Project: 4596 (Run 27, Clone 13, Gen 32)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Another short lived one.
[07:47:55] + Closed connections
[07:47:55]
[07:47:55] + Processing work unit
[07:47:55] Core required: FahCore_82.exe
[07:47:55] Core found.
[07:47:55] Working on Unit 09 [September 5 07:47:55]
[07:47:55] + Working ...
[07:47:55] - Calling 'FahCore_82.exe -dir work/ -suffix 09 -checkpoint 15 -forceasm -verbose -lifeline 3536 -version 503'
[07:47:55]
[07:47:55] *------------------------------*
[07:47:55] Folding@Home PMD Core
[07:47:55] Version 1.03 (September 7, 2005)
[07:47:55]
[07:47:55] Preparing to commence simulation
[07:47:55] - Assembly optimizations manually forced on.
[07:47:55] - Not checking prior termination.
[07:47:55] - Expanded 17298 -> 109848 (decompressed 635.0 percent)
[07:47:55]
[07:47:55] Project: 4596 (Run 27, Clone 13, Gen 32)
[07:47:55]
[07:47:55] Assembly optimizations on if available.
[07:47:55] Entering M.D.
[07:47:59] + New frame time estimate; Working...
[07:48:01] Going to send back what have done.
[07:48:01] logfile size: 5649
[07:48:01] - Writing 6169 bytes of core data to disk...
[07:48:01]   ... Done.
[07:48:01]
[07:48:01] Folding@home Core Shutdown: EARLY_UNIT_END
[07:48:04] + New frame time estimate; Working...
[07:48:05] CoreStatus = 72 (114)
[07:48:05] Sending work to server
[07:48:05] + Attempting to send results
[07:48:05] - Reading file work/wuresults_09.dat from core
[07:48:05]   (Read 6169 bytes from disk)
[07:48:05] Connecting to http://169.230.26.30:8080/
[07:48:05] Posted data.
[07:48:05] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[07:48:05] - Uploaded at ~14 kB/s
[07:48:05] - Averaged speed for that direction ~46 kB/s
[07:48:05] + Results successfully sent
[07:48:05] Thank you for your contribution to Folding@Home.
Re: Project: 4596 (Run 27, Clone 13, Gen 32)
Yes it's a bad WU, thanks for the report :)
nwkelley
Pande Group Member
Post by nwkelley »
edit: i'll let vince know!
vvoelz
Pande Group Member
Post by vvoelz »
Thanks toTOW --
Some of bad WUs for 4596 look like the result of corrupted files. I have now turned off projects 4594, 4595 and 4596 (ACCEPT ONLY), so no more should be sent out. Let me know if you see any more.
Vince
