Project: 2665 (Run 0, Clone 667, Gen 40) - ERROR 0x0
Post by 314159 »
Linux Quad - Stock Clock - and, - Duh! - running single SMP instance, as all my Quads are, of course. :)
[11:38:45] Working on Unit 01 [August 27 11:38:45]
[11:38:45] + Working ...
[11:38:45] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -forceasm -verbose -lifeline 5847 -version 602'
[11:38:45]
[11:38:45] *------------------------------*
[11:38:45] Folding@Home Gromacs SMP Core
[11:38:45] Version 1.74 (November 27, 2006)
[11:38:45]
[11:38:45] Preparing to commence simulation
[11:38:45] - Ensuring status. Please wait.
[11:39:02] - Assembly optimizations manually forced on.
[11:39:02] - Not checking prior termination.
[11:39:03] - Expanded 4727499 -> 24426905 (decompressed 516.6 percent)
[11:39:03] - Starting from initial work packet
[11:39:03]
[11:39:03] Project: 2665 (Run 0, Clone 667, Gen 40)
[11:39:03]
[11:39:03] Assembly optimizations on if available.
[11:39:03] Entering M.D.
[11:39:09] Rejecting checkpoint
[11:39:10]
[11:39:11] rotein: HGG in waterExtra SSE boost OK.
[11:39:11]
[11:39:11] Extra SSE boost OK.
[11:39:12] Writing local files
[11:39:12] Completed 0 out of 250000 steps  (0 percent)
[11:52:55] Warning:  long 1-4 interactions
[11:53:00] CoreStatus = 0 (0)
[11:53:00] Client-core communications error: ERROR 0x0
[11:53:00] Deleting current work unit & continuing...
[11:57:21] - Warning: Could not delete all work unit files (1): Core returned invalid code
[11:57:21] Trying to send all finished work units
[11:57:21] + No unsent completed units remaining.
[11:57:21] - Preparing to get new work unit...
[11:57:21] + Attempting to get work packet
[11:57:21] - Will indicate memory of 1024 MB
[11:57:21] - Connecting to assignment server
[11:57:21] Connecting to http://assign.stanford.edu:8080/
[11:57:22] Posted data.
[11:57:22] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[11:57:22] + News From Folding@Home: Welcome to Folding@Home
[11:57:22] Loaded queue successfully.
[11:57:22] Connecting to http://171.64.65.64:8080/
[11:57:27] Posted data.
[11:57:27] Initial: 0000; - Receiving payload (expected size: 4728011)
[11:57:30] - Downloaded at ~1539 kB/s
[11:57:30] - Averaged speed for that direction ~1329 kB/s
[11:57:30] + Received work.
[11:57:30] + Closed connections
[11:57:35]
[11:57:35] + Processing work unit
[11:57:35] Core required: FahCore_a1.exe
[11:57:35] Core found.
[11:57:35] Working on Unit 02 [August 27 11:57:35]
[11:57:35] + Working ...
[11:57:35] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 02 -checkpoint 15 -forceasm -verbose -lifeline 5847 -version 602'
[11:57:35]
[11:57:35] *------------------------------*
[11:57:35] Folding@Home Gromacs SMP Core
[11:57:35] Version 1.74 (November 27, 2006)
[11:57:35]
[11:57:35] Preparing to commence simulation
[11:57:35] - Ensuring status. Please wait.
[11:57:53] - Assembly optimizations manually forced on.
[11:57:53] - Not checking prior termination.
[11:57:53] - Expanded 4727499 -> 24426905 (decompressed 516.6 percent)
[11:57:54] - Starting from initial work packet
[11:57:54]
[11:57:54] Project: 2665 (Run 0, Clone 667, Gen 40)
[11:57:54]
[11:57:54] Assembly optimizations on if available.
[11:57:54] Entering M.D.
[11:58:00] Rejecting checkpoint
[11:58:01] Protein: HGG in water
[11:58:01] xtra SSE boost OK.
[11:58:01]
[11:58:02] Extra SSE boost OK.
[11:58:02] Writing local files
[11:58:02] Completed 0 out of 250000 steps  (0 percent)
[12:11:50] Warning:  long 1-4 interactions
[12:11:55] CoreStatus = 0 (0)
[12:11:55] Client-core communications error: ERROR 0x0
[12:11:55] Deleting current work unit & continuing...
[12:16:17] - Warning: Could not delete all work unit files (2): Core returned invalid code
[12:16:17] Trying to send all finished work units
[12:16:17] + No unsent completed units remaining.
[12:16:17] - Preparing to get new work unit...
[12:16:17] + Attempting to get work packet
[12:16:17] - Will indicate memory of 1024 MB
[12:16:17] - Connecting to assignment server
[12:16:17] Connecting to http://assign.stanford.edu:8080/
[12:16:17] Posted data.
[12:16:17] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[12:16:17] + News From Folding@Home: Welcome to Folding@Home
[12:16:17] Loaded queue successfully.
[12:16:17] Connecting to http://171.64.65.63:8080/
[12:16:18] Posted data.
[12:16:18] Initial: 0000; - Receiving payload (expected size: 609413)
[12:16:19] - Downloaded at ~595 kB/s
[12:16:19] - Averaged speed for that direction ~1182 kB/s
[12:16:19] + Received work.
[12:16:19] + Closed connections
[12:16:24]
[12:16:24] + Processing work unit
[12:16:24] Core required: FahCore_a1.exe
[12:16:24] Core found.
[12:16:24] Working on Unit 03 [August 27 12:16:24]
[12:16:24] + Working ...
[12:16:24] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline 5847 -version 602'
[12:16:24]
[12:16:24] *------------------------------*
[12:16:24] Folding@Home Gromacs SMP Core
[12:16:24] Version 1.74 (November 27, 2006)
[12:16:24]
[12:16:24] Preparing to commence simulation
[12:16:24] - Ensuring status. Please wait.
[12:16:42] - Assembly optimizations manually forced on.
[12:16:42] - Not checking prior termination.
[12:16:42] - Expanded 608901 -> 3260933 (decompressed 535.5 percent)
[12:16:42] - Starting from initial work packet
[12:16:42]
[12:16:42] Project: 3064 (Run 5, Clone 59, Gen 95)
[12:16:42]
[12:16:42] Assembly optimizations on if available.
[12:16:42] Entering M.D.
[12:16:48] Rejecting checkpoint
[12:16:48] Protein: p3064_lambda5_2003Extra SSE boost OK.
[12:16:48]
[12:16:48] Extra SSE boost OK.
[12:16:48] Writing local files
[12:16:48] Completed 0 out of 5000000 steps  (0 percent)
[12:27:05] Writing local files
[12:27:05] Completed 50000 out of 5000000 steps  (1 percent)
[12:37:14] Writing local files
[12:37:14] Completed 100000 out of 5000000 steps  (2 percent)
[12:47:18] Writing local files
etc.
R/C/G look familiar.
Has this been reported previously?
Has this one been completed by anyone to date?
Thanks Guys (and Gals). :)
John (from the central part of the Commonwealth of Virginia, U.S.A.)
A friendly visitor to what hopefully will remain a friendly Forum.
With thanks to all of the dedicated volunteers on the staff here!!
Re: Project: 2665 (Run 0, Clone 667, Gen 40)
Two reports for partial credit.
314159
Re: Project: 2665 (Run 0, Clone 667, Gen 40) - ERROR 0x0
Post by 314159 »
Thank you. Especially for the addition of the -ERROR 0x0 to the thread topic.
That is an excellent idea!
You're getting very good at the lookups. :)
