Project: 4596 (Run 17, Clone 108, Gen 31) Early Unit End
John Deas
Post by John Deas »
Early Unit End on p4596 - never got started.
Client: Windows CPU Console Edition
Client Version: 6.20
Core Type: Folding@Home PMD Core
Core Version: 1.03 (September 7, 2005)
Operating System: Windows XP Home v5.1.2600 SP2
CPU: AMD Sempron 3400+ x86 Family 15 Model 47 Stepping 2
Overclocked: No
Log file extract:
[07:59:01] + No unsent completed units remaining.
[07:59:01] - Preparing to get new work unit...
[07:59:01] + Attempting to get work packet
[07:59:01] - Will indicate memory of 446 MB
[07:59:01] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 15, Stepping: 2
[07:59:01] - Connecting to assignment server
[07:59:01] Connecting to http://assign.stanford.edu:8080/
[07:59:02] Posted data.
[07:59:02] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[07:59:02] + News From Folding@Home: Welcome to Folding@Home
[07:59:02] Loaded queue successfully.
[07:59:02] Connecting to http://169.230.26.30:8080/
[07:59:04] Posted data.
[07:59:04] Initial: 0000; - Receiving payload (expected size: 15175)
[07:59:04] Conversation time very short, giving reduced weight in bandwidth avg
[07:59:04] - Downloaded at ~29 kB/s
[07:59:04] - Averaged speed for that direction ~45 kB/s
[07:59:04] + Received work.
[07:59:04] Trying to send all finished work units
[07:59:04] + No unsent completed units remaining.
[07:59:04] + Closed connections
[07:59:04]
[07:59:04] + Processing work unit
[07:59:04] Core required: FahCore_82.exe
[07:59:04] Core found.
[07:59:04] Working on queue slot 08 [September 3 07:59:04 UTC]
[07:59:04] + Working ...
[07:59:04] - Calling '.\FahCore_82.exe -dir work/ -suffix 08 -checkpoint 15 -service -verbose -lifeline 1624 -version 620'
[07:59:04]
[07:59:04] *------------------------------*
[07:59:04] Folding@Home PMD Core
[07:59:04] Version 1.03 (September 7, 2005)
[07:59:04]
[07:59:04] Preparing to commence simulation
[07:59:04] - Looking at optimizations...
[07:59:04] - Created dyn
[07:59:04] - Files status OK
[07:59:05] - Expanded 14663 -> 98740 (decompressed 673.3 percent)
[07:59:05]
[07:59:05] Project: 4596 (Run 17, Clone 108, Gen 31)
[07:59:05]
[07:59:05] Assembly optimizations on if available.
[07:59:05] Entering M.D.
[07:59:11] Going to send back what have done.
[07:59:11] logfile size: 5649
[07:59:11] - Writing 6169 bytes of core data to disk...
[07:59:11]   ... Done.
[07:59:11]
[07:59:11] Folding@home Core Shutdown: EARLY_UNIT_END
[07:59:15] CoreStatus = 72 (114)
[07:59:15] Sending work to server
[07:59:15] Project: 4596 (Run 17, Clone 108, Gen 31)
[07:59:15] + Attempting to send results [September 3 07:59:15 UTC]
[07:59:15] - Reading file work/wuresults_08.dat from core
[07:59:15]   (Read 6169 bytes from disk)
[07:59:15] Connecting to http://169.230.26.30:8080/
[07:59:16] Posted data.
[07:59:16] Initial: 0000; - Uploaded at ~7 kB/s
[07:59:16] - Averaged speed for that direction ~22 kB/s
[07:59:16] + Results successfully sent
[07:59:16] Thank you for your contribution to Folding@Home.
Regards, John Deas
Re: Project: 4596 (Run 17, Clone 108, Gen 31) Early Unit End
This is probably a bad WU, thanks for the report :)
ZVdP
Post by ZVdP »
I recently had the same with 4594 (run 9, clone 72, gen 59)
[09:52:51] - Preparing to get new work unit...
[09:52:51] + Attempting to get work packet
[09:52:51] - Connecting to assignment server
[09:52:51] - Successful: assigned to (169.230.26.30).
[09:52:51] + News From Folding@Home: Welcome to Folding@Home
[09:52:52] Loaded queue successfully.
[09:52:53] + Closed connections
[09:52:53]
[09:52:53] + Processing work unit
[09:52:53] Core required: FahCore_82.exe
[09:52:53] Core found.
[09:52:53] Working on queue slot 02 [September 4 09:52:53 UTC]
[09:52:53] + Working ...
[09:52:53]
[09:52:53] *------------------------------*
[09:52:53] Folding@Home PMD Core
[09:52:53] Version 1.03 (September 7, 2005)
[09:52:53]
[09:52:53] Preparing to commence simulation
[09:52:53] - Looking at optimizations...
[09:52:53] - Created dyn
[09:52:53] - Files status OK
[09:52:53] - Expanded 19499 -> 124970 (decompressed 640.9 percent)
[09:52:53]
[09:52:53] Project: 4594 (Run 9, Clone 72, Gen 59)
[09:52:53]
[09:52:53] Assembly optimizations on if available.
[09:52:53] Entering M.D.
[09:52:59] Going to send back what have done.
[09:52:59] logfile size: 5649
[09:52:59] - Writing 6169 bytes of core data to disk...
[09:52:59]   ... Done.
[09:52:59]
[09:52:59] Folding@home Core Shutdown: EARLY_UNIT_END
[09:53:03] CoreStatus = 72 (114)
[09:53:03] Sending work to server
[09:53:03] Project: 4594 (Run 9, Clone 72, Gen 59)
[09:53:03] - Read packet limit of 540015616... Set to 524286976.
[09:53:03] + Attempting to send results [September 4 09:53:03 UTC]
[09:53:04] + Results successfully sent
[09:53:04] Thank you for your contribution to Folding@Home.
[09:53:08] - Preparing to get new work unit...
[09:53:08] + Attempting to get work packet
[09:53:08] - Connecting to assignment server
[09:53:09] - Successful: assigned to (169.230.26.30).
[09:53:09] + News From Folding@Home: Welcome to Folding@Home
[09:53:09] Loaded queue successfully.
[09:53:10] + Closed connections
