Several 266* work units have stalled right after uploading
finished work units. Some for as long as 12 hours (before I caught them).
The short-term fix is simply Ctrl-C, then relaunch the client.
This one was only stalled for 16 minutes. I can post additional (complete) logs
as the others do the same thing if you need them.
Intel(R) Core(TM)2 Quad CPU @ 2.40GHz 2 GB RAM, Ubuntu 8.04 (no over clock)
[10:55:49] Project: 2669 (Run 2, Clone 19, Gen 9)
[21:10:22]
[21:10:22] Folding@home Core Shutdown: FINISHED_UNIT
[21:13:41] CoreStatus = 64 (100)
[21:13:41] Unit 4 finished with 85 percent of time to deadline remaining.
[21:13:41] Updated performance fraction: 0.838426
[21:13:41] Sending work to server
[21:13:41] + Attempting to send results
[21:13:41] - Reading file work/wuresults_04.dat from core
[21:13:41] (Read 25969302 bytes from disk)
[21:13:41] Connecting to http://171.64.65.56:8080/
[21:17:15] Posted data.
[21:17:15] Initial: 0000; - Uploaded at ~114 kB/s
[21:17:23] - Averaged speed for that direction ~110 kB/s
[21:17:23] + Results successfully sent
[21:17:23] Thank you for your contribution to Folding@Home.
[21:17:23] + Number of Units Completed: 30 (This is where it stalls)
[21:34:41] ***** Got an Activate signal (2) (This is me Ctrl-C)
[21:34:41] Killing all core threads
Folding@Home Client Shutdown.
P266* CLient Stalls After Sending
Re: P266* CLient Stalls After Sending
Please see the previous bug report, discussion, and beta client:
viewtopic.php?f=44&t=5327
