Fahmon Hung issue
racing4mat
Fahmon Hung issue
Post by racing4mat »
Fahmon is running in 2 PCs for 2 months perfectly. The PCs are networked and I run Fahmon on each PC, but on the 1st I'm monitoring the clients of the other too.
Today it decided to hung on both PCs the same time! I have noticed it hunged all clients since the date was changed to 1 Sep at 12:00AM. I can see only the progress, a Hung and no PPDs even if I check the Ignore asychronous clocks option in prefs. Is anyone else having the same issue?
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Re: Fahmon Hung issue
Post by John Naylor »
I've just got that too... BST [UTC+1] here.
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
HuntWarrior
Hardware configuration: Windows 7 intel Ci7 2.80 Ghz + HD6700
Post by HuntWarrior »
So did I !
Folding for a cure for Huntington's Disease! Team 46113 since 2004 pls look at http://en.hdbuzz.net/ so far in 13 languages and http://hdyo.org in English, Spanish and German so far, interperters are welcome!
uncle_fungus
Post by uncle_fungus »
Yeah, I think this is a known issue that happens at the end of each month. Don't know precisely why though.
metal03326
Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz)
Post by metal03326 »
Same here. I don't remember having such a problem last month. My FahMon version is 2.3.2b. I hope this will be fixed in the next version.
That's funny ... fahmon can't monitor any client between midnight and 2am every 1st of a month :lol:
PeterA
Hardware configuration: PC: AMD Sempron(tm) Processor 2800+, 1024 MB RAM, Microsoft Windows XP (Home Edition) SP3
Laptop: Mobile AMD Sempron(tm) Processor 3500+, 896 MB RAM, Microsoft Windows Vista (Home Premium)
Post by PeterA »
:shock: I guess I'll have to close Fahmon before I go to bed! 8-)
Is this a new problem? Because I don't recall this happening before. :e?:
BrownBullhead
Post by BrownBullhead »
PeterA: Why not just close FahMon [2.3.2b] most of the time, and keep it open only when you are at your computer? You can avoid the "first of the month" crash. :)
racing4mat
Thank you all for your answers, that's really helpful for the programmer too to fix it.
Fahmon is a great tool and must be supported and improved.
John Naylor
@BrownBullhead lol.... I left it running and FahMon woke up then started working normally again after 2am (as toTOW said), so it isn't a crash as such.
Flathead74
Post by Flathead74 »
Or, display, if you wish, and configure FahMon to refresh when you press F6.
This won't get rid of the reported problem, though.
PeterA
Post by PeterA »
BrownBullhead wrote:PeterA: Why not just close FahMon [2.3.2b] most of the time, and keep it open only when you are at your computer? You can avoid the "first of the month" crash. :)
I have never experienced a "first of the month" crash before. :? In fact, I have never experienced any problem with keeping it running. It's nice to be able to just click on the icon in the tray and see how all my folding is doing. :D If it's not broken, why fix it?
