FAH WU Backup
FAH WU Backup
I was wondering where FAH stores its backups of the WU it is working on, and how big these backups are.
Re: FAH WU Backup
Search for the "work" directory on your system.
jackrabbit
Re: FAH WU Backup
Actually, there is no backup directory as such. There is only "the place where work is stored temporarily during processing", which is the work folder as Ivo stated. If you want backups, you'll have to make them yourself.
The biggest difference between time and space is that you can't reuse time.
