[20:08:38] Folding@Home Gromacs SMP Core
[20:08:38] Version 1.74 (March 10, 2007)
[20:08:38]
[20:08:38] Preparing to commence simulation
[20:08:38] - Ensuring status. Please wait.
[20:08:47] - Starting from initial work packet
[20:08:47]
[20:08:47] Project: 2665 (Run 2, Clone 343, Gen 37)
[20:08:47]
[20:08:47] Assembly optimizations on if available.
[20:08:47] Entering M.D.
[20:09:05] al work packet
[20:09:05]
[20:09:05] Project: 2665 (Run 2, Clone 343, Gen 37)
[20:09:05]
[20:09:05] 65 (Run 2, Clone 343, Gen 37)
[20:09:05]
[20:09:06] Entering M.D.
[20:09:12] Rejecting checkpoint
[20:09:15] Protein: HGG with glycosylations
[20:09:15] Writing local files
[20:09:24] Extra SSE boost OK.
[20:09:24] Writing local files
[20:09:25] Completed 0 out of 250000 steps (0 percent)
Is this right? [Project: 2665 (Run 2, Clone 343, Gen 37)]
Ancient_Dragon
I THINK I have the 64-bit version running -- below is the last few lines of the console window. It that what's supposed to happen? I assume Completed 0 out of ... will eventually count upwards.
Ancient_Dragon
Re: Is this right?
Oops! There's a big problem now
[20:26:32] Warning: long 1-4 interactions
[20:26:33] Gromacs cannot continue further.
[20:26:33] Going to send back what have done.
[20:26:33] logfi- Failed to delete work/wudata_01.sas
[20:26:33] - Failed to delete work/wudata_01.g- Failed to delete
[20:26:33] Folding@home Core Shutdown: EARLY_UNIT_END
[20:26:33] Finalizing output
[20:26:33] ing: check for stray files
[20:28:33]
[20:28:33] Folding@home Core Shutdown: EARLY_UNIT_END
[20:28:33]
[20:28:36] CoreStatus = 7B (123)
[20:28:36] Client-core communications error: ERROR 0x7b
[20:28:36] This is a sign of more serious problems, shutting down.
Re: Is this right?
Yes, its supposed to.Ancient_Dragon wrote:I THINK I have the 64-bit version running -- below is the last few lines of the console window. It that what's supposed to happen? I assume Completed 0 out of ... will eventually count upwards.
I looked up that particular Work Unit: Project: 2665 (Run 2, Clone 343, Gen 37), and a number of people have attempted to run it and they've all had problems with it, so it's a bad WU, not something wrong with your installation.
arfyness
- Hardware configuration: 5 x WinXP (console version installed as service)
1 x Linux (manually, until I figure out what's wrong)
Asus nForce2 Mobo (A7N8X-E) w/ AMD AthlonXP 3200+ :: 1.0GB RAM :: Ubuntu Hardy 8.04.1 - Location: Columbus, Ohio, USA
Re: Is this right?
Ancient_Dragon: Post back if this happens again. There is also a separate board Issues with a specific WU for repeated problems with the same work unit ... In your case, look for "Project: 2665 (Run 2, Clone 343, Gen 37)" if you have any future errors.
-- Nate
-- Nate
:: ./fah6 v6.02 :: Ubuntu Hardy 8.04.1 :: Asus A7N8X-E (nForce2) :: AMD AthlonXP 3200+ :: 1.0GB RAM :: 1 cpu ::
Re: Is this right?
At the time he posted, there wasn't any good way to tell if it was a problem with a specific WU. Once I checked on it, the thread can be moved to that forum . . . which I'll do right now.arfyness wrote:Ancient_Dragon: Post back if this happens again. There is also a separate board Issues with a specific WU for repeated problems with the same work unit ... In your case, look for "Project: 2665 (Run 2, Clone 343, Gen 37)" if you have any future errors.
-- Nate
Re: Is this right? [Project: 2665 (Run 2, Clone 343, Gen 37)]
Hi.
Let me transmit this to Peter.
Thanks,
Paula
Thanks,
Paula
VijayPande
- Pande Group Member
I stopped this one manually.
