Hello,
This work unit is dying at the same point (10%) on each attempt.
"[18:11:35] Completed 25000 out of 250000 steps (10 percent)
[18:14:49] Warning: long 1-4 interactions
[18:14:50] Gromacs cannot continue further.
[18:14:50] Going to send back what have done."
Etc, etc. It's happened several times now. I'd hoped to get a new work unit assigned--but I've invariably gotten this broken job. Could it be canceled? Thanks,
Bret
Project: 2665 (Run 3, Clone 957, Gen 22)
Re: 2665 (Run 3, Clone 957, Gen 22)
This a bad WU indeed, nobody was able to go to 100%.
Use qfix to submit partial results : viewtopic.php?f=8&t=191
Please use this forum to report issues with a WU next time : viewforum.php?f=19
Re: Project: 2665 (Run 3, Clone 957, Gen 22)
thanks for the heads up, i'll remove it!
(peter has been working hard to make an automated system which will hopefully be available very soon)
