Finally! A Use for User ID!!!!
wfo
Post by wfo »
I know these requests are usually turned down by default. If user ID does not come into play here no one will ever use it again. I won't and no one else will ever have a reason to.
Xtremesytems decided to have a race among team members. As PlanetAMD64's #1 folder for at least 2 years and as a former motorcycle racer this intrigued me. :D The night the competition started, I swung all but 3 of my machines to that team for a 2 week sprint. :D I accidentally configured one machine to a non existent team # 33362 instead of 36362. :( I did not discover this till about an hour ago when I saw 2 WUs credited to a rogue team I knew nothing about. :( As you can see I am the one and only member and #1 on this previously non existent team. :evil: Please put the points where they really belong and delete Team BTM from your database. Your servers created the team name. My user ID was in the submissions and is only known by me. :D
If you need to do further research, just look where my points are going. :ewink: And read this thread starting with post #532. http://www.xtremesystems.org/forums/sho ... ost3275126
Flathead74
Re: Finally! A Use for User ID!!!!
Post by Flathead74 »
Good luck... :wink:
wfo
Post by wfo »
Flathead74 wrote:Good luck... :wink:
I know. I know. :( Still, why waste our time with user ID if it can't correct things like this??? It's not like there was a previously existing team that could contest the error. I'm the only guy and both WUs were uploaded in the last 48hrs. And I'm trying to get it corrected in a timely manner. It's not like this is 6 months after the fact. All my machines but the aforementioned 3 switched 9/1. That's easy to check. :D
Edit: As further proof I could PM the appropriate party the log of the last WU sent to this so-called team. That WU will never be uploaded. The client was reconfigured but shut down. :wink:
road-runner
Post by road-runner »
Those few points are not going to help you win anyway.... Image
The Pande Group has a firm policy to NEVER move/adjust points after they've been submitted. (They do correct the errors that they make but they cannot afford to fix errors caused by the donors, themselves.)
