Project: 2665 (Run3, Clone 827, Gen 25)
crosby
Post by crosby »
Got a long interactions once and a gromacs cannot continue further once on this one - and looks like its going to fail again. Using 6.22 R3 on vista.
*edit* failed again on a gromacs cannot continue further at 0%
[20:40:53] - Ask before connecting: No
[20:40:53] - User name: crosby (Team 24)
[20:40:53] - User ID: 5B76003B1D1C8B2F
[20:40:53] - Machine ID: 1
[20:40:53]
[20:40:53] Could not open work queue, generating new queue...
[20:40:53] - Preparing to get new work unit...
[20:40:53] + Attempting to get work packet
[20:40:53] - Connecting to assignment server
[20:40:54] - Couldn't send HTTP request to server
[20:40:54] + Could not connect to Assignment Server
[20:40:54] + Could not connect to Assignment Server 2
[20:40:54] + Couldn't get work instructions.
[20:40:54] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[20:41:02] + Attempting to get work packet
[20:41:02] - Connecting to assignment server
[20:41:03] - Successful: assigned to (171.64.65.64).
[20:41:03] + News From Folding@Home: Welcome to Folding@Home
[20:41:03] Loaded queue successfully.
[20:41:30] + Closed connections
[20:41:30]
[20:41:30] + Processing work unit
[20:41:30] Work type a1 not eligible for variable processors
[20:41:30] Core required: FahCore_a1.exe
[20:41:30] Core found.
[20:41:30] Using generic mpiexec calls
[20:41:30] Working on queue slot 01 [September 2 20:41:30 UTC]
[20:41:30] + Working ...
[20:41:30]
[20:41:30] *------------------------------*
[20:41:30] Folding@Home Gromacs SMP Core
[20:41:30] Version 1.74 (March 10, 2007)
[20:41:30]
[20:41:30] Preparing to commence simulation
[20:41:30] - Ensuring status. Please wait.
[20:41:35] - Starting from initial work packet
[20:41:36]
[20:41:36] Project: 2665 (Run 3, Clone 827, Gen 25)
[20:41:36]
[20:41:36] Assembly optimizations on if available.
[20:41:36] Entering M.D.
[20:42:00]  on if available.
[20:42:00] Entering M.D.
[20:42:06] Rejecting checkpoint
[20:42:07] Protein: HGG in water
[20:42:07] Writing local files
[20:42:15] Extra SSE boost OK.
[20:42:16] Writing local files
[20:42:16] Completed 0 out of 250000 steps  (0 percent)
[20:48:40] Warning:  long 1-4 interactions
[20:48:40] ed to delete work/wudata_01.arc
[20:48:40] - Failed to delete work/wudata_01.xtc
[20:48:40] - Failed to delete work/wudata_01.bed
[20:48:40] - Failed to delete work/wudata_01.sas
[20:48:40] - Failed to delete work/wudata_01.goe
[20:48:40] Warning:  check for stray files
[20:48:40]
[20:48:40] Folding@home Core Shutdown: EARLY_UNIT_END
[20:48:40] Finalizing output
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
Re: Project: 2665 (Run3, Clone 827, Gen 25)
This is probably a bad one, there is a lot of reports for partial credits in the stats DB :(
nwkelley
Pande Group Member
Post by nwkelley »
thanks guys, i'll pass it along...
VijayPande
Pande Group Member
Post by VijayPande »
We have an idea for how the server can better handle this and we're working to implement that.
GHAS
Hardware configuration: Phenom X4 9950 ,Ati HD4850 (512Mb DDR3) , 2Gb RAM -800Mhz 5-5-5-15 (2Gb)
Post by GHAS »
This happened to me too.I used the -delete x parameter on FAH.exe and after this I managed to take a new project that runs with no problems.
