Failed 3 times at 97 percent, and moved on to a different WU
model name : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
cpu MHz : 3006.892
cache size : 4096 KB
Memory: 1.96 GB physical, 1.94 GB virtual
Current Work Unit
Name: 66728 p3065_lambda5_99sb_big
Tag: P3065R2C40G79
Download time: August 31 18:57:50
Due time: September 5 04:33:50
Progress: 97% [|||||||||_]
[18:57:50] Core required: FahCore_a1.exe
[18:57:50] Core found.
[18:57:50] Working on Unit 08 [August 31 18:57:50]
[18:57:50] + Working ...
-version 602'
[18:57:50] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 24425
[18:57:50] Folding@Home Gromacs SMP Core
[18:57:50] Version 1.74 (November 27, 2006)
[18:57:51] Project: 3065 (Run 2, Clone 40, Gen 79)
[18:57:51] Assembly optimizations on if available.
[10:02:44] Completed 2325000 out of 2500000 steps (93 percent)
[10:12:30] Writing local files
[10:12:30] Completed 2350000 out of 2500000 steps (94 percent)
[10:22:14] Writing local files
[10:22:14] Completed 2375000 out of 2500000 steps (95 percent)
[10:31:55] Writing local files
[10:31:56] Completed 2400000 out of 2500000 steps (96 percent)
[10:41:37] Writing local files
[10:41:37] Completed 2425000 out of 2500000 steps (97 percent)
[10:50:18] CoreStatus = 0 (0)
[10:50:18] Client-core communications error: ERROR 0x0
[10:50:18] Deleting current work unit & continuing...
[10:54:40] - Warning: Could not delete all work unit files (8): Core returned invalid code
[10:54:40] Trying to send all finished work units
[10:54:40] + No unsent completed units remaining.
3065 (Run 2, Clone 40, Gen 79) 0x0 @ 97% 3 times
Re: 3065 (Run 2, Clone 40, Gen 79) 0x0 @ 97% 3 times
No one was able to return this one yet ...
