Project: 2665 (Run 3, Clone 220, Gen 46)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Long interactions (which is more than I can say for this WU ;-) )
[23:43:34] + Closed connections
[23:43:34]
[23:43:34] + Processing work unit
[23:43:34] Work type a1 not eligible for variable processors
[23:43:34] Core required: FahCore_a1.exe
[23:43:34] Core found.
[23:43:34] Using generic mpiexec calls
[23:43:34] Working on queue slot 07 [September 9 23:43:34 UTC]
[23:43:34] + Working ...
[23:43:34] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 4428 -version 622'
[23:43:34]
[23:43:34] *------------------------------*
[23:43:34] Folding@Home Gromacs SMP Core
[23:43:34] Version 1.74 (March 10, 2007)
[23:43:34]
[23:43:34] Preparing to commence simulation
[23:43:34] - Looking at optimizations...
[23:43:34] - Created dyn
[23:43:34] - Files status OK
[23:43:39] - Expanded 4729698 -> 24426905 (decompressed 516.4 percent)
[23:43:39] - Starting from initial work packet
[23:43:39]
[23:43:39] Project: 2665 (Run 3, Clone 220, Gen 46)
[23:43:39]
[23:43:40] Assembly optimizations on if available.
[23:43:40] Entering M.D.
[23:44:01]  percent)
[23:44:01] - Starting from initial work packet
[23:44:01]
[23:44:01] Project: 2665 (Run 3, Clone 220, Gen 46)
[23:44:01]
[23:44:02] Entering M.D.
[23:44:08] Rejecting checkpoint
[23:44:10] Protein: HGG in water
[23:44:10] Writing local files
[23:44:18] Extra SSE boost OK.
[23:44:19] Writing local files
[23:44:19] Completed 0 out of 250000 steps  (0 percent)
[23:55:21] Warning:  long 1-4 interactions
[23:55:22]  Failed to delete work/wudata_07.bed
[23:55:22] - Failed to delete work/wudata_07.sas
[23:55:22] - Failed to delete work/wudata_07.goe
[23:55:22] Warning:  check for stray files
[23:55:22]
[23:55:22] Folding@home Core Shutdown: EARLY_UNIT_END
[23:55:22] Finalizing output
[02:46:22] CoreStatus = 7B (123)
[02:46:22] Client-core communications error: ERROR 0x7b
[02:46:22] Deleting current work unit & continuing...
[02:46:22] Using generic mpiexec calls
[02:48:26] - Warning: Could not delete all work unit files (7): Core returned invalid code
[02:48:26] Trying to send all finished work units
[02:48:26] + No unsent completed units remaining.
[02:48:26] - Preparing to get new work unit...
[02:48:26] + Attempting to get work packet
Re: Project: 2665 (Run 3, Clone 220, Gen 46)
There's no report in the DB for this WU :(
anko1
Post by anko1 »
I ran qfix b/c on another unit and see that it "fixed" this WU, too, and sent 9957 bytes. Was this worth anything? Also, as a point of interest this one, and the other unit, which I'll post separately, ended in the:
mode. I didn't realize that you could send results when they ended this way.
Edit: as an interesting add on, when it sent, it counted as a completed unit:
--- Opening Log file [September 12 22:01:23 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: C:\SMP\Folding@Home Windows SMP Client V1.01
Executable: C:\SMP\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe
Arguments: -verbosity 9 -smp
[22:01:23] - Ask before connecting: No
[22:01:23] - User name: anko1 (Team 47815)
[22:01:23] - User ID: 6E38A8D328AF4A1B
[22:01:23] - Machine ID: 1
[22:01:23]
[22:01:23] Loaded queue successfully.
[22:01:23]
[22:01:23] - Autosending finished units... [September 12 22:01:23 UTC]
[22:01:23] + Processing work unit
[22:01:23] Trying to send all finished work units
[22:01:23] Work type a1 not eligible for variable processors
[22:01:23] Project: 2665 (Run 3, Clone 220, Gen 46)
[22:01:23] Core required: FahCore_a1.exe
[22:01:23] Core found.
[22:01:23] + Attempting to send results [September 12 22:01:23 UTC]
[22:01:23] Using generic mpiexec calls
[22:01:23] - Reading file work/wuresults_07.dat from core
[22:01:23]   (Read 9957 bytes from disk)
[22:01:23] Connecting to http://171.64.65.64:8080/
[22:01:23] Working on queue slot 01 [September 12 22:01:23 UTC]
[22:01:23] + Working ...
[22:01:23] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 1352 -version 622'
[22:01:24]
[22:01:24] *------------------------------*
[22:01:24] Folding@Home Gromacs SMP Core
[22:01:24] Version 1.74 (March 10, 2007)
[22:01:24]
[22:01:24] Preparing to commence simulation
[22:01:24] - Ensuring status. Please wait.
[22:01:24] Posted data.
[22:01:24] Initial: 0000; - Uploaded at ~10 kB/s
[22:01:24] - Averaged speed for that direction ~42 kB/s
[22:01:24] + Results successfully sent
[22:01:24] Thank you for your contribution to Folding@Home.
[22:01:24] + Number of Units Completed: 26
ElectricVehicle
Post by ElectricVehicle »
I got the same thing with this WU Project: 2665 (Run 3, Clone 220, Gen 46) . Just hung for hours at 0%. I qfix'd and it sent something back to the servers.
[12:26:45] Completed 0 out of 250000 steps (0 percent)
[12:42:03] d to delete work/wudata_05.xtc
[12:42:03] - Failed to delete work/wudata_05.bed
[12:42:03] - Failed to delete work/wudata_05.sas
[12:42:03] - Failed to delete work/wudata_05.goe
[12:42:03] Warning: check for stray files
[12:42:03]
[12:42:03] Folding@home Core Shutdown: EARLY_UNIT_END
--- Opening Log file [September 30 09:34:16 UTC]
Launch directory: C:\FahSmp2ndClient
Executable: C:\FahSmp2ndClient\Folding@home-Win32-x86.exe
Arguments: -smp -verbosity 9
[09:34:16] - Ask before connecting: No
[09:34:16] - User name: [EV]Solar (Team 104636)
[09:34:16] - User ID: xxxx
[09:34:16] - Machine ID: 3
[12:25:35] - Preparing to get new work unit...
[12:25:35] + Attempting to get work packet
[12:25:35] - Will indicate memory of 2046 MB
[12:25:35] - Connecting to assignment server
[12:25:35] Connecting to http://assign.stanford.edu:8080/
[12:25:35] Posted data.
[12:25:35] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[12:25:35] + News From Folding@Home: Welcome to Folding@Home
[12:25:35] Loaded queue successfully.
[12:25:35] Connecting to http://171.64.65.64:8080/
[12:25:41] Posted data.
[12:25:41] Initial: 0000; - Receiving payload (expected size: 4730210)
[12:25:48] - Downloaded at ~659 kB/s
[12:25:48] - Averaged speed for that direction ~614 kB/s
[12:25:48] + Received work.
[12:25:48] Trying to send all finished work units
[12:25:48] + No unsent completed units remaining.
[12:25:48] + Closed connections
[12:25:48]
[12:25:48] + Processing work unit
[12:25:48] Work type a1 not eligible for variable processors
[12:25:48] Core required: FahCore_a1.exe
[12:25:48] Core found.
[12:25:48] Using generic mpiexec calls
[12:25:48] Working on queue slot 05 [October 2 12:25:48 UTC]
[12:25:48] + Working ...
[12:25:48] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 05 -checkpoint 30 -verbose -lifeline 5660 -version 622'
[12:25:48]
[12:25:48] *------------------------------*
[12:25:48] Folding@Home Gromacs SMP Core
[12:25:48] Version 1.74 (March 10, 2007)
[12:25:48]
[12:25:48] Preparing to commence simulation
[12:25:48] - Ensuring status. Please wait.
[12:25:55] - Starting from initial work packet
[12:25:55]
[12:25:55] Project: 2665 (Run 3, Clone 220, Gen 46)
[12:25:55]
[12:25:55] Assembly optimizations on if available.
[12:25:55] Entering M.D.
[12:26:14]  percent)
[12:26:14] - Starting from initial work packet
[12:26:14]
[12:26:14] Project: 2665 (Run 3, Clone 220, Gen 46)
[12:26:14]
[12:26:15] Entering M.D.
[12:26:31] Warning:  cannot record process ID
[12:26:31] Rejecting checkpoint
[12:26:33]
[12:26:33] Writing local files
[12:26:33]
[12:26:44] Extra SSE boost OK.
[12:26:45] Writing local files
[12:42:03]
[12:42:03] Finalizing output
[15:33:46] - Autosending finished units... [October 2 15:33:46 UTC]
[15:33:46] Trying to send all finished work units
[15:33:46] + No unsent completed units remaining.
[15:33:46] - Autosend completed
[15:55:22] Killing all core threads
[15:55:22] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
[15:55:22] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
Fold On! (with 100% Renewable, 0 Carbon electricity) ElectricVehicle EV1, RAV4 EV, LEAF, Bolt EV, Volt, M3, s4 Simulator
anko1
Post by anko1 »
I see you're using Beta2r3 also. Bummer that it hung. I wonder why my client just moved on. The two differences I see are that my client recorded long 1-4 interactions and yours didn't. Also, you had an autosend when my client was just ending up. I've noticed with the GPU client that the two times I had an expired unit during autosend, I got a Special Exit, so maybe if autosend happens at the wrong time, issues happen.
