Project: 3064 (Run 2, Clone 52, Gen 89) - ERROR 0x0 frame 60
Post by 314159 »
Quad Q6600-Linux Client-Stock Clock-Single Instance running.
Depressing. :e(
[05:25:11] + Processing work unit
[05:25:11] Core required: FahCore_a1.exe
[05:25:11] Core found.
[05:25:11] Working on Unit 01 [August 30 05:25:11]
[05:25:11] + Working ...
[05:25:11] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -forceasm -verbose -lifeline 5510 -version 602'
[05:25:12]
[05:25:12] *------------------------------*
[05:25:12] Folding@Home Gromacs SMP Core
[05:25:12] Version 1.74 (November 27, 2006)
[05:25:12]
[05:25:12] Preparing to commence simulation
[05:25:12] - Ensuring status. Please wait.
[05:25:29] - Assembly optimizations manually forced on.
[05:25:29] - Not checking prior termination.
[05:25:29] - Expanded 609927 -> 3263429 (decompressed 535.0 percent)
[05:25:29] - Starting from initial work packet
[05:25:29]
[05:25:29] Project: 3064 (Run 2, Clone 52, Gen 89)
[05:25:29]
[05:25:29] Assembly optimizations on if available.
[05:25:29] Entering M.D.
[05:25:35] Rejecting checkpoint
[05:25:35] Protein: p3064_lambda5_2003Extra SSE boost OK.
[05:25:35]
[05:25:35] Extra SSE boost OK.
[05:25:35] Writing local files
[05:25:35] Completed 0 out of 5000000 steps  (0 percent)
[05:39:48] Writing local files
[05:39:48] Completed 50000 out of 5000000 steps  (1 percent)
[05:53:58] Writing local files
[21:39:32] Writing local files
[21:39:32] Completed 3400000 out of 5000000 steps  (68 percent)
[21:40:03] CoreStatus = 0 (0)
[21:40:03] Client-core communications error: ERROR 0x0
[21:40:03] Deleting current work unit & continuing...
Has anyone completed this one to date?
I might mention that I am experiencing problems with the new a2 Core on some other machines.
John (from the central part of the Commonwealth of Virginia, U.S.A.)
A friendly visitor to what hopefully will remain a friendly Forum.
With thanks to all of the dedicated volunteers on the staff here!!
Re: Project: 3064 (Run 2, Clone 52, Gen 89) - ERROR 0x0 frame 60
No data for this WU in the stats DB :(
