Projects 551x - Multiple EUEs
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Is this a bad WU?
[23:15:22] + Closed connections
[23:15:22]
[23:15:22] + Processing work unit
[23:15:22] Core required: FahCore_11.exe
[23:15:22] Core found.
[23:15:22] Working on queue slot 04 [September 8 23:15:22 UTC]
[23:15:22] + Working ...
[23:15:22] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[23:15:22]
[23:15:22] *------------------------------*
[23:15:22] Folding@Home GPU Core - Beta
[23:15:22] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[23:15:22]
[23:15:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:15:22] Build host: amoeba
[23:15:22] Board Type: Nvidia
[23:15:22] Core      :
[23:15:22] Preparing to commence simulation
[23:15:22] - Looking at optimizations...
[23:15:22] - Created dyn
[23:15:22] - Files status OK
[23:15:22] - Expanded 84718 -> 447228 (decompressed 527.9 percent)
[23:15:22] Called DecompressByteArray: compressed_data_size=84718 data_size=447228, decompressed_data_size=447228 diff=0
[23:15:22] - Digital signature verified
[23:15:22]
[23:15:22] Project: 5512 (Run 9, Clone 27, Gen 0)
[23:15:22]
[23:15:22] Assembly optimizations on if available.
[23:15:22] Entering M.D.
[23:15:29] Working on p5512_lam5w_330K_g1
[23:15:31] Client config found, loading data.
[23:15:31] Starting GUI Server
[23:15:31] mdrun_gpu returned -1
[23:15:31] Going to send back what have done.
[23:15:32] logfile size: 11113 info=11113 bed=0 hdr=25
[23:15:32] - Writing 11651 bytes of core data to disk...
[23:15:32] Done: 11139 -> 4047 (compressed to 36.3 percent)
[23:15:32]   ... Done.
[23:15:32]
[23:15:32] Folding@home Core Shutdown: EARLY_UNIT_END
[23:15:35] CoreStatus = 72 (114)
[23:15:35] Sending work to server
[23:15:35] Project: 5512 (Run 9, Clone 27, Gen 0)
[23:15:35] - Read packet limit of 540015616... Set to 524286976.
[23:15:35] + Attempting to send results [September 8 23:15:35 UTC]
[23:15:35] - Reading file work/wuresults_04.dat from core
[23:15:35]   (Read 4559 bytes from disk)
[23:15:35] Connecting to http://171.64.65.106:8080/
[23:15:35] Posted data.
[23:15:35] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[23:15:35] - Uploaded at ~10 kB/s
[23:15:35] - Averaged speed for that direction ~45 kB/s
[23:15:35] + Results successfully sent
[23:15:35] Thank you for your contribution to Folding@Home.
Reason: Merged posts and edit title
anko1
Project: 5512 (Run 8, Clone 50, Gen 0)
Post by anko1 »
Maybe the 5512s don't like me? or am I doing something wrong? 5506s are my friends. ;-)
[04:45:44] + Closed connections
[04:45:44]
[04:45:44] + Processing work unit
[04:45:44] Core required: FahCore_11.exe
[04:45:44] Core found.
[04:45:44] Working on queue slot 07 [September 9 04:45:44 UTC]
[04:45:44] + Working ...
[04:45:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[04:45:44]
[04:45:44] *------------------------------*
[04:45:44] Folding@Home GPU Core - Beta
[04:45:44] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[04:45:44]
[04:45:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:45:44] Build host: amoeba
[04:45:44] Board Type: Nvidia
[04:45:44] Core      :
[04:45:44] Preparing to commence simulation
[04:45:44] - Looking at optimizations...
[04:45:44] - Created dyn
[04:45:44] - Files status OK
[04:45:44] - Expanded 84711 -> 447228 (decompressed 527.9 percent)
[04:45:44] Called DecompressByteArray: compressed_data_size=84711 data_size=447228, decompressed_data_size=447228 diff=0
[04:45:44] - Digital signature verified
[04:45:44]
[04:45:44] Project: 5512 (Run 8, Clone 50, Gen 0)
[04:45:44]
[04:45:44] Assembly optimizations on if available.
[04:45:44] Entering M.D.
[04:45:50] Working on p5512_lam5w_330K_g1
[04:45:52] Client config found, loading data.
[04:45:52] Starting GUI Server
[04:45:52] mdrun_gpu returned -1
[04:45:52] Going to send back what have done.
[04:45:53] logfile size: 11113 info=11113 bed=0 hdr=25
[04:45:53] - Writing 11651 bytes of core data to disk...
[04:45:53] Done: 11139 -> 4046 (compressed to 36.3 percent)
[04:45:53]   ... Done.
[04:45:53]
[04:45:53] Folding@home Core Shutdown: EARLY_UNIT_END
[04:45:56] CoreStatus = 72 (114)
[04:45:56] Sending work to server
[04:45:56] Project: 5512 (Run 8, Clone 50, Gen 0)
[04:45:56] - Read packet limit of 540015616... Set to 524286976.
[04:45:56] + Attempting to send results [September 9 04:45:56 UTC]
[04:45:56] - Reading file work/wuresults_07.dat from core
[04:45:56]   (Read 4558 bytes from disk)
[04:45:56] Connecting to http://171.64.65.106:8080/
[04:45:56] Posted data.
[04:45:56] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[04:45:56] - Uploaded at ~10 kB/s
[04:45:56] - Averaged speed for that direction ~41 kB/s
[04:45:56] + Results successfully sent
[04:45:56] Thank you for your contribution to Folding@Home.
anko1
Project: 5511 (Run 2, Clone 81, Gen 0)
Post by anko1 »
Well, if I hadn't completed several others (including a different Gen 0), I'd be getting paranoid.
[13:14:11] + Closed connections
[13:14:11]
[13:14:11] + Processing work unit
[13:14:11] Core required: FahCore_11.exe
[13:14:11] Core found.
[13:14:11] Working on queue slot 02 [September 9 13:14:11 UTC]
[13:14:11] + Working ...
[13:14:11] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[13:14:12]
[13:14:12] *------------------------------*
[13:14:12] Folding@Home GPU Core - Beta
[13:14:12] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:14:12]
[13:14:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:14:12] Build host: amoeba
[13:14:12] Board Type: Nvidia
[13:14:12] Core      :
[13:14:12] Preparing to commence simulation
[13:14:12] - Looking at optimizations...
[13:14:12] - Created dyn
[13:14:12] - Files status OK
[13:14:12] - Expanded 84717 -> 447228 (decompressed 527.9 percent)
[13:14:12] Called DecompressByteArray: compressed_data_size=84717 data_size=447228, decompressed_data_size=447228 diff=0
[13:14:12] - Digital signature verified
[13:14:12]
[13:14:12] Project: 5511 (Run 2, Clone 81, Gen 0)
[13:14:12]
[13:14:12] Assembly optimizations on if available.
[13:14:12] Entering M.D.
[13:14:18] Working on p5511_lam5w_300K_g1
[13:14:20] Client config found, loading data.
[13:14:20] Starting GUI Server
[13:14:20] mdrun_gpu returned -1
[13:14:20] Going to send back what have done.
[13:14:21] logfile size: 11112 info=11112 bed=0 hdr=25
[13:14:21] - Writing 11650 bytes of core data to disk...
[13:14:21] Done: 11138 -> 4067 (compressed to 36.5 percent)
[13:14:21]   ... Done.
[13:14:21]
[13:14:21] Folding@home Core Shutdown: EARLY_UNIT_END
[13:14:24] CoreStatus = 72 (114)
[13:14:24] Sending work to server
[13:14:24] Project: 5511 (Run 2, Clone 81, Gen 0)
[13:14:24] - Read packet limit of 540015616... Set to 524286976.
[13:14:24] + Attempting to send results [September 9 13:14:24 UTC]
[13:14:24] - Reading file work/wuresults_02.dat from core
[13:14:24]   (Read 4579 bytes from disk)
[13:14:24] Connecting to http://171.64.65.106:8080/
[13:14:24] Posted data.
[13:14:24] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[13:14:24] - Uploaded at ~10 kB/s
[13:14:24] - Averaged speed for that direction ~31 kB/s
[13:14:24] + Results successfully sent
[13:14:24] Thank you for your contribution to Folding@Home.
anko1
Project: 5513 (Run 7, Clone 92, Gen 0)
Post by anko1 »
OK, I'm getting paranoid anyway!!!
[15:58:58] + Closed connections
[15:58:58]
[15:58:58] + Processing work unit
[15:58:58] Core required: FahCore_11.exe
[15:58:58] Core found.
[15:58:58] Working on queue slot 04 [September 9 15:58:58 UTC]
[15:58:58] + Working ...
[15:58:58] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[15:58:58]
[15:58:58] *------------------------------*
[15:58:58] Folding@Home GPU Core - Beta
[15:58:58] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[15:58:58]
[15:58:58] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:58:58] Build host: amoeba
[15:58:58] Board Type: Nvidia
[15:58:58] Core      :
[15:58:58] Preparing to commence simulation
[15:58:58] - Looking at optimizations...
[15:58:58] - Created dyn
[15:58:58] - Files status OK
[15:58:58] - Expanded 84650 -> 447224 (decompressed 528.3 percent)
[15:58:58] Called DecompressByteArray: compressed_data_size=84650 data_size=447224, decompressed_data_size=447224 diff=0
[15:58:58] - Digital signature verified
[15:58:58]
[15:58:58] Project: 5513 (Run 7, Clone 92, Gen 0)
[15:58:58]
[15:58:58] Assembly optimizations on if available.
[15:58:58] Entering M.D.
[15:59:05] Working on p5513_lam5w_300K
[15:59:07] Client config found, loading data.
[15:59:07] Starting GUI Server
[15:59:07] mdrun_gpu returned -1
[15:59:07] Going to send back what have done.
[15:59:08] logfile size: 11110 info=11110 bed=0 hdr=25
[15:59:08] - Writing 11648 bytes of core data to disk...
[15:59:08] Done: 11136 -> 4055 (compressed to 36.4 percent)
[15:59:08]   ... Done.
[15:59:08]
[15:59:08] Folding@home Core Shutdown: EARLY_UNIT_END
[15:59:10] CoreStatus = 72 (114)
[15:59:10] Sending work to server
[15:59:10] Project: 5513 (Run 7, Clone 92, Gen 0)
[15:59:10] - Read packet limit of 540015616... Set to 524286976.
[15:59:10] + Attempting to send results [September 9 15:59:10 UTC]
[15:59:10] - Reading file work/wuresults_04.dat from core
[15:59:10]   (Read 4567 bytes from disk)
[15:59:10] Connecting to http://171.64.65.106:8080/
[15:59:11] Posted data.
[15:59:11] Initial: 0000; - Uploaded at ~5 kB/s
[15:59:11] - Averaged speed for that direction ~29 kB/s
[15:59:11] + Results successfully sent
[15:59:11] Thank you for your contribution to Folding@Home.
anko1
Project: 5512 (Run 2, Clone 97, Gen 0)
Post by anko1 »
Am I setting some sort of record? Fortunately, I complete a 5508 right after this, so at least something's working.
[15:59:16] + Closed connections
[15:59:21]
[15:59:21] + Processing work unit
[15:59:21] Core required: FahCore_11.exe
[15:59:21] Core found.
[15:59:21] Working on queue slot 05 [September 9 15:59:21 UTC]
[15:59:21] + Working ...
[15:59:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[15:59:21]
[15:59:21] *------------------------------*
[15:59:21] Folding@Home GPU Core - Beta
[15:59:21] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[15:59:21]
[15:59:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:59:21] Build host: amoeba
[15:59:21] Board Type: Nvidia
[15:59:21] Core      :
[15:59:21] Preparing to commence simulation
[15:59:21] - Looking at optimizations...
[15:59:21] - Created dyn
[15:59:21] - Files status OK
[15:59:21] - Expanded 84618 -> 447228 (decompressed 528.5 percent)
[15:59:21] Called DecompressByteArray: compressed_data_size=84618 data_size=447228, decompressed_data_size=447228 diff=0
[15:59:21] - Digital signature verified
[15:59:21]
[15:59:21] Project: 5512 (Run 2, Clone 97, Gen 0)
[15:59:21]
[15:59:21] Assembly optimizations on if available.
[15:59:21] Entering M.D.
[15:59:27] Working on p5512_lam5w_330K_g1
[15:59:29] Client config found, loading data.
[15:59:29] Starting GUI Server
[15:59:29] mdrun_gpu returned -1
[15:59:29] Going to send back what have done.
[15:59:30] logfile size: 5576 info=5576 bed=0 hdr=25
[15:59:30] - Writing 6114 bytes of core data to disk...
[15:59:30] Done: 5602 -> 2016 (compressed to 35.9 percent)
[15:59:30]   ... Done.
[15:59:30]
[15:59:30] Folding@home Core Shutdown: EARLY_UNIT_END
[15:59:33] CoreStatus = 72 (114)
[15:59:33] Sending work to server
[15:59:33] Project: 5512 (Run 2, Clone 97, Gen 0)
[15:59:33] - Read packet limit of 540015616... Set to 524286976.
[15:59:33] + Attempting to send results [September 9 15:59:33 UTC]
[15:59:33] - Reading file work/wuresults_05.dat from core
[15:59:33]   (Read 2528 bytes from disk)
[15:59:33] Connecting to http://171.64.65.106:8080/
[15:59:33] Posted data.
[15:59:33] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[15:59:33] - Uploaded at ~6 kB/s
[15:59:33] - Averaged speed for that direction ~27 kB/s
[15:59:33] + Results successfully sent
[15:59:33] Thank you for your contribution to Folding@Home.
anko1
Project: 5511 (Run 8, Clone 51, Gen 0)
Post by anko1 »
??? [Actually, missed this one first time through the log.]
[10:28:04] + Closed connections
[10:28:04]
[10:28:04] + Processing work unit
[10:28:04] Core required: FahCore_11.exe
[10:28:04] Core found.
[10:28:04] Working on queue slot 00 [September 9 10:28:04 UTC]
[10:28:04] + Working ...
[10:28:04] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[10:28:05]
[10:28:05] *------------------------------*
[10:28:05] Folding@Home GPU Core - Beta
[10:28:05] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[10:28:05]
[10:28:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:28:05] Build host: amoeba
[10:28:05] Board Type: Nvidia
[10:28:05] Core      :
[10:28:05] Preparing to commence simulation
[10:28:05] - Looking at optimizations...
[10:28:05] - Created dyn
[10:28:05] - Files status OK
[10:28:05] - Expanded 84785 -> 447228 (decompressed 527.4 percent)
[10:28:05] Called DecompressByteArray: compressed_data_size=84785 data_size=447228, decompressed_data_size=447228 diff=0
[10:28:05] - Digital signature verified
[10:28:05]
[10:28:05] Project: 5511 (Run 8, Clone 51, Gen 0)
[10:28:05]
[10:28:05] Assembly optimizations on if available.
[10:28:05] Entering M.D.
[10:28:11] Working on p5511_lam5w_300K_g1
[10:28:13] Client config found, loading data.
[10:28:13] Starting GUI Server
[10:28:13] mdrun_gpu returned -1
[10:28:13] Going to send back what have done.
[10:28:14] logfile size: 10637 info=10637 bed=0 hdr=25
[10:28:14] - Writing 11175 bytes of core data to disk...
[10:28:14] Done: 10663 -> 3861 (compressed to 36.2 percent)
[10:28:14]   ... Done.
[10:28:14]
[10:28:14] Folding@home Core Shutdown: EARLY_UNIT_END
[10:28:17] CoreStatus = 72 (114)
[10:28:17] Sending work to server
[10:28:17] Project: 5511 (Run 8, Clone 51, Gen 0)
[10:28:17] - Read packet limit of 540015616... Set to 524286976.
[10:28:17] + Attempting to send results [September 9 10:28:17 UTC]
[10:28:17] - Reading file work/wuresults_00.dat from core
[10:28:17]   (Read 4373 bytes from disk)
[10:28:17] Connecting to http://171.64.65.106:8080/
[10:28:20] Posted data.
[10:28:20] Initial: 0000; - Uploaded at ~1 kB/s
[10:28:20] - Averaged speed for that direction ~34 kB/s
[10:28:20] + Results successfully sent
[10:28:20] Thank you for your contribution to Folding@Home.
anko1
Project: 5512 (Run 6, Clone 133, Gen 0)
Post by anko1 »
What can I say? At least I got two in row done before this.
[21:40:35] + Closed connections
[21:40:35]
[21:40:35] + Processing work unit
[21:40:35] Core required: FahCore_11.exe
[21:40:35] Core found.
[21:40:35] Working on queue slot 08 [September 9 21:40:35 UTC]
[21:40:35] + Working ...
[21:40:35] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[21:40:36]
[21:40:36] *------------------------------*
[21:40:36] Folding@Home GPU Core - Beta
[21:40:36] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[21:40:36]
[21:40:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:40:36] Build host: amoeba
[21:40:36] Board Type: Nvidia
[21:40:36] Core      :
[21:40:36] Preparing to commence simulation
[21:40:36] - Looking at optimizations...
[21:40:36] - Created dyn
[21:40:36] - Files status OK
[21:40:36] - Expanded 84678 -> 447228 (decompressed 528.1 percent)
[21:40:36] Called DecompressByteArray: compressed_data_size=84678 data_size=447228, decompressed_data_size=447228 diff=0
[21:40:36] - Digital signature verified
[21:40:36]
[21:40:36] Project: 5512 (Run 6, Clone 133, Gen 0)
[21:40:36]
[21:40:36] Assembly optimizations on if available.
[21:40:36] Entering M.D.
[21:40:42] Working on p5512_lam5w_330K_g1
[21:40:44] Client config found, loading data.
[21:40:44] Starting GUI Server
[21:40:44] mdrun_gpu returned -1
[21:40:44] Going to send back what have done.
[21:40:45] logfile size: 11113 info=11113 bed=0 hdr=25
[21:40:45] - Writing 11651 bytes of core data to disk...
[21:40:45] Done: 11139 -> 4052 (compressed to 36.3 percent)
[21:40:45]   ... Done.
[21:40:45]
[21:40:45] Folding@home Core Shutdown: EARLY_UNIT_END
[21:40:48] CoreStatus = 72 (114)
[21:40:48] Sending work to server
[21:40:48] Project: 5512 (Run 6, Clone 133, Gen 0)
[21:40:48] - Read packet limit of 540015616... Set to 524286976.
[21:40:48] + Attempting to send results [September 9 21:40:48 UTC]
[21:40:48] - Reading file work/wuresults_08.dat from core
[21:40:48]   (Read 4564 bytes from disk)
[21:40:48] Connecting to http://171.64.65.106:8080/
[21:40:48] Posted data.
[21:40:48] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[21:40:48] - Uploaded at ~10 kB/s
[21:40:48] - Averaged speed for that direction ~31 kB/s
[21:40:48] + Results successfully sent
[21:40:48] Thank you for your contribution to Folding@Home.
anko1
Project: 5511 (Run 3, Clone 141, Gen 0)
Post by anko1 »
Well, at least I'm almost done with today's log.
[00:15:24] + Closed connections
[00:15:24]
[00:15:24] + Processing work unit
[00:15:24] Core required: FahCore_11.exe
[00:15:24] Core found.
[00:15:24] Working on queue slot 00 [September 10 00:15:24 UTC]
[00:15:24] + Working ...
[00:15:24] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -checkpoint 15 -verbose -lifeline 5608 -version 620'
[00:15:24]
[00:15:24] *------------------------------*
[00:15:24] Folding@Home GPU Core - Beta
[00:15:24] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[00:15:24]
[00:15:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:15:24] Build host: amoeba
[00:15:24] Board Type: Nvidia
[00:15:24] Core      :
[00:15:24] Preparing to commence simulation
[00:15:24] - Looking at optimizations...
[00:15:24] - Created dyn
[00:15:24] - Files status OK
[00:15:24] - Expanded 84669 -> 447228 (decompressed 528.2 percent)
[00:15:24] Called DecompressByteArray: compressed_data_size=84669 data_size=447228, decompressed_data_size=447228 diff=0
[00:15:24] - Digital signature verified
[00:15:24]
[00:15:24] Project: 5511 (Run 3, Clone 141, Gen 0)
[00:15:24]
[00:15:24] Assembly optimizations on if available.
[00:15:24] Entering M.D.
[00:15:31] Working on p5511_lam5w_300K_g1
[00:15:33] Client config found, loading data.
[00:15:33] Starting GUI Server
[00:15:33] mdrun_gpu returned -1
[00:15:33] Going to send back what have done.
[00:15:34] logfile size: 11112 info=11112 bed=0 hdr=25
[00:15:34] - Writing 11650 bytes of core data to disk...
[00:15:34] Done: 11138 -> 4060 (compressed to 36.4 percent)
[00:15:34]   ... Done.
[00:15:34]
[00:15:34] Folding@home Core Shutdown: EARLY_UNIT_END
[00:15:36] CoreStatus = 72 (114)
[00:15:36] Sending work to server
[00:15:36] Project: 5511 (Run 3, Clone 141, Gen 0)
[00:15:36] - Read packet limit of 540015616... Set to 524286976.
[00:15:36] + Attempting to send results [September 10 00:15:36 UTC]
[00:15:36] - Reading file work/wuresults_00.dat from core
[00:15:36]   (Read 4572 bytes from disk)
[00:15:36] Connecting to http://171.64.65.106:8080/
[00:15:36] Posted data.
[00:15:36] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[00:15:36] - Uploaded at ~10 kB/s
[00:15:36] - Averaged speed for that direction ~32 kB/s
[00:15:36] + Results successfully sent
[00:15:36] Thank you for your contribution to Folding@Home.
Edit: here's the start of my log. I've processed lots of units, so I think it's OK, but just in case....
--- Opening Log file [September 7 23:36:25 UTC]
                       Folding@Home Client Version 6.20r1
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Angela Nomellini\Desktop\Folding@home-Win32-GPU_XP-620
Executable: C:\Documents and Settings\Angela Nomellini\Desktop\Folding@home-Win32-GPU_XP-620\Folding@home-Win32-GPU.exe
Arguments: -verbosity 9
[23:36:25] - Ask before connecting: No
[23:36:25] - User name: anko1 (Team 47815)
[23:36:25] - User ID: 6E38A8D328AF4A1B
[23:36:25] - Machine ID: 2
[23:36:25]
[23:36:26] Loaded queue successfully.
Re: Project: 5512 (Run 2, Clone 97, Gen 0)
When getting a lot of EUEs, please list the WUs in a single post. Thanks.
anko1
Re: Projects 551x - Multiple EUEs
Post by anko1 »
Ohhh, but I was trying to up my post count. ;-) Sure thing, though I hope there's not a next time. :-)
I've randomly taken a WU in your list ... the winner is : Project: 5511 (Run 3, Clone 141, Gen 0) ... all reports are immediate failures, so these are BadWU, unfortunately :(
anko1
Post by anko1 »
I assume Project: 5511 (Run 3, Clone 141, Gen 0) is suitably gratified by the honor. ;-) Thanks for the info, toTOW.
anko1
Post by anko1 »
Here's a few more in case anyone is keeping track: [@7im - is this an OK way to list them? Would it be better to have all WUs listed up front with logs following?]
Project 5512 (Run 9, Clone 357, Gen 0)
[14:41:10] + Closed connections
[14:41:10]
[14:41:10] + Processing work unit
[14:41:10] Core required: FahCore_11.exe
[14:41:10] Core found.
[14:41:10] Working on queue slot 06 [September 10 14:41:10 UTC]
[14:41:10] + Working ...
[14:41:10] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 15 -verbose -lifeline 2308 -version 620'
[14:41:10]
[14:41:10] *------------------------------*
[14:41:10] Folding@Home GPU Core - Beta
[14:41:10] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[14:41:10]
[14:41:10] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:41:10] Build host: amoeba
[14:41:10] Board Type: Nvidia
[14:41:10] Core      :
[14:41:10] Preparing to commence simulation
[14:41:10] - Looking at optimizations...
[14:41:10] - Created dyn
[14:41:10] - Files status OK
[14:41:10] - Expanded 84609 -> 447228 (decompressed 528.5 percent)
[14:41:10] Called DecompressByteArray: compressed_data_size=84609 data_size=447228, decompressed_data_size=447228 diff=0
[14:41:10] - Digital signature verified
[14:41:10]
[14:41:10] Project: 5512 (Run 9, Clone 357, Gen 0)
[14:41:10]
[14:41:10] Assembly optimizations on if available.
[14:41:10] Entering M.D.
[14:41:16] Working on p5512_lam5w_330K_g1
[14:41:18] Client config found, loading data.
[14:41:18] Starting GUI Server
[14:41:18] mdrun_gpu returned -1
[14:41:18] Going to send back what have done.
[14:41:19] logfile size: 11113 info=11113 bed=0 hdr=25
[14:41:19] - Writing 11651 bytes of core data to disk...
[14:41:19] Done: 11139 -> 4053 (compressed to 36.3 percent)
[14:41:19]   ... Done.
[14:41:19]
[14:41:19] Folding@home Core Shutdown: EARLY_UNIT_END
[14:41:22] CoreStatus = 72 (114)
[14:41:22] Sending work to server
[14:41:22] Project: 5512 (Run 9, Clone 357, Gen 0)
[14:41:22] - Read packet limit of 540015616... Set to 524286976.
[14:41:22] + Attempting to send results [September 10 14:41:22 UTC]
[14:41:22] - Reading file work/wuresults_06.dat from core
[14:41:22]   (Read 4565 bytes from disk)
[14:41:22] Connecting to http://171.64.65.106:8080/
[14:41:22] Posted data.
[14:41:22] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[14:41:22] - Uploaded at ~10 kB/s
[14:41:22] - Averaged speed for that direction ~40 kB/s
[14:41:22] + Results successfully sent
[14:41:22] Thank you for your contribution to Folding@Home.
Project: 5512 (Run 6, Clone 371, Gen 0)
[14:41:27] + Closed connections
[14:41:32]
[14:41:32] + Processing work unit
[14:41:32] Core required: FahCore_11.exe
[14:41:32] Core found.
[14:41:32] Working on queue slot 07 [September 10 14:41:32 UTC]
[14:41:32] + Working ...
[14:41:32] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 15 -verbose -lifeline 2308 -version 620'
[14:41:32]
[14:41:32] *------------------------------*
[14:41:32] Folding@Home GPU Core - Beta
[14:41:32] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[14:41:32]
[14:41:32] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:41:32] Build host: amoeba
[14:41:32] Board Type: Nvidia
[14:41:32] Core      :
[14:41:32] Preparing to commence simulation
[14:41:32] - Looking at optimizations...
[14:41:32] - Created dyn
[14:41:32] - Files status OK
[14:41:32] - Expanded 84650 -> 447228 (decompressed 528.3 percent)
[14:41:32] Called DecompressByteArray: compressed_data_size=84650 data_size=447228, decompressed_data_size=447228 diff=0
[14:41:32] - Digital signature verified
[14:41:32]
[14:41:32] Project: 5512 (Run 6, Clone 371, Gen 0)
[14:41:32]
[14:41:32] Assembly optimizations on if available.
[14:41:32] Entering M.D.
[14:41:39] Working on p5512_lam5w_330K_g1
[14:41:41] Client config found, loading data.
[14:41:41] Starting GUI Server
[14:41:41] mdrun_gpu returned -1
[14:41:41] Going to send back what have done.
[14:41:42] logfile size: 10637 info=10637 bed=0 hdr=25
[14:41:42] - Writing 11175 bytes of core data to disk...
[14:41:42] Done: 10663 -> 3872 (compressed to 36.3 percent)
[14:41:42]   ... Done.
[14:41:42]
[14:41:42] Folding@home Core Shutdown: EARLY_UNIT_END
[14:41:45] CoreStatus = 72 (114)
[14:41:45] Sending work to server
[14:41:45] Project: 5512 (Run 6, Clone 371, Gen 0)
[14:41:45] - Read packet limit of 540015616... Set to 524286976.
[14:41:45] + Attempting to send results [September 10 14:41:45 UTC]
[14:41:45] - Reading file work/wuresults_07.dat from core
[14:41:45]   (Read 4384 bytes from disk)
[14:41:45] Connecting to http://171.64.65.106:8080/
[14:41:45] Posted data.
[14:41:45] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[14:41:45] - Uploaded at ~10 kB/s
[14:41:45] - Averaged speed for that direction ~37 kB/s
[14:41:45] + Results successfully sent
[14:41:45] Thank you for your contribution to Folding@Home.
Project: 5512 (Run 9, Clone 1, Gen 0)
[04:20:07] + Closed connections
[04:20:07]
[04:20:07] + Processing work unit
[04:20:07] Core required: FahCore_11.exe
[04:20:07] Core found.
[04:20:07] Working on queue slot 03 [September 11 04:20:07 UTC]
[04:20:07] + Working ...
[04:20:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 15 -verbose -lifeline 2308 -version 620'
[04:20:07]
[04:20:07] *------------------------------*
[04:20:07] Folding@Home GPU Core - Beta
[04:20:07] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[04:20:07]
[04:20:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:20:07] Build host: amoeba
[04:20:07] Board Type: Nvidia
[04:20:07] Core      :
[04:20:07] Preparing to commence simulation
[04:20:07] - Looking at optimizations...
[04:20:07] - Created dyn
[04:20:07] - Files status OK
[04:20:07] - Expanded 84768 -> 447228 (decompressed 527.5 percent)
[04:20:07] Called DecompressByteArray: compressed_data_size=84768 data_size=447228, decompressed_data_size=447228 diff=0
[04:20:07] - Digital signature verified
[04:20:07]
[04:20:07] Project: 5512 (Run 9, Clone 1, Gen 0)
[04:20:07]
[04:20:07] Assembly optimizations on if available.
[04:20:07] Entering M.D.
[04:20:13] Working on p5512_lam5w_330K_g1
[04:20:15] Client config found, loading data.
[04:20:15] Starting GUI Server
[04:20:15] mdrun_gpu returned -1
[04:20:15] Going to send back what have done.
[04:20:16] logfile size: 11112 info=11112 bed=0 hdr=25
[04:20:16] - Writing 11650 bytes of core data to disk...
[04:20:16] Done: 11138 -> 4049 (compressed to 36.3 percent)
[04:20:16]   ... Done.
[04:20:16]
[04:20:16] Folding@home Core Shutdown: EARLY_UNIT_END
[04:20:19] CoreStatus = 72 (114)
[04:20:19] Sending work to server
[04:20:19] Project: 5512 (Run 9, Clone 1, Gen 0)
[04:20:19] - Read packet limit of 540015616... Set to 524286976.
[04:20:19] + Attempting to send results [September 11 04:20:19 UTC]
[04:20:19] - Reading file work/wuresults_03.dat from core
[04:20:19]   (Read 4561 bytes from disk)
[04:20:19] Connecting to http://171.64.65.106:8080/
[04:20:19] Posted data.
[04:20:19] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[04:20:19] - Uploaded at ~10 kB/s
[04:20:19] - Averaged speed for that direction ~44 kB/s
[04:20:19] + Results successfully sent
[04:20:19] Thank you for your contribution to Folding@Home.
Pette Broad
Hardware configuration: CPU folding on only one machine a laptop
GPU Hardware..
3 x 460
1 X 260
4 X 250
+ 1 X 9800GT (3 days a week)
Post by Pette Broad »
Yes, a load of them here too, one after the other. 550X are running fine by the looks of it.
[13:00:59] Folding@home Core Shutdown: FINISHED_UNIT
[13:01:02] CoreStatus = 64 (100)
[13:01:02] Sending work to server
[13:01:02] Project: 5504 (Run 0, Clone 916, Gen 41)
[13:01:02] + Attempting to send results [September 11 13:01:02 UTC]
[13:01:27] + Results successfully sent
[13:01:27] Thank you for your contribution to Folding@Home.
[13:01:27] + Number of Units Completed: 26
[13:01:32] - Preparing to get new work unit...
[13:01:32] + Attempting to get work packet
[13:01:32] - Connecting to assignment server
[13:01:32] - Successful: assigned to (171.64.65.106).
[13:01:32] + News From Folding@Home: GPU folding beta
[13:01:33] Loaded queue successfully.
[13:01:35] + Closed connections
[13:01:35]
[13:01:35] + Processing work unit
[13:01:35] Core required: FahCore_11.exe
[13:01:35] Core found.
[13:01:35] Working on queue slot 07 [September 11 13:01:35 UTC]
[13:01:35] + Working ...
[13:01:35]
[13:01:35] *------------------------------*
[13:01:35] Folding@Home GPU Core - Beta
[13:01:35] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:01:35]
[13:01:35] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:01:35] Build host: amoeba
[13:01:35] Board Type: Nvidia
[13:01:35] Core      :
[13:01:35] Preparing to commence simulation
[13:01:35] - Looking at optimizations...
[13:01:35] - Created dyn
[13:01:35] - Files status OK
[13:01:35] - Expanded 84689 -> 447228 (decompressed 528.0 percent)
[13:01:35] Called DecompressByteArray: compressed_data_size=84689 data_size=447228, decompressed_data_size=447228 diff=0
[13:01:35] - Digital signature verified
[13:01:35]
[13:01:35] Project: 5511 (Run 6, Clone 129, Gen 0)
[13:01:35]
[13:01:35] Assembly optimizations on if available.
[13:01:35] Entering M.D.
[13:01:41] Working on p5511_lam5w_300K_g1
[13:01:44] Client config found, loading data.
[13:01:44] Starting GUI Server
[13:01:44] mdrun_gpu returned -1
[13:01:44] Going to send back what have done.
[13:01:45] logfile size: 11114 info=11114 bed=0 hdr=25
[13:01:45] - Writing 11652 bytes of core data to disk...
[13:01:45] Done: 11140 -> 4049 (compressed to 36.3 percent)
[13:01:45]   ... Done.
[13:01:45]
[13:01:45] Folding@home Core Shutdown: EARLY_UNIT_END
[13:01:49] CoreStatus = 72 (114)
[13:01:49] Sending work to server
[13:01:49] Project: 5511 (Run 6, Clone 129, Gen 0)
[13:01:49] + Attempting to send results [September 11 13:01:49 UTC]
[13:01:50] + Results successfully sent
[13:01:50] Thank you for your contribution to Folding@Home.
[13:01:54] - Preparing to get new work unit...
[13:01:54] + Attempting to get work packet
[13:01:54] - Connecting to assignment server
[13:01:55] - Successful: assigned to (171.64.65.106).
[13:01:55] + News From Folding@Home: GPU folding beta
[13:01:55] Loaded queue successfully.
[13:01:57] + Closed connections
[13:02:02]
[13:02:02] + Processing work unit
[13:02:02] Core required: FahCore_11.exe
[13:02:02] Core found.
[13:02:02] Working on queue slot 08 [September 11 13:02:02 UTC]
[13:02:02] + Working ...
[13:02:02]
[13:02:02] *------------------------------*
[13:02:02] Folding@Home GPU Core - Beta
[13:02:02] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:02:02]
[13:02:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:02:02] Build host: amoeba
[13:02:02] Board Type: Nvidia
[13:02:02] Core      :
[13:02:02] Preparing to commence simulation
[13:02:02] - Looking at optimizations...
[13:02:02] - Created dyn
[13:02:02] - Files status OK
[13:02:02] - Expanded 84672 -> 447224 (decompressed 528.1 percent)
[13:02:02] Called DecompressByteArray: compressed_data_size=84672 data_size=447224, decompressed_data_size=447224 diff=0
[13:02:02] - Digital signature verified
[13:02:02]
[13:02:02] Project: 5513 (Run 2, Clone 181, Gen 0)
[13:02:02]
[13:02:02] Assembly optimizations on if available.
[13:02:02] Entering M.D.
[13:02:09] Working on p5513_lam5w_300K
[13:02:11] Client config found, loading data.
[13:02:11] Starting GUI Server
[13:02:12] mdrun_gpu returned -1
[13:02:12] Going to send back what have done.
[13:02:13] logfile size: 11108 info=11108 bed=0 hdr=25
[13:02:13] - Writing 11646 bytes of core data to disk...
[13:02:13] Done: 11134 -> 4055 (compressed to 36.4 percent)
[13:02:13]   ... Done.
[13:02:13]
[13:02:13] Folding@home Core Shutdown: EARLY_UNIT_END
[13:02:17] CoreStatus = 72 (114)
[13:02:17] Sending work to server
[13:02:17] Project: 5513 (Run 2, Clone 181, Gen 0)
[13:02:17] + Attempting to send results [September 11 13:02:17 UTC]
[13:02:17] + Results successfully sent
[13:02:17] Thank you for your contribution to Folding@Home.
[13:02:22] - Preparing to get new work unit...
[13:02:22] + Attempting to get work packet
[13:02:22] - Connecting to assignment server
[13:02:22] - Successful: assigned to (171.64.65.106).
[13:02:22] + News From Folding@Home: GPU folding beta
[13:02:22] Loaded queue successfully.
[13:02:25] + Closed connections
[13:02:30]
[13:02:30] + Processing work unit
[13:02:30] Core required: FahCore_11.exe
[13:02:30] Core found.
[13:02:30] Working on queue slot 09 [September 11 13:02:30 UTC]
[13:02:30] + Working ...
[13:02:30]
[13:02:30] *------------------------------*
[13:02:30] Folding@Home GPU Core - Beta
[13:02:30] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:02:30]
[13:02:30] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:02:30] Build host: amoeba
[13:02:30] Board Type: Nvidia
[13:02:30] Core      :
[13:02:30] Preparing to commence simulation
[13:02:30] - Looking at optimizations...
[13:02:30] - Created dyn
[13:02:30] - Files status OK
[13:02:30] - Expanded 84660 -> 447228 (decompressed 528.2 percent)
[13:02:30] Called DecompressByteArray: compressed_data_size=84660 data_size=447228, decompressed_data_size=447228 diff=0
[13:02:30] - Digital signature verified
[13:02:30]
[13:02:30] Project: 5511 (Run 4, Clone 245, Gen 0)
[13:02:30]
[13:02:30] Assembly optimizations on if available.
[13:02:30] Entering M.D.
[13:02:36] Working on p5511_lam5w_300K_g1
[13:02:39] Client config found, loading data.
[13:02:39] Starting GUI Server
[13:02:39] mdrun_gpu returned -1
[13:02:39] Going to send back what have done.
[13:02:40] logfile size: 10635 info=10635 bed=0 hdr=25
[13:02:40] - Writing 11173 bytes of core data to disk...
[13:02:40] Done: 10661 -> 3874 (compressed to 36.3 percent)
[13:02:40]   ... Done.
[13:02:40]
[13:02:40] Folding@home Core Shutdown: EARLY_UNIT_END
[13:02:44] CoreStatus = 72 (114)
[13:02:44] Sending work to server
[13:02:44] Project: 5511 (Run 4, Clone 245, Gen 0)
[13:02:44] + Attempting to send results [September 11 13:02:44 UTC]
[13:02:45] + Results successfully sent
[13:02:45] Thank you for your contribution to Folding@Home.
[13:02:49] - Preparing to get new work unit...
[13:02:49] + Attempting to get work packet
[13:02:49] - Connecting to assignment server
[13:02:50] - Successful: assigned to (171.64.65.106).
[13:02:50] + News From Folding@Home: GPU folding beta
[13:02:50] Loaded queue successfully.
[13:02:52] + Closed connections
[13:02:57]
[13:02:57] + Processing work unit
[13:02:57] Core required: FahCore_11.exe
[13:02:57] Core found.
[13:02:57] Working on queue slot 00 [September 11 13:02:57 UTC]
[13:02:57] + Working ...
[13:02:57]
[13:02:57] *------------------------------*
[13:02:57] Folding@Home GPU Core - Beta
[13:02:57] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:02:57]
[13:02:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:02:57] Build host: amoeba
[13:02:57] Board Type: Nvidia
[13:02:57] Core      :
[13:02:57] Preparing to commence simulation
[13:02:57] - Looking at optimizations...
[13:02:57] - Created dyn
[13:02:57] - Files status OK
[13:02:57] - Expanded 84620 -> 447228 (decompressed 528.5 percent)
[13:02:57] Called DecompressByteArray: compressed_data_size=84620 data_size=447228, decompressed_data_size=447228 diff=0
[13:02:57] - Digital signature verified
[13:02:57]
[13:02:57] Project: 5511 (Run 7, Clone 258, Gen 0)
[13:02:57]
[13:02:57] Assembly optimizations on if available.
[13:02:57] Entering M.D.
[13:03:04] Working on p5511_lam5w_300K_g1
[13:03:06] Client config found, loading data.
[13:03:06] Starting GUI Server
[13:03:06] mdrun_gpu returned -1
[13:03:06] Going to send back what have done.
[13:03:07] logfile size: 11113 info=11113 bed=0 hdr=25
[13:03:07] - Writing 11651 bytes of core data to disk...
[13:03:07] Done: 11139 -> 4052 (compressed to 36.3 percent)
[13:03:07]   ... Done.
[13:03:08]
[13:03:08] Folding@home Core Shutdown: EARLY_UNIT_END
[13:03:11] CoreStatus = 72 (114)
[13:03:11] Sending work to server
[13:03:11] Project: 5511 (Run 7, Clone 258, Gen 0)
[13:03:11] + Attempting to send results [September 11 13:03:11 UTC]
[13:03:12] + Results successfully sent
[13:03:12] Thank you for your contribution to Folding@Home.
[13:03:17] - Preparing to get new work unit...
[13:03:17] + Attempting to get work packet
[13:03:17] - Connecting to assignment server
[13:03:17] - Successful: assigned to (171.64.65.106).
[13:03:17] + News From Folding@Home: GPU folding beta
[13:03:17] Loaded queue successfully.
[13:03:19] + Closed connections
[13:03:24]
[13:03:24] + Processing work unit
[13:03:24] Core required: FahCore_11.exe
[13:03:24] Core found.
[13:03:24] Working on queue slot 01 [September 11 13:03:24 UTC]
[13:03:24] + Working ...
[13:03:24]
[13:03:24] *------------------------------*
[13:03:24] Folding@Home GPU Core - Beta
[13:03:24] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:03:24]
[13:03:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:03:24] Build host: amoeba
[13:03:24] Board Type: Nvidia
[13:03:24] Core      :
[13:03:24] Preparing to commence simulation
[13:03:24] - Looking at optimizations...
[13:03:24] - Created dyn
[13:03:24] - Files status OK
[13:03:24] - Expanded 45302 -> 246249 (decompressed 543.5 percent)
[13:03:24] Called DecompressByteArray: compressed_data_size=45302 data_size=246249, decompressed_data_size=246249 diff=0
[13:03:24] - Digital signature verified
[13:03:24]
[13:03:24] Project: 5506 (Run 3, Clone 126, Gen 76)
[13:03:24]
[13:03:24] Assembly optimizations on if available.
[13:03:24] Entering M.D.
[13:03:31] Working on p5506_supervillin_e1
[13:03:31] Client config found, loading data.
[13:03:31] Starting GUI Server
[13:06:20] Completed 1%
[13:09:10] Completed 2%
[13:12:02] Completed 3%
[13:14:55] Completed 4%
[13:17:47] Completed 5%
[13:20:39] Completed 6%
[13:23:30] Completed 7%
[13:26:21] Completed 8%
[13:29:11] Completed 9%
[13:32:02] Completed 10%
[13:34:52] Completed 11%
[13:37:45] Completed 12%
Pete
matte.2
Post by matte.2 »
Same phenomenon for following WU's
Project: 5512 (Run 9, Clone 41, Gen 0)
Project: 5511 (Run 9, Clone 8, Gen 0)
Project: 5513 (Run 9, Clone 235, Gen 0)
Project: 5513 (Run 4, Clone 96, Gen 0)
Project: 5512 (Run 9, Clone 102, Gen 0)
Project: 5511 (Run 1, Clone 164, Gen 0)
Project: 5511 (Run 2, Clone 372, Gen 0)
did not join the logs as it's always the same, ... Starting GUI Server ... mdrun_gpu returned -1 ... Going to send back what have done. ...
However I Did manage to fold Project: 5510 (Run 4, Clone 320, Gen 4) which is a 551x too.
Did not like it though, compared with a 5506 it generates 50 points less and takes about 25% longer to finish (122secs per pct iso 97secs per pct) resulting in a PPD drop of >25%. (maybe they're getting too many gpu folders ;-))
