Hi there,
Currently haveing issues with the SMP client due to a possible "issue" with win xp SP3
Any how, if i run the GPU client on its own (MID02) i get about 48 CPU usage
If i run the CPU graphical client on its own (MID 01)i get 50 Cpu usage
When i run both to gether the total system CPU usage is around 79% .not 98%
Looking at the system resource the GPU is throteling back? Why when there both set to use different cores?
Machine ID not working on GPU and CPU client
Machine #2:
Machine 3:
Re: Machine ID not working on GPU and CPU client
Set the GPU to use slightly higher a slightly higher core priority. Also, check mark the do not lock cores to the specific core. Both setting are in the advanced tab within the GPU client config. That should fix your problem.
