Project: 2665 (Run 0, Clone 667, Gen 40)
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Post by Leoslocks »
[12:35:19] Project: 2665 (Run 0, Clone 667, Gen 40)
[12:35:19]
[12:35:20] Assembly optimizations on if available.
[12:35:20] Entering M.D.
[12:35:39]  percent)
[12:35:39] - Starting from initial work packet
[12:35:39]
[12:35:39] Project: 2665 (Run 0, Clone 667, Gen 40)
[12:35:39]
[12:35:41] Entering M.D.
[12:35:49] Rejecting checkpoint
[12:35:50] Protein: HGG in water
[12:35:50] Writing local files
[12:35:57] Extra SSE boost OK.
[12:35:57] Writing local files
[12:35:57] Completed 0 out of 250000 steps  (0 percent)
[12:51:52] run has entered a
[12:51:52]   state from which no further progress can be made.
[12:51:52] This may be the correct result of the simulation, however if you
[12:51:52]   often see other project units terminating early like this
[12:51:52]   toa, ltu may wish computer (issues
[12:51:52]   such as hilogfile size: 10631
[12:51:52] - Writing 11181 bytes of core data to disk...
[12:51:52]   ... Done.
[12:51:52] - Failed to delete work/wudata_03.arc
[12:51:52] No C.P. to delete.
[12:51:52] Warning:  check for stray files
[12:51:52] 550 bytes of core data to disk...
[12:51:52] ailed to delete work/wudata_03.arc
[12:51:52]
[12:51:52] Folding@home Core Shutdown: EARLY_UNIT_END
[12:51:52]
[12:51:55] CoreStatus = 7B (123)
[12:51:55] Client-core communications error: ERROR 0x7b
[12:51:55] Deleting current work unit & continuing...
[12:51:55] Using generic mpiexec calls
[12:53:57] - Preparing to get new work unit...
[12:53:57] + Attempting to get work packet
[12:53:57] - Connecting to assignment server
[12:53:58] - Successful: assigned to (171.64.65.64).
[12:53:58] + News From Folding@Home: Welcome to Folding@Home
[12:53:58] Loaded queue successfully.
[12:54:13] + Closed connections
[12:54:18]
[12:54:18] + Processing work unit
[12:54:18] Work type a1 not eligible for variable processors
[12:54:18] Core required: FahCore_a1.exe
[12:54:18] Core found.
[12:54:18] Using generic mpiexec calls
[12:54:18] Working on queue slot 04 [September 4 12:54:18 UTC]
[12:54:18] + Working ...
[12:54:18]
[12:54:18] *------------------------------*
[12:54:18] Folding@Home Gromacs SMP Core
[12:54:18] Version 1.74 (March 10, 2007)
[12:54:18]
[12:54:18] Preparing to commence simulation
[12:54:18] - Ensuring status. Please wait.
[12:54:23] - Starting from initial work packet
[12:54:23]
[12:54:23] Project: 2665 (Run 0, Clone 667, Gen 40)
[12:54:23]
[12:54:24] Assembly optimizations on if available.
[12:54:24] Entering M.D.
[12:54:42]  percent)
[12:54:42] - Starting from initial work packet
[12:54:42]
[12:54:42] Project: 2665 (Run 0, Clone 667, Gen 40)
[12:54:42]
[12:54:47] Entering M.D.
[12:54:54] Rejecting checkpoint
[12:54:56] Protein: HGG in water
[12:54:56] Writing local files
[12:55:05] Extra SSE boost OK.
[12:55:05] Writing local files
[12:55:06] Completed 0 out of 250000 steps  (0 percent)
[13:15:27] Warning:  long 1-4 interactions
[13:15:27] Quit 101 - NaN detected: (ener[20])
[13:15:27]
[13:15:27] Simulation instability has been encountered. The run has entered a
[13:15:27]   state from which no further progress can be made.
[13:15:27] This may be the correct result of the simulation, however if you
[13:15:27]   often see other project units terminating early like this
[13:15:27]   too, you may wish to check the stability of your computer (issues
[13:15:27]   such as high temperature, overclocking, etc.).
[13:15:27] No C.P. to delete.
[13:15:27] Warning:  check for stray files
[13:15:27] 631
[13:15:27] - Writing 11181 bNo C.P. to delete.
[13:15:27]
[13:15:27] Folding@home Core Shutdown: EARLY_UNIT_END
[13:15:27] FinWarning:  check for stray files
[13:17:27]
[13:17:27] Folding@home Core Shutdown: EARLY_UNIT_END
[13:17:27]
[13:17:31] CoreStatus = 7B (123)
[13:17:31] Client-core communications error: ERROR 0x7b
[13:17:31] Deleting current work unit & continuing...
[13:17:31] Using generic mpiexec calls
[13:19:34] - Preparing to get new work unit...
[13:19:34] + Attempting to get work packet
[13:19:34] - Connecting to assignment server
[13:19:34] - Successful: assigned to (171.64.65.64).
[13:19:34] + News From Folding@Home: Welcome to Folding@Home
[13:19:34] Loaded queue successfully.
[13:19:52] + Closed connections
[13:19:57]
[13:19:57] + Processing work unit
[13:19:57] Work type a1 not eligible for variable processors
[13:19:57] Core required: FahCore_a1.exe
[13:19:57] Core found.
[13:19:57] Using generic mpiexec calls
[13:19:57] Working on queue slot 05 [September 4 13:19:57 UTC]
[13:19:57] + Working ...
[13:19:58]
[13:19:58] *------------------------------*
[13:19:58] Folding@Home Gromacs SMP Core
[13:19:58] Version 1.74 (March 10, 2007)
[13:19:58]
[13:19:58] Preparing to commence simulation
[13:19:58] - Ensuring status. Please wait.
[13:20:03] - Starting from initial work packet
[13:20:03]
[13:20:03] Project: 2665 (Run 0, Clone 667, Gen 40)
[13:20:03]
[13:20:03] Assembly optimizations on if available.
[13:20:03] Entering M.D.
[13:20:23] al work packet
[13:20:23]
[13:20:23] Project: 2665 (Run 0, Clone 667, Gen 40)
[13:20:23]
[13:20:25] 65 (Run 0, Clone 667, Gen 40)
[13:20:25]
[13:20:27] Entering M.D.
[13:20:35] GG in water
[13:20:35]  in water
[13:20:35] Writing local files
[13:20:36] Extra SSE boost OK.
[13:20:45] cal files
[13:20:45] Completed 0 out of 250000 steps  (0 percent)
[13:41:17] Warning:  long 1-4 interactions
[13:41:17] un has entered a
[13:41:17]   state from which no further progress can be made.
[13:41:17] This may be the correct result of the simulation, however if you
[13:41:17]   often see other project units terminating early like this
[13:41:17]   too, you may wish to check the stability of your computer (issues
[13:41:17]   such as high temperature, overclocking, etc.).
[13:41:17] Going to s- Failed to delete work/wudata_05.arc
[13:41:17] No C.P. to delete.
[13:41:17] Warning:  check for stray files
[13:41:17]
[13:41:17] Folding@home Core Shutdown: EARLY_UNIT_END
[13:41:17] Finalizing output
[13:41:17] te work/wudata_05.arc
[13:41:17] arc
[13:43:17] output
[13:43:17] g@home Core Shutdown: EARLY_UNIT_END
[13:43:17]
[13:43:17] Folding@home Core Shutdown: EARLY_UNIT_END
[13:43:20] CoreStatus = 7B (123)
[13:43:20] Client-core communications error: ERROR 0x7b
[13:43:20] - Attempting to download new core...
Downloaded a new core, aquired a new WU and Fold on.
Re: Project: 2665 (Run 0, Clone 667, Gen 40)
Someone managed to complete this one for full credit, but there is also a lot of reports for partial credit.
