Project: 5512 (Run 0, Clone 126, Gen 0)
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
This WU was sandwiched in between two successful ones. It looks like it fell over immediately.
20:19:58] Completed 96%
[20:21:59] Completed 97%
[20:24:00] Completed 98%
[20:26:01] Completed 99%
[20:28:02] Completed 100%
[20:29:02]
[20:29:02] Finished Work Unit:
[20:29:02] - Reading up to 30216 from "work/wudata_04.trr": Read 30216
[20:29:02] trr file hash check passed.
[20:29:02] - Reading up to 197920 from "work/wudata_04.xtc": Read 197920
[20:29:02] xtc file hash check passed.
[20:29:02] edr file hash check passed.
[20:29:02] logfile size: 35691
[20:29:02] Leaving Run
[20:29:04] - Writing 264899 bytes of core data to disk...
[20:29:04] Done: 264387 -> 237765 (compressed to 89.9 percent)
[20:29:04]   ... Done.
[20:29:04] - Shutting down core
[20:29:04]
[20:29:04] Folding@home Core Shutdown: FINISHED_UNIT
[20:29:07] CoreStatus = 64 (100)
[20:29:07] Sending work to server
[20:29:07] Project: 5511 (Run 8, Clone 104, Gen 0)
[20:29:07] - Read packet limit of 540015616... Set to 524286976.
[20:29:07] + Attempting to send results [September 9 20:29:07 UTC]
[20:29:12] + Results successfully sent
[20:29:12] Thank you for your contribution to Folding@Home.
[20:29:12] + Number of Units Completed: 264
[20:29:16] - Preparing to get new work unit...
[20:29:16] + Attempting to get work packet
[20:29:16] - Connecting to assignment server
[20:29:16] - Successful: assigned to (171.64.65.106).
[20:29:16] + News From Folding@Home: GPU folding beta
[20:29:16] Loaded queue successfully.
[20:29:17] + Closed connections
[20:29:17]
[20:29:17] + Processing work unit
[20:29:17] Core required: FahCore_11.exe
[20:29:17] Core found.
[20:29:17] Working on queue slot 05 [September 9 20:29:17 UTC]
[20:29:17] + Working ...
[20:29:17]
[20:29:17] *------------------------------*
[20:29:17] Folding@Home GPU Core - Beta
[20:29:17] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[20:29:17]
[20:29:17] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:29:17] Build host: amoeba
[20:29:17] Board Type: Nvidia
[20:29:17] Core      :
[20:29:17] Preparing to commence simulation
[20:29:17] - Looking at optimizations...
[20:29:17] - Created dyn
[20:29:17] - Files status OK
[20:29:17] - Expanded 84669 -> 447228 (decompressed 528.2 percent)
[20:29:17] Called DecompressByteArray: compressed_data_size=84669 data_size=447228, decompressed_data_size=447228 diff=0
[20:29:17] - Digital signature verified
[20:29:17]
[20:29:17] Project: 5512 (Run 0, Clone 126, Gen 0)
[20:29:17]
[20:29:17] Assembly optimizations on if available.
[20:29:17] Entering M.D.
[20:29:24] Working on p5512_lam5w_330K_g1
[20:29:26] Client config found, loading data.
[20:29:26] Starting GUI Server
[20:29:26] mdrun_gpu returned -1
[20:29:26] Going to send back what have done.
[20:29:27] logfile size: 11112 info=11112 bed=0 hdr=25
[20:29:27] - Writing 11650 bytes of core data to disk...
[20:29:27] Done: 11138 -> 4049 (compressed to 36.3 percent)
[20:29:27]   ... Done.
[20:29:27]
[20:29:27] Folding@home Core Shutdown: EARLY_UNIT_END
[20:29:30] CoreStatus = 72 (114)
[20:29:30] Sending work to server
[20:29:30] Project: 5512 (Run 0, Clone 126, Gen 0)
[20:29:30] - Read packet limit of 540015616... Set to 524286976.
[20:29:30] + Attempting to send results [September 9 20:29:30 UTC]
[20:29:30] + Results successfully sent
[20:29:30] Thank you for your contribution to Folding@Home.
[20:29:34] - Preparing to get new work unit...
[20:29:34] + Attempting to get work packet
[20:29:34] - Connecting to assignment server
[20:29:35] - Successful: assigned to (171.64.65.106).
[20:29:35] + News From Folding@Home: GPU folding beta
[20:29:35] Loaded queue successfully.
[20:29:36] + Closed connections
[20:29:41]
[20:29:41] + Processing work unit
[20:29:41] Core required: FahCore_11.exe
[20:29:41] Core found.
[20:29:41] Working on queue slot 06 [September 9 20:29:41 UTC]
[20:29:41] + Working ...
[20:29:41]
[20:29:41] *------------------------------*
[20:29:41] Folding@Home GPU Core - Beta
[20:29:41] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[20:29:41]
[20:29:41] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:29:41] Build host: amoeba
[20:29:41] Board Type: Nvidia
[20:29:41] Core      :
[20:29:41] Preparing to commence simulation
[20:29:41] - Looking at optimizations...
[20:29:41] - Created dyn
[20:29:41] - Files status OK
[20:29:41] - Expanded 41348 -> 231661 (decompressed 560.2 percent)
[20:29:41] Called DecompressByteArray: compressed_data_size=41348 data_size=231661, decompressed_data_size=231661 diff=0
[20:29:41] - Digital signature verified
[20:29:41]
[20:29:41] Project: 5504 (Run 7, Clone 598, Gen 26)
[20:29:41]
[20:29:41] Assembly optimizations on if available.
[20:29:41] Entering M.D.
[20:29:47] Working on 544 p5504_fip35_ww_domain
[20:29:48] Client config found, loading data.
[20:29:48] Starting GUI Server
[20:31:07] Completed 1%
[20:32:26] Completed 2%
[20:33:46] Completed 3%
[20:35:06] Completed 4%
[20:36:27] Completed 5%
[20:37:47] Completed 6%
[20:39:07] Completed 7%
[20:40:27] Completed 8%
Re: Project: 5511 (Run 8, Clone 104, Gen 0)
EDIT: Forget what I said earlier, I see the problem.
The WU that ended immediately was Project: 5512 (Run 0, Clone 126, Gen 0) and the title of this thread is Project: 5511 (Run 8, Clone 104, Gen 0) which is WU that you got full credit for, not a bad one. I'll correct the title.
Project: 5512 (Run 0, Clone 126, Gen 0) has been returned by many people for zero points. I'll ask Dan to pull it, if he hasn't already.
ppetrone
Pande Group Member
Re: Project 5512, Run 0, Clone 126, Gen 0
Post by ppetrone »
Thanks. I notified Dan as well.
Paula
VijayPande
Pande Group Member
Post by VijayPande »
I put this on a zero weight until we can see what's up.
VijayPande
Pande Group Member
PS We have an idea of what's wrong here. Interestingly, it could be that our tests for whether the GPU is working is now too strict. We're looking into this.
