoreStatus = 7A (122)
[06:35:38] Sending work to server
[06:35:38] Project: 5019 (Run 5, Clone 15, Gen 3)
[06:35:38] + Attempting to send results [September 10 06:35:38 UTC]
[06:35:38] - Reading file work/wuresults_06.dat from core
[06:35:38]   (Read 7726 bytes from disk)
[06:35:38] Connecting to http://171.64.65.20:8080/
[06:35:39] Posted data.
[06:35:39] Initial: 0000; - Uploaded at ~8 kB/s
[06:35:39] - Averaged speed for that direction ~48 kB/s
[06:35:39] + Results successfully sent
[06:35:39] Thank you for your contribution to Folding@Home.
^w^ing
Hardware configuration: C2D E6400 2.13 GHz @ 3.2 GHz
Asus EN8800GTS 640 (G80) @ 660/792/1700 running the 6.23 w/ core11 v1.19
forceware 260.89
Asus P5N-E SLi
2GB 800MHz DDRII (2xCorsair TwinX 512MB)
WinXP 32 SP3
Re: Project: 5019 (Run 5, Clone 15, Gen 3) UM after completion
Post by ^w^ing »
To toTOW or PG, please take a look at what i wrote in my very last post in the mentioned topic. The WU finished succesfully after a third try.
Thanks for pointing that to our attention. This should help to debug the issue.
