Project: 5506 (Run 6, Clone 357, Gen 60)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Came to a very early end. ;-)
[21:27:21] + Closed connections
[21:27:21]
[21:27:21] + Processing work unit
[21:27:21] Core required: FahCore_11.exe
[21:27:21] Core found.
[21:27:21] Working on queue slot 01 [August 30 21:27:21 UTC]
[21:27:21] + Working ...
[21:27:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 180 -version 620'
[21:27:21]
[21:27:21] *------------------------------*
[21:27:21] Folding@Home GPU Core - Beta
[21:27:21] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[21:27:21]
[21:27:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:27:21] Build host: amoeba
[21:27:21] Board Type: Nvidia
[21:27:21] Core      :
[21:27:21] Preparing to commence simulation
[21:27:21] - Looking at optimizations...
[21:27:21] - Created dyn
[21:27:21] - Files status OK
[21:27:21] - Expanded 45487 -> 246249 (decompressed 541.3 percent)
[21:27:21] Called DecompressByteArray: compressed_data_size=45487 data_size=246249, decompressed_data_size=246249 diff=0
[21:27:21] - Digital signature verified
[21:27:21]
[21:27:21] Project: 5506 (Run 6, Clone 357, Gen 60)
[21:27:21]
[21:27:21] Assembly optimizations on if available.
[21:27:21] Entering M.D.
[21:27:28] Working on p5506_supervillin_e1
[21:27:28] Client config found, loading data.
[21:27:28] mdrun_gpu returned -1
[21:27:28] Going to send back what have done.
[21:27:28] Starting GUI Server
[21:27:29] logfile size: 10882 info=10882 bed=0 hdr=25
[21:27:29] - Writing 11420 bytes of core data to disk...
[21:27:29] Done: 10908 -> 3968 (compressed to 36.3 percent)
[21:27:29]   ... Done.
[21:27:29]
[21:27:29] Folding@home Core Shutdown: EARLY_UNIT_END
[21:27:31] CoreStatus = 72 (114)
[21:27:31] Sending work to server
[21:27:31] Project: 5506 (Run 6, Clone 357, Gen 60)
[21:27:31] - Read packet limit of 540015616... Set to 524286976.
[21:27:31] + Attempting to send results [August 30 21:27:31 UTC]
[21:27:31] - Reading file work/wuresults_01.dat from core
[21:27:31]   (Read 4480 bytes from disk)
[21:27:31] Connecting to http://171.64.65.106:8080/
[21:27:32] Posted data.
[21:27:32] Initial: 0000; - Uploaded at ~5 kB/s
[21:27:32] - Averaged speed for that direction ~41 kB/s
[21:27:32] + Results successfully sent
[21:27:32] Thank you for your contribution to Folding@Home.
[21:27:36] Trying to send all finished work units
[21:27:36] + No unsent completed units remaining.
Re: Project: 5506 (Run 6, Clone 357, Gen 60)
This one is probably a bad WU : there is many reports for 0 credits.
