This machine has been folding for almost 3 weeks, and still has not submitted a work unit yet. They always fail. Before my trouble was with project 781, which seems to be a similar simulation, using the same core a0.
--- Opening Log file [September 1 14:49:09]
# Linux Console Edition #######################################################
Folding@Home Client Version 6.02
http://folding.stanford.edu
Launch directory: /usr/local/folding
Executable: ./fah6
[14:49:09] - Ask before connecting: No
[14:49:09] - User name: Arfyness (Team 45104)
[14:49:09] - User ID: <removed>
[14:49:09] - Machine ID: 1
[14:49:09]
[14:49:09] Loaded queue successfully.
[14:49:09]
[14:49:09] + Processing work unit
[14:49:09] Core required: FahCore_a0.exe
[14:49:09] Core found.
[14:49:09] Working on Unit 05 [September 1 14:49:09]
[14:49:09] + Working ...
[14:49:09]
[14:49:09] *------------------------------*
[14:49:09] Folding@Home Gromacs 3.3 Core
[14:49:09] Version 1.92 (April 17. 2007)
[14:49:09]
[14:49:09] Preparing to commence simulation
[14:49:09] - Looking at optimizations...
[14:49:09] - Files status OK
[14:49:10] - Expanded 1168013 -> 6252409 (decompressed 535.3 percent)
[14:49:10]
[14:49:10] Project: 782 (Run 0, Clone 77, Gen 3)
[14:49:10]
[14:49:10] Assembly optimizations on if available.
[14:49:10] Entering M.D.
No option -tpi
(single precision)
starting mdrun 'Mini chaperonin'
500000 steps, 1000.0 ps.
[14:49:31] (Starting from checkpoint)
[14:49:31] Protein: Mini chaperonin
[14:49:31] Writing local files
[14:49:31] Completed 18850 out of 500000 steps (3%)
[14:49:32] Extra 3DNow boost OK.
[14:49:32] Extra SSE boost OK.
[15:08:44] Writing local files
[15:08:44] Completed 20000 out of 500000 steps (4 percent)
< --- SNIP --- >
[00:02:29] Completed 140000 out of 500000 steps (28 percent)
[01:30:49] Writing local files
[01:30:49] Completed 145000 out of 500000 steps (29 percent)
Program Core_A0.exe, VERSION 3.3
Source code file: fatal.c, line: 342
Fatal error:
NaN detected: (ener[25])
Thanx for Using GROMACS - Have a Nice Day
[02:53:48] Gromacs error.
[02:53:48]
[02:53:48] Folding@home Core Shutdown: UNKNOWN_ERROR
[02:53:49] CoreStatus = 79 (121)
[02:53:49] Client-core communications error: ERROR 0x79
[02:53:49] Deleting current work unit & continuing...
[02:54:06] - Preparing to get new work unit...
[02:54:06] + Attempting to get work packet
[02:54:06] - Connecting to assignment server
[02:54:07] - Successful: assigned to (171.64.122.138).
[02:54:07] + News From Folding@Home: Welcome to Folding@Home
[02:54:07] Loaded queue successfully.
[02:54:12] + Closed connections
[02:54:17]
[02:54:17] + Processing work unit
[02:54:17] Core required: FahCore_a0.exe
[02:54:17] Core found.
[02:54:17] Working on Unit 06 [September 3 02:54:17]
[02:54:17] + Working ...
[02:54:17]
[02:54:17] *------------------------------*
[02:54:17] Folding@Home Gromacs 3.3 Core
[02:54:17] Version 1.92 (April 17. 2007)
[02:54:17]
[02:54:17] Preparing to commence simulation
[02:54:17] - Looking at optimizations...
[02:54:17] - Created dyn
[02:54:17] - Files status OK
[02:54:17] - Expanded 1168013 -> 6252409 (decompressed 535.3 percent)
[02:54:17] - Starting from initial work packet
[02:54:17]
[02:54:17] Project: 782 (Run 0, Clone 77, Gen 3)
[02:54:17]
[02:54:17] Assembly optimizations on if available.
[02:54:17] Entering M.D.
No option -tpi
[02:54:24] Protein: Mini chaperonin
[02:54:24] Writing local files
[02:54:24] Extra 3DNow boost OK.
[02:54:24] Extra SSE boost OK.
[02:54:25] Writing local files
[02:54:26] Completed 0 out of 500000 steps (0 percent)
[04:54:43] Writing local files
[04:54:43] Completed 5000 out of 500000 steps (1 percent)
[06:37:47] Writing local files
[06:37:47] Completed 10000 out of 500000 steps (2 percent)
Fatal error:
NaN detected: (ener[20])
[06:42:32] Gromacs error.
[06:42:32]
[06:42:32] Folding@home Core Shutdown: UNKNOWN_ERROR
[06:42:33] CoreStatus = 79 (121)
[06:42:33] Client-core communications error: ERROR 0x79
[06:42:33] Deleting current work unit & continuing...
[06:42:50] - Preparing to get new work unit...
[06:42:50] + Attempting to get work packet
[06:42:50] - Connecting to assignment server
[06:42:50] - Successful: assigned to (171.64.122.138).
[06:42:50] + News From Folding@Home: Welcome to Folding@Home
[06:42:50] Loaded queue successfully.
[06:42:55] + Closed connections
[06:43:00]
[06:43:00] + Processing work unit
[06:43:00] Core required: FahCore_a0.exe
[06:43:00] Core found.
[06:43:00] Working on Unit 07 [September 3 06:43:00]
[06:43:00] + Working ...
[06:43:00]
[06:43:00] *------------------------------*
[06:43:00] Folding@Home Gromacs 3.3 Core
[06:43:00] Version 1.92 (April 17. 2007)
[06:43:00]
[06:43:00] Preparing to commence simulation
[06:43:00] - Looking at optimizations...
[06:43:00] - Created dyn
[06:43:00] - Files status OK
[06:43:01] - Expanded 1168013 -> 6252409 (decompressed 535.3 percent)
[06:43:01] - Starting from initial work packet
[06:43:01]
[06:43:01] Project: 782 (Run 0, Clone 77, Gen 3)
[06:43:01]
[06:43:01] Assembly optimizations on if available.
[06:43:01] Entering M.D.
No option -tpi
[06:43:07] Protein: Mini chaperonin
[06:43:07] Writing local files
[06:43:08] Extra 3DNow boost OK.
[06:43:08] Extra SSE boost OK.
[06:43:09] Writing local files
[06:43:09] Completed 0 out of 500000 steps (0 percent)
[08:13:16] Writing local files
[08:13:16] Completed 5000 out of 500000 steps (1 percent)
[09:43:27] Writing local files
[09:43:28] Completed 10000 out of 500000 steps (2 percent)For what it's worth, I booted into memtest86 the other day (which Ubuntu provides in the grub menu) and all the tests finished without errors.
Getting frustrated,
- Nate
