Project: 2665 (Run 2, Clone 516, Gen 35)
Freddy_Frog
Post by Freddy_Frog »
This may be a bad unit. Have tried it 3 times and it failed each time just after 4% on a Q6600, Vista64, single -SMP client, plus a GPU client. I had to delete it each time before it would continue. Maybe someone else will have better success.
[03:41:47] Completed 250000 out of 250000 steps  (100 percent)
[03:41:47] Writing final coordinates.
[03:41:48] Past main M.D. loop
[03:41:48] Will end MPI now
[03:42:48]
[03:42:48] Finished Work Unit:
[03:42:48] - Reading up to 21193200 from "work/wudata_03.arc": Read 21193200
[03:42:48] - Reading up to 526180 from "work/wudata_03.xtc": Read 526180
[03:42:48] goefile size: 0
[03:42:48] logfile size: 203297
[03:42:48] Leaving Run
[03:42:50] - Writing 21929049 bytes of core data to disk...
[03:42:50]   ... Done.
[03:42:50] - Failed to delete work/wudata_03.sas
[03:42:50] - Failed to delete work/wudata_03.goe
[03:42:50] Warning:  check for stray files
[03:42:50] - Shutting down core
[03:42:50]
[03:42:50] Folding@home Core Shutdown: FINISHED_UNIT
[03:42:50]
[03:44:57] CoreStatus = 64 (100)
[03:44:57] Unit 3 finished with 79 percent of time to deadline remaining.
[03:44:57] Updated performance fraction: 0.775314
[03:44:57] Sending work to server
[03:44:57] Project: 2665 (Run 1, Clone 542, Gen 47)
[03:44:57] + Attempting to send results [September 3 03:44:57 UTC]
[03:44:57] - Reading file work/wuresults_03.dat from core
[03:44:57]   (Read 21929049 bytes from disk)
[03:44:57] Connecting to http://171.64.65.64:8080/
[03:48:31] Posted data.
[03:48:31] Initial: 0000; - Uploaded at ~98 kB/s
[03:48:35] - Averaged speed for that direction ~97 kB/s
[03:48:35] + Results successfully sent
[03:48:35] Thank you for your contribution to Folding@Home.
[03:48:35] + Number of Units Completed: 362
[03:48:36] Using generic mpiexec calls
[03:50:40] - Warning: Could not delete all work unit files (3): Core returned invalid code
[03:50:40] Trying to send all finished work units
[03:50:40] + No unsent completed units remaining.
[03:50:40] - Preparing to get new work unit...
[03:50:40] + Attempting to get work packet
[03:50:40] - Will indicate memory of 4093 MB
[03:50:40] - Connecting to assignment server
[03:50:40] Connecting to http://assign.stanford.edu:8080/
[03:50:41] Posted data.
[03:50:41] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[03:50:41] + News From Folding@Home: Welcome to Folding@Home
[03:50:41] Loaded queue successfully.
[03:50:41] Connecting to http://171.64.65.64:8080/
[03:50:47] Posted data.
[03:50:47] Initial: 0000; - Receiving payload (expected size: 4841308)
[03:50:58] - Downloaded at ~429 kB/s
[03:50:58] - Averaged speed for that direction ~408 kB/s
[03:50:58] + Received work.
[03:50:58] Trying to send all finished work units
[03:50:58] + No unsent completed units remaining.
[03:50:58] + Closed connections
[03:50:58]
[03:50:58] + Processing work unit
[03:50:58] Work type a1 not eligible for variable processors
[03:50:58] Core required: FahCore_a1.exe
[03:50:58] Core found.
[03:50:58] Using generic mpiexec calls
[03:50:58] Working on queue slot 04 [September 3 03:50:58 UTC]
[03:50:58] + Working ...
[03:50:58] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 4944 -version 622'
[03:50:58]
[03:50:58] *------------------------------*
[03:50:58] Folding@Home Gromacs SMP Core
[03:50:58] Version 1.74 (March 10, 2007)
[03:50:58]
[03:50:58] Preparing to commence simulation
[03:50:58] - Looking at optimizations...
[03:50:58] - Created dyn
[03:50:58] - Files status OK
[03:51:03] - Expanded 4840796 -> 24810145 (decompressed 512.5 percent)
[03:51:03] - Starting from initial work packet
[03:51:03]
[03:51:03] Project: 2665 (Run 2, Clone 516, Gen 35)
[03:51:03]
[03:51:04] Assembly optimizations on if available.
[03:51:04] Entering M.D.
[03:51:25]  percent)
[03:51:25] cket
[03:51:25]
[03:51:25] Project: 2665 (Run 2, Clone 516, Gen 35)
[03:51:25]
[03:51:26] 65 (Run 2, Clone 516, Gen 35)
[03:51:26]
[03:51:27] Entering M.D.
[03:51:33] Rejecting checkpoint
[03:51:34] Protein: HGG with glycosylations
[03:51:34] Writing local files
[03:51:42] Extra SSE boost OK.
[03:51:42] Writing local files
[03:51:42] Completed 0 out of 250000 steps  (0 percent)
[04:06:43] Timered checkpoint triggered.
[04:07:39] Writing local files
[04:07:39] Completed 2500 out of 250000 steps  (1 percent)
[04:22:40] Timered checkpoint triggered.
[04:23:36] Writing local files
[04:23:36] Completed 5000 out of 250000 steps  (2 percent)
[04:38:37] Timered checkpoint triggered.
[04:39:25] Writing local files
[04:39:26] Completed 7500 out of 250000 steps  (3 percent)
[04:54:26] Timered checkpoint triggered.
[04:58:12] Writing local files
[04:58:12] Completed 10000 out of 250000 steps  (4 percent)
[05:03:43] Warning:  long 1-4 interactions
[07:58:13] At least 3 hours since checkpoint written...
[08:00:13]
[08:00:13] Folding@home Core Shutdown: EARLY_UNIT_END
[08:00:13]
[08:00:16] CoreStatus = 7B (123)
[08:00:16] Client-core communications error: ERROR 0x7b
[08:00:16] This is a sign of more serious problems, shutting down.
[08:55:35] - Autosending finished units... [September 3 08:55:35 UTC]
[08:55:35] Trying to send all finished work units
[08:55:35] + No unsent completed units remaining.
[08:55:35] - Autosend completed
--- Opening Log file [September 3 09:06:09 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2
                          http://folding.stanford.edu
Launch directory: C:\Tools(x86)\Folding@Home Windows SMP Client V1.01
Executable: C:\Tools(x86)\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe
Arguments: -smp -local -verbosity 9
[09:06:09] - Ask before connecting: No
[09:06:09] - User name: Freddy_Frog (Team 31707)
[09:06:09] - User ID:
[09:06:09] - Machine ID: 1
[09:06:09]
[09:06:09] Loaded queue successfully.
[09:06:09]
[09:06:09] + Processing work unit
[09:06:09] - Autosending finished units... [September 3 09:06:09 UTC]
[09:06:09] Trying to send all finished work units
[09:06:09] Work type a1 not eligible for variable processors
[09:06:09] + No unsent completed units remaining.
[09:06:09] Core required: FahCore_a1.exe
[09:06:09] - Autosend completed
[09:06:09] Core found.
[09:06:09] Using generic mpiexec calls
[09:06:09] Working on queue slot 04 [September 3 09:06:09 UTC]
[09:06:09] + Working ...
[09:06:09] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 3964 -version 622'
[09:06:10]
[09:06:10] *------------------------------*
[09:06:10] Folding@Home Gromacs SMP Core
[09:06:10] Version 1.74 (March 10, 2007)
[09:06:10]
[09:06:10] Preparing to commence simulation
[09:06:10] - Looking at optimizations...
[09:06:10] - Failed to delete work/wudata_04.arc
[09:06:10] Warning:  c- Created dyn
[09:06:10] - Files status OK
[09:06:10] 4.arc
[09:06:10] Warning:  check for stray files
[09:06:10] - Created dyn
[09:06:10] inalizing output
[09:08:10] e Shutdown: MISSING_WORK_FILES
[09:08:10] Finalizing output
[09:08:13] CoreStatus = 1 (1)
[09:08:13] Client-core communications error: ERROR 0x1
[09:08:13] This is a sign of more serious problems, shutting down.
[09:26:14] Killing all core threads
[09:26:14] Killing 2 cores
[09:26:14] Killing core 0
[09:26:14] Killing core 1
Folding@Home Client Shutdown at user request.
[09:26:14] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
--- Opening Log file [September 3 09:27:34 UTC]
[09:27:34] - Ask before connecting: No
[09:27:34] - User name: Freddy_Frog (Team 31707)
[09:27:34] - User ID:
[09:27:34] - Machine ID: 1
[09:27:34]
[09:27:34] Loaded queue successfully.
[09:27:34]
[09:27:34] - Autosending finished units... [September 3 09:27:34 UTC]
[09:27:34] Trying to send all finished work units
[09:27:34] + Processing work unit
[09:27:34] + No unsent completed units remaining.
[09:27:34] Work type a1 not eligible for variable processors
[09:27:34] - Autosend completed
[09:27:34] Core required: FahCore_a1.exe
[09:27:34] Core found.
[09:27:34] Using generic mpiexec calls
[09:27:34] Working on queue slot 04 [September 3 09:27:34 UTC]
[09:27:34] + Working ...
[09:27:34] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 4244 -version 622'
[09:27:34]
[09:27:34] *------------------------------*
[09:27:34] Folding@Home Gromacs SMP Core
[09:27:34] Version 1.74 (March 10, 2007)
[09:27:34]
[09:27:34] Preparing to commence simulation
[09:27:34] - Ensuring status. Please wait.
[09:27:51] - Looking at optimizations...
[09:27:51] - Working with standard loops on this execution.
[09:27:51] - Previous termination of core was improper.
[09:27:51] - Files status OK
[09:27:51]
[09:27:51] Folding@home Core Shutdown: MISSING_WORK_FILES
[09:27:51] Finalizing output
[09:29:52] G_WORK_FILES
[09:29:52] Finalizing output
[09:29:55] CoreStatus = 1 (1)
[09:29:55] Client-core communications error: ERROR 0x1
[09:29:55] This is a sign of more serious problems, shutting down.
[09:50:04] Killing all core threads
[09:50:04] Killing 2 cores
[09:50:04] Killing core 0
[09:50:04] Killing core 1
[09:50:04] ***** Got a SIGTERM signal (2)
--- Opening Log file [September 3 09:52:09 UTC]
[09:52:09] - Ask before connecting: No
[09:52:09] - User name: Freddy_Frog (Team 31707)
[09:52:09] - User ID:
[09:52:09] - Machine ID: 1
[09:52:09]
[09:52:10] Loaded queue successfully.
[09:52:10]
[09:52:10] + Processing work unit
[09:52:10] Work type a1 not eligible for variable processors
[09:52:10] - Autosending finished units... [September 3 09:52:10 UTC]
[09:52:10] Core required: FahCore_a1.exe
[09:52:10] Trying to send all finished work units
[09:52:10] Core found.
[09:52:10] Using generic mpiexec calls
[09:52:10] + No unsent completed units remaining.
[09:52:10] Working on queue slot 04 [September 3 09:52:10 UTC]
[09:52:10] - Autosend completed
[09:52:10] + Working ...
[09:52:10] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 3988 -version 622'
[09:52:10]
[09:52:10] *------------------------------*
[09:52:10] Folding@Home Gromacs SMP Core
[09:52:10] Version 1.74 (March 10, 2007)
[09:52:10]
[09:52:10] Preparing to commence simulation
[09:52:10] - Ensuring status. Please wait.
[09:52:27] - Looking at optimizations...
[09:52:27] - Working with standard loops on this execution.
[09:52:27] - Previous termination of core was improper.
[09:52:27] - Going to use standard loops.
[09:52:27] - Files status OK
[09:54:27]
[09:54:27] Folding@home Core Shutdown: MISSING_WORK_FILES
[09:54:27] Finalizing output
[09:54:30] CoreStatus = 1 (1)
[09:54:30] Client-core communications error: ERROR 0x1
[09:54:30] This is a sign of more serious problems, shutting down.
[09:55:28] Killing all core threads
[09:55:28] Killing 2 cores
[09:55:28] Killing core 0
[09:55:28] Killing core 1
[09:55:28] ***** Got a SIGTERM signal (2)
--- Opening Log file [September 3 09:55:32 UTC]
[09:55:32] - Ask before connecting: No
[09:55:32] - User name: Freddy_Frog (Team 31707)
[09:55:32] - User ID:
[09:55:32] - Machine ID: 1
[09:55:32]
[09:55:32] Could not open work queue, generating new queue...
[09:55:32] - Preparing to get new work unit...
[09:55:32] + Attempting to get work packet
[09:55:32] - Will indicate memory of 4093 MB
[09:55:32] - Detect CPU.[09:55:32] - Autosending finished units... [September 3 09:55:32 UTC]
 Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[09:55:32] Trying to send all finished work units
[09:55:32] + No unsent completed units remaining.
[09:55:32] - Autosend completed
[09:55:32] - Connecting to assignment server
[09:55:32] Connecting to http://assign.stanford.edu:8080/
[09:55:32] Posted data.
[09:55:32] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[09:55:32] + News From Folding@Home: Welcome to Folding@Home
[09:55:33] Loaded queue successfully.
[09:55:33] Connecting to http://171.64.65.64:8080/
[09:55:38] Posted data.
[09:55:38] Initial: 0000; - Receiving payload (expected size: 4841308)
[09:55:49] - Downloaded at ~429 kB/s
[09:55:49] - Averaged speed for that direction ~429 kB/s
[09:55:49] + Received work.
[09:55:49] + Closed connections
[09:55:49]
[09:55:49] + Processing work unit
[09:55:49] Work type a1 not eligible for variable processors
[09:55:49] Core required: FahCore_a1.exe
[09:55:49] Core found.
[09:55:49] Using generic mpiexec calls
[09:55:49] Working on queue slot 01 [September 3 09:55:49 UTC]
[09:55:49] + Working ...
[09:55:49] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 2304 -version 622'
[09:55:49]
[09:55:49] *------------------------------*
[09:55:49] Folding@Home Gromacs SMP Core
[09:55:49] Version 1.74 (March 10, 2007)
[09:55:49]
[09:55:49] Preparing to commence simulation
[09:55:49] - Ensuring status. Please wait.
[09:56:06] - Looking at optimizations...
[09:56:06] - Working with standard loops on this execution.
[09:56:06] - Created dyn
[09:56:06] - Files status OK
[09:56:06] as improper.
[09:56:06] - Going to use standard loops.
[09:56:18] - Expanded 4840796 -> 24810145 (decompressed 512.5 percent)
[09:56:18] - Starting from initial work packet
[09:56:18]
[09:56:18] Project: 2665 (Run 2, Clone 516, Gen 35)
[09:56:18]
[09:56:18] Entering M.D.
[09:56:28] Rejecting checkpoint
[09:56:30] Protein: HGG with glycosylations
[09:56:30] Writing local files
[09:56:37] Extra SSE boost OK.
[09:56:38] Writing local files
[09:56:38] Completed 0 out of 250000 steps  (0 percent)
[10:11:38] Timered checkpoint triggered.
[10:12:59] Writing local files
[10:12:59] Completed 2500 out of 250000 steps  (1 percent)
[10:27:59] Timered checkpoint triggered.
[10:31:22] Writing local files
[10:31:23] Completed 5000 out of 250000 steps  (2 percent)
[10:46:22] Timered checkpoint triggered.
[10:50:37] Writing local files
[10:50:38] Completed 7500 out of 250000 steps  (3 percent)
[11:05:37] Timered checkpoint triggered.
[11:09:46] Writing local files
[11:09:46] Completed 10000 out of 250000 steps  (4 percent)
[11:15:07]
[11:15:07] - Failed to delete work/wudata_01.arc
[11:15:07] Warning:  check for stray files
[11:15:07] d to delete work/wudata_01.arc
[11:15:07] No C.P. to delete.
[11:15:07] - Failed to delete work/wudata_01.chk
[11:15:07] - Failed to delete work/wudata_01.goe
[11:15:07] ulation, however if you
[11:15:07]   often see other project units terminating early like this
[11:15:07]   too, you may wish to check the stability of your computer (issues
[11:15:07]   such as high temperature, overclocking, etc.).
[11:15:07] Going to send back what have done.
[11:15:07] logfile size: 16696
[11:15:07] - Writing 17246 bytes of core data to disk...
[11:15:07]   ... Done.
[11:17:07]
[11:17:07] Folding@home Core Shutdown: EARLY_UNIT_END
[11:17:07]
[11:17:11] CoreStatus = 7B (123)
[11:17:11] Client-core communications error: ERROR 0x7b
[11:17:11] This is a sign of more serious problems, shutting down.
[11:25:15] Killing all core threads
[11:25:15] Killing 2 cores
[11:25:15] Killing core 0
[11:25:15] Killing core 1
[11:25:15] ***** Got a SIGTERM signal (2)
--- Opening Log file [September 3 11:35:09 UTC]
[11:35:09] - Ask before connecting: No
[11:35:09] - User name: Freddy_Frog (Team 31707)
[11:35:09] - User ID:
[11:35:09] - Machine ID: 1
[11:35:09]
[11:35:09] Could not open work queue, generating new queue...
[11:35:09] - Preparing to get new work unit...
[11:35:09] - Autosending finished units... [September 3 11:35:09 UTC]
[11:35:09] + Attempting to get work packet
[11:35:09] Trying to send all finished work units
[11:35:09] - Will indicate memory of 4093 MB
[11:35:09] + No unsent completed units remaining.
[11:35:09] - Autosend completed
[11:35:09] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[11:35:09] - Connecting to assignment server
[11:35:09] Connecting to http://assign.stanford.edu:8080/
[11:35:09] Posted data.
[11:35:09] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[11:35:09] + News From Folding@Home: Welcome to Folding@Home
[11:35:10] Loaded queue successfully.
[11:35:10] Connecting to http://171.64.65.64:8080/
[11:35:15] Posted data.
[11:35:15] Initial: 0000; - Receiving payload (expected size: 4841308)
[11:35:26] - Downloaded at ~429 kB/s
[11:35:26] - Averaged speed for that direction ~429 kB/s
[11:35:26] + Received work.
[11:35:26] + Closed connections
[11:35:26]
[11:35:26] + Processing work unit
[11:35:26] Work type a1 not eligible for variable processors
[11:35:26] Core required: FahCore_a1.exe
[11:35:26] Core not found.
[11:35:26] - Core is not present or corrupted.
[11:35:26] - Attempting to download new core...
[11:35:26] + Downloading new core: FahCore_a1.exe
[11:35:26] Downloading core (/~pande/Win32/x86/Core_a1.fah from www.stanford.edu)
[11:35:26] Initial: AFDE; + 10240 bytes downloaded
[11:35:27] Initial: AD21; + 20480 bytes downloaded
[11:35:27] Initial: CC38; + 30720 bytes downloaded
[11:35:27] Initial: 8501; + 40960 bytes downloaded
[11:35:27] Initial: F56A; + 51200 bytes downloaded
[11:35:27] Initial: ABAE; + 61440 bytes downloaded
[11:35:27] Initial: B6B0; + 71680 bytes downloaded
[11:35:27] Initial: 783A; + 81920 bytes downloaded
[11:35:28] Initial: B2A6; + 92160 bytes downloaded
[11:35:28] Initial: 1409; + 102400 bytes downloaded
[11:35:28] Initial: BBF0; + 112640 bytes downloaded
[11:35:28] Initial: 1861; + 122880 bytes downloaded
[11:35:28] Initial: 5950; + 133120 bytes downloaded
[11:35:28] Initial: 1081; + 143360 bytes downloaded
[11:35:28] Initial: 26BC; + 153600 bytes downloaded
[11:35:28] Initial: FE4A; + 163840 bytes downloaded
[11:35:28] Initial: C1C3; + 174080 bytes downloaded
[11:35:28] Initial: 9B49; + 184320 bytes downloaded
[11:35:28] Initial: 9EE5; + 194560 bytes downloaded
[11:35:28] Initial: D79D; + 204800 bytes downloaded
[11:35:28] Initial: 7801; + 215040 bytes downloaded
[11:35:28] Initial: 8B51; + 225280 bytes downloaded
[11:35:28] Initial: E26E; + 235520 bytes downloaded
[11:35:28] Initial: EDB0; + 245760 bytes downloaded
[11:35:28] Initial: 0919; + 256000 bytes downloaded
[11:35:28] Initial: CDDE; + 266240 bytes downloaded
[11:35:28] Initial: 7A7E; + 276480 bytes downloaded
[11:35:28] Initial: 034E; + 286720 bytes downloaded
[11:35:28] Initial: 88D0; + 296960 bytes downloaded
[11:35:28] Initial: D66D; + 307200 bytes downloaded
[11:35:28] Initial: 6A52; + 317440 bytes downloaded
[11:35:28] Initial: B478; + 327680 bytes downloaded
[11:35:28] Initial: CF8A; + 337920 bytes downloaded
[11:35:28] Initial: 8407; + 348160 bytes downloaded
[11:35:28] Initial: 2246; + 358400 bytes downloaded
[11:35:29] Initial: 1C69; + 368640 bytes downloaded
[11:35:29] Initial: 1287; + 378880 bytes downloaded
[11:35:29] Initial: 19B3; + 389120 bytes downloaded
[11:35:29] Initial: 1AD1; + 399360 bytes downloaded
[11:35:29] Initial: 5791; + 409600 bytes downloaded
[11:35:29] Initial: 76C5; + 419840 bytes downloaded
[11:35:29] Initial: 9B77; + 430080 bytes downloaded
[11:35:29] Initial: E82F; + 440320 bytes downloaded
[11:35:29] Initial: D0D3; + 450560 bytes downloaded
[11:35:29] Initial: 0F5E; + 460800 bytes downloaded
[11:35:29] Initial: D743; + 471040 bytes downloaded
[11:35:29] Initial: 0B7C; + 481280 bytes downloaded
[11:35:29] Initial: FAFD; + 491520 bytes downloaded
[11:35:29] Initial: 0E14; + 501760 bytes downloaded
[11:35:29] Initial: 4048; + 512000 bytes downloaded
[11:35:29] Initial: 21A5; + 522240 bytes downloaded
[11:35:29] Initial: C1A5; + 532480 bytes downloaded
[11:35:29] Initial: F716; + 542720 bytes downloaded
[11:35:29] Initial: DD98; + 552960 bytes downloaded
[11:35:29] Initial: 9F7B; + 563200 bytes downloaded
[11:35:29] Initial: 1CC0; + 573440 bytes downloaded
[11:35:29] Initial: 4D37; + 583680 bytes downloaded
[11:35:29] Initial: 222A; + 593920 bytes downloaded
[11:35:29] Initial: 8E33; + 604160 bytes downloaded
[11:35:29] Initial: D3C9; + 614400 bytes downloaded
[11:35:29] Initial: 9821; + 624640 bytes downloaded
[11:35:29] Initial: 236E; + 634880 bytes downloaded
[11:35:29] Initial: 1A7A; + 645120 bytes downloaded
[11:35:29] Initial: 6D64; + 655360 bytes downloaded
[11:35:29] Initial: 4ADC; + 665600 bytes downloaded
[11:35:29] Initial: 3854; + 675840 bytes downloaded
[11:35:29] Initial: CB5C; + 686080 bytes downloaded
[11:35:29] Initial: 2A88; + 696320 bytes downloaded
[11:35:29] Initial: 1199; + 706560 bytes downloaded
[11:35:29] Initial: 0512; + 716800 bytes downloaded
[11:35:29] Initial: 316E; + 727040 bytes downloaded
[11:35:29] Initial: D89D; + 737280 bytes downloaded
[11:35:29] Initial: E6A3; + 747520 bytes downloaded
[11:35:29] Initial: B488; + 757760 bytes downloaded
[11:35:29] Initial: BAFD; + 768000 bytes downloaded
[11:35:29] Initial: 34A0; + 778240 bytes downloaded
[11:35:29] Initial: DD6C; + 788480 bytes downloaded
[11:35:29] Initial: D2E9; + 789667 bytes downloaded
[11:35:29] Verifying core Core_a1.fah...
[11:35:29] Signature is VALID
[11:35:29]
[11:35:29] Trying to unzip core FahCore_a1.exe
[11:35:29] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[11:35:34] + Core successfully engaged
[11:35:39]
[11:35:39] + Processing work unit
[11:35:39] Work type a1 not eligible for variable processors
[11:35:39] Core required: FahCore_a1.exe
[11:35:39] Core found.
[11:35:39] Using generic mpiexec calls
[11:35:39] Working on queue slot 01 [September 3 11:35:39 UTC]
[11:35:39] + Working ...
[11:35:39] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 4572 -version 622'
[11:35:40]
[11:35:40] *------------------------------*
[11:35:40] Folding@Home Gromacs SMP Core
[11:35:40] Version 1.74 (March 10, 2007)
[11:35:40]
[11:35:40] Preparing to commence simulation
[11:35:40] - Ensuring status. Please wait.
[11:35:48] - Starting from initial work packet
[11:35:49]
[11:35:49] Project: 2665 (Run 2, Clone 516, Gen 35)
[11:35:49]
[11:35:49] M.D.
[11:35:49] ing M.D.
[11:36:05]
[11:36:05] cket
[11:36:05]
[11:36:05] Project: 2665 (Run 2, Clone 516, Gen 35)
[11:36:05]
[11:36:06] 65 (Run 2, Clone 516, Gen 35)
[11:36:06]
[11:36:06] Entering M.D.
[11:36:12] Rejecting checkpoint
[11:36:14] Protein: HGG with glycosylations
[11:36:14] Writing local files
[11:36:21] Extra SSE boost OK.
[11:36:21] Writing local files
[11:36:21] Completed 0 out of 250000 steps  (0 percent)
[11:51:22] Timered checkpoint triggered.
[11:51:47] Writing local files
[11:51:47] Completed 2500 out of 250000 steps  (1 percent)
[12:06:48] Timered checkpoint triggered.
[12:09:34] Writing local files
[12:09:34] Completed 5000 out of 250000 steps  (2 percent)
[12:24:35] Timered checkpoint triggered.
[12:27:02] Writing local files
[12:27:02] Completed 7500 out of 250000 steps  (3 percent)
[12:42:02] Timered checkpoint triggered.
[12:44:29] Writing local files
[12:44:29] Completed 10000 out of 250000 steps  (4 percent)
[12:49:38] Gromacs cannot continue further.
[12:49:38] Going to send back what have done.
[12:49:38] logfile size: 16696
[12:49:38] - Writing 17232 bytes of core data to disk...
[12:49:38]   ... Done.
[12:49:38] - Failed to delete work/wudata_01.sas
[12:49:38] - Failed to delete work/wudata_01.goe
[12:49:38] Warning:  check for stray files
[12:51:38]
[12:51:38] Folding@home Core Shutdown: EARLY_UNIT_END
[12:51:38]
[12:51:42] CoreStatus = 7B (123)
[12:51:42] Client-core communications error: ERROR 0x7b
[12:51:42] This is a sign of more serious problems, shutting down.
[17:35:09] - Autosending finished units... [September 3 17:35:09 UTC]
[17:35:09] Trying to send all finished work units
[17:35:09] + No unsent completed units remaining.
[17:35:09] - Autosend completed
--- Opening Log file [September 3 20:08:29 UTC]
[20:08:29] - Ask before connecting: No
[20:08:29] - User name: Freddy_Frog (Team 31707)
[20:08:29] - User ID:
[20:08:29] - Machine ID: 1
[20:08:29]
[20:08:29] Could not open work queue, generating new queue...
[20:08:29] - Preparing to get new work unit...
[20:08:29] - Autosending finished units... [September 3 20:08:29 UTC]
[20:08:29] + Attempting to get work packet
[20:08:29] Trying to send all finished work units
[20:08:29] - Will indicate memory of 4093 MB
[20:08:29] + No unsent completed units remaining.
[20:08:29] - Detect CPU.[20:08:29] - Autosend completed
[20:08:29] - Connecting to assignment server
[20:08:29] Connecting to http://assign.stanford.edu:8080/
[20:08:31] Posted data.
[20:08:31] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[20:08:31] + News From Folding@Home: Welcome to Folding@Home
[20:08:31] Loaded queue successfully.
[20:08:31] Connecting to http://171.64.65.64:8080/
[20:08:31] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[20:08:32] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[20:08:45] + Attempting to get work packet
[20:08:45] - Will indicate memory of 4093 MB
[20:08:45] - Connecting to assignment server
[20:08:45] Connecting to http://assign.stanford.edu:8080/
[20:08:46] Posted data.
[20:08:46] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[20:08:46] + News From Folding@Home: Welcome to Folding@Home
[20:08:46] Loaded queue successfully.
[20:08:46] Connecting to http://171.64.65.64:8080/
[20:08:52] Posted data.
[20:08:52] Initial: 0000; - Receiving payload (expected size: 4742832)
[20:09:02] - Downloaded at ~463 kB/s
[20:09:02] - Averaged speed for that direction ~463 kB/s
[20:09:02] + Received work.
[20:09:02] + Closed connections
[20:09:02]
[20:09:02] + Processing work unit
[20:09:02] Work type a1 not eligible for variable processors
[20:09:02] Core required: FahCore_a1.exe
[20:09:02] Core found.
[20:09:02] Using generic mpiexec calls
[20:09:02] Working on queue slot 01 [September 3 20:09:02 UTC]
[20:09:02] + Working ...
[20:09:02] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 4852 -version 622'
[20:09:02]
[20:09:02] *------------------------------*
[20:09:02] Folding@Home Gromacs SMP Core
[20:09:02] Version 1.74 (March 10, 2007)
[20:09:02]
[20:09:02] Preparing to commence simulation
[20:09:02] - Ensuring status. Please wait.
[20:09:02] Created dyn
[20:09:02] - Files status OK
[20:09:07] - Expanded 4742320 -> 24426905 (decompressed 515.0 percent)
[20:09:08] - Starting from initial work packet
[20:09:08]
[20:09:08] Project: 2665 (Run 3, Clone 518, Gen 47)
Re: Project: 2665 (Run 2, Clone 516, Gen 35)
There's no other reports for that WU ...
You can use qfix to submit partial results : viewtopic.php?f=8&t=191
