Project: 2665 (Run 3, Clone 129, Gen 47)
starbuck
Post by starbuck »
This WU is dying at the same point every time:
[19:33:48] Completed 50000 out of 250000 steps (20 percent)
[19:45:54] Gromacs cannot continue further.
[19:45:54] Going to send back what have done.
[19:45:54] logfile size: 33770
[19:45:54] - Writing 34306 bytes of core data to disk...
[19:45:54] ... Done.
[19:45:54] - Failed to delete work/wudata_02.sas
[19:45:54] - Failed to delete work/wudata_02.goe
[19:45:54] Warning: check for stray files
[19:45:54]
[19:45:54] Folding@home Core Shutdown: EARLY_UNIT_END
[19:45:54]
[19:45:58] CoreStatus = 7B (123)
[19:45:58] Client-core communications error: ERROR 0x7b
[19:45:58] This is a sign of more serious problems, shutting down.
I've had it happen several times now.
Re: Project: 2665 (Run 3, Clone 129, Gen 47)
There is no data for this WU yet ...
You can try to submit your partial results with qfix : viewtopic.php?f=8&t=191
