Project: 2665 (Run 3, Clone 325, Gen 36)
lobuxracer
Post by lobuxracer »
One of my folders is choking on this one, and couldn't find an existing thread on it. Seven times in a row? Seems odd. The other SMP instance on this machine is working perfectly so I am not doubting my hardware. Machine is Gigabyte P35-DS3L w/Q6600 @ 3.195 GHz fully patched Win2K Server OS (file and print services) with zero users all day (no one home). Running extended life 5.91 client. Log included, but had to trim a little from the top:
[23:53:36] Completed 4950000 out of 5000000 steps  (99 percent)
[00:08:25] -
[00:08:25] Completed 5000000 out of 5000000 steps  (100 percent)
[00:08:25] Writing final coordinates.
[00:08:25] Past main M.D. loop
[00:08:25] Will end MPI now
[00:09:25]
[00:09:25] Finished Work Unit:
[00:09:25] - Reading up to 518424 from "work/wudata_01.arc": Read 518424
[00:09:25] - Reading up to 976404 from "work/wudata_01.xtc": Read 976404
[00:09:25] goefile size: 0
[00:09:25] logfile size: 149650
[00:09:25] Leaving Run
[00:09:28] - Writing 1846514 bytes of core data to disk...
[00:09:28]   ... Done.
[00:09:28] - Failed to delete work/wudata_01.sas
[00:09:28] - Failed to delete work/wudata_01.goe
[00:09:28] Warning:  check for stray files
[00:09:28] - Shutting down core
[00:11:28]
[00:11:28] Folding@home Core Shutdown: FINISHED_UNIT
[00:11:28]
[00:11:32] CoreStatus = 64 (100)
[00:11:32] Sending work to server
[00:11:32] + Attempting to send results
[00:11:43] + Results successfully sent
[00:11:43] Thank you for your contribution to Folding@Home.
[00:11:43] + Number of Units Completed: 5
[00:13:47] - Preparing to get new work unit...
[00:13:47] + Attempting to get work packet
[00:13:47] - Connecting to assignment server
[00:13:47] - Successful: assigned to (171.64.65.64).
[00:13:47] + News From Folding@Home: Welcome to Folding@Home
[00:13:48] Loaded queue successfully.
[00:14:05] + Closed connections
[00:14:05]
[00:14:05] + Processing work unit
[00:14:05] Core required: FahCore_a1.exe
[00:14:05] Core found.
[00:14:05] Working on Unit 02 [August 22 00:14:05]
[00:14:05] + Working ...
[00:14:05]
[00:14:05] *------------------------------*
[00:14:05] Folding@Home Gromacs SMP Core
[00:14:05] Version 1.74 (March 10, 2007)
[00:14:05]
[00:14:05] Preparing to commence simulation
[00:14:05] - Ensuring status. Please wait.
[00:14:10] - Starting from initial work packet
[00:14:10]
[00:14:10] Project: 2665 (Run 3, Clone 325, Gen 36)
[00:14:10]
[00:14:11] Assembly optimizations on if available.
[00:14:11] Entering M.D.
[00:14:34] al work packet
[00:14:34]
[00:14:34] Project: 2665 (Run 3, Clone 325, Gen 36)
[00:14:34]
[00:14:35] 65 (Run 3, Clone 325, Gen 36)
[00:14:35]
[00:14:37] Entering M.D.
[00:14:43] Rejecting checkpoint
[00:14:44] Protein: HGG in water
[00:14:44] -
[00:14:52] Extra SSE boost OK.
[00:14:52] -
[00:14:53] Completed 0 out of 250000 steps  (0 percent)
[00:31:38] -
[00:31:39] Completed 2500 out of 250000 steps  (1 percent)
[00:48:38] -
[00:48:39] Completed 5000 out of 250000 steps  (2 percent)
[01:05:39] -
[01:05:40] Completed 7500 out of 250000 steps  (3 percent)
[01:22:40] -
[01:22:41] Completed 10000 out of 250000 steps  (4 percent)
[01:39:41] -
[01:39:41] Completed 12500 out of 250000 steps  (5 percent)
[01:56:41] -
[01:56:42] Completed 15000 out of 250000 steps  (6 percent)
[02:13:42] -
[02:13:43] Completed 17500 out of 250000 steps  (7 percent)
[02:30:43] -
[02:30:44] Completed 20000 out of 250000 steps  (8 percent)
[02:47:45] -
[02:47:46] Completed 22500 out of 250000 steps  (9 percent)
[03:04:47] -
[03:04:48] Completed 25000 out of 250000 steps  (10 percent)
[03:21:48] -
[03:21:49] Completed 27500 out of 250000 steps  (11 percent)
[03:38:49] -
[03:38:50] Completed 30000 out of 250000 steps  (12 percent)
[03:55:51] -
[03:55:51] Completed 32500 out of 250000 steps  (13 percent)
[04:12:53] -
[04:12:54] Completed 35000 out of 250000 steps  (14 percent)
[04:29:56] -
[04:29:56] Completed 37500 out of 250000 steps  (15 percent)
[04:46:59] -
[04:46:59] Completed 40000 out of 250000 steps  (16 percent)
[05:04:03] -
[05:04:03] Completed 42500 out of 250000 steps  (17 percent)
[05:21:08] -
[05:21:08] Completed 45000 out of 250000 steps  (18 percent)
[05:38:11] -
[05:38:11] Completed 47500 out of 250000 steps  (19 percent)
[05:55:12] -
[05:55:13] Completed 50000 out of 250000 steps  (20 percent)
[06:12:19] -
[06:12:20] Completed 52500 out of 250000 steps  (21 percent)
[06:29:22] -
[06:29:23] Completed 55000 out of 250000 steps  (22 percent)
[06:46:24] -
[06:46:25] Completed 57500 out of 250000 steps  (23 percent)
[07:03:25] -
[07:03:25] Completed 60000 out of 250000 steps  (24 percent)
[07:20:26] -
[07:20:26] Completed 62500 out of 250000 steps  (25 percent)
[07:37:28] -
[07:37:29] Completed 65000 out of 250000 steps  (26 percent)
[07:54:30] -
[07:54:30] Completed 67500 out of 250000 steps  (27 percent)
[08:11:32] -
[08:11:32] Completed 70000 out of 250000 steps  (28 percent)
[08:28:32] -
[08:28:33] Completed 72500 out of 250000 steps  (29 percent)
[08:45:33] -
[08:45:34] Completed 75000 out of 250000 steps  (30 percent)
[09:02:32] -
[09:02:33] Completed 77500 out of 250000 steps  (31 percent)
[09:19:31] -
[09:19:32] Completed 80000 out of 250000 steps  (32 percent)
[09:36:32] -
[09:36:33] Completed 82500 out of 250000 steps  (33 percent)
[09:53:32] -
[09:53:33] Completed 85000 out of 250000 steps  (34 percent)
[10:10:32] -
[10:10:33] Completed 87500 out of 250000 steps  (35 percent)
[10:27:31] -
[10:27:32] Completed 90000 out of 250000 steps  (36 percent)
[10:44:31] -
[10:44:32] Completed 92500 out of 250000 steps  (37 percent)
[11:01:32] -
[11:01:33] Completed 95000 out of 250000 steps  (38 percent)
[11:18:32] -
[11:18:33] Completed 97500 out of 250000 steps  (39 percent)
[11:35:31] -
[11:35:32] Completed 100000 out of 250000 steps  (40 percent)
[11:39:14] Gromacs cannot continue further.
[11:39:14] Going to send back what have done.
[11:39:14] logfile size: 84069
[11:39:14] - Writing 84605 bytes of core data to disk...
[11:39:14]   ... Done.
[11:39:16] - Failed to delete work/wudata_02.sas
[11:39:16] - Failed to delete work/wudata_02.goe
[11:39:16] Warning:  check for stray files
[11:41:16]
[11:41:16] Folding@home Core Shutdown: EARLY_UNIT_END
[11:41:16]
[11:41:19] CoreStatus = 7B (123)
[11:41:19] Client-core communications error: ERROR 0x7b
[11:41:19] Deleting current work unit & continuing...
[11:43:23] - Preparing to get new work unit...
[11:43:23] + Attempting to get work packet
[11:43:23] - Connecting to assignment server
[11:43:24] - Successful: assigned to (171.64.65.64).
[11:43:24] + News From Folding@Home: Welcome to Folding@Home
[11:43:24] Loaded queue successfully.
[11:43:37] + Closed connections
[11:43:42]
[11:43:42] + Processing work unit
[11:43:42] Core required: FahCore_a1.exe
[11:43:42] Core found.
[11:43:42] Working on Unit 03 [August 22 11:43:42]
[11:43:42] + Working ...
[11:43:42]
[11:43:42] *------------------------------*
[11:43:42] Folding@Home Gromacs SMP Core
[11:43:42] Version 1.74 (March 10, 2007)
[11:43:42]
[11:43:42] Preparing to commence simulation
[11:43:42] - Ensuring status. Please wait.
[11:43:47] - Starting from initial work packet
[11:43:47]
[11:43:47] Project: 2665 (Run 3, Clone 325, Gen 36)
[11:43:47]
[11:43:48] Assembly optimizations on if available.
[11:43:48] Entering M.D.
[11:44:10] al work packet
[11:44:10]
[11:44:10] Project: 2665 (Run 3, Clone 325, Gen 36)
[11:44:10]
[11:44:10] 65 (Run 3, Clone 325, Gen 36)
[11:44:10]
[11:44:12] Entering M.D.
[11:44:18] Rejecting checkpoint
[11:44:19] Protein: HGG in water
[11:44:20] -
[11:44:27] Extra SSE boost OK.
[11:44:27] -
[11:44:28] Completed 0 out of 250000 steps  (0 percent)
[12:01:08] -
[12:01:08] Completed 2500 out of 250000 steps  (1 percent)
[12:18:08] -
[12:18:09] Completed 5000 out of 250000 steps  (2 percent)
[12:35:09] -
[12:35:10] Completed 7500 out of 250000 steps  (3 percent)
[12:52:13] -
[12:52:14] Completed 10000 out of 250000 steps  (4 percent)
[13:09:15] -
[13:09:16] Completed 12500 out of 250000 steps  (5 percent)
[13:26:15] -
[13:26:16] Completed 15000 out of 250000 steps  (6 percent)
[13:43:16] -
[13:43:17] Completed 17500 out of 250000 steps  (7 percent)
[14:00:16] -
[14:00:17] Completed 20000 out of 250000 steps  (8 percent)
[14:17:19] -
[14:17:20] Completed 22500 out of 250000 steps  (9 percent)
[14:34:19] -
[14:34:20] Completed 25000 out of 250000 steps  (10 percent)
[14:51:22] -
[14:51:23] Completed 27500 out of 250000 steps  (11 percent)
[15:08:24] -
[15:08:25] Completed 30000 out of 250000 steps  (12 percent)
[15:25:26] -
[15:25:27] Completed 32500 out of 250000 steps  (13 percent)
[15:42:27] -
[15:42:28] Completed 35000 out of 250000 steps  (14 percent)
[15:59:29] -
[15:59:30] Completed 37500 out of 250000 steps  (15 percent)
[16:16:32] -
[16:16:33] Completed 40000 out of 250000 steps  (16 percent)
[16:33:35] -
[16:33:36] Completed 42500 out of 250000 steps  (17 percent)
[16:50:38] -
[16:50:39] Completed 45000 out of 250000 steps  (18 percent)
[17:07:42] -
[17:07:43] Completed 47500 out of 250000 steps  (19 percent)
[17:24:46] -
[17:24:47] Completed 50000 out of 250000 steps  (20 percent)
[17:41:49] -
[17:41:50] Completed 52500 out of 250000 steps  (21 percent)
[17:58:53] -
[17:58:53] Completed 55000 out of 250000 steps  (22 percent)
[18:15:55] -
[18:15:56] Completed 57500 out of 250000 steps  (23 percent)
[18:32:56] -
[18:32:57] Completed 60000 out of 250000 steps  (24 percent)
[18:49:59] -
[18:50:00] Completed 62500 out of 250000 steps  (25 percent)
[19:07:03] -
[19:07:03] Completed 65000 out of 250000 steps  (26 percent)
[19:24:04] -
[19:24:05] Completed 67500 out of 250000 steps  (27 percent)
[19:41:06] -
[19:41:07] Completed 70000 out of 250000 steps  (28 percent)
[19:58:35] -
[19:58:36] Completed 72500 out of 250000 steps  (29 percent)
[20:15:36] -
[20:15:37] Completed 75000 out of 250000 steps  (30 percent)
[20:32:36] -
[20:32:37] Completed 77500 out of 250000 steps  (31 percent)
[20:49:36] -
[20:49:37] Completed 80000 out of 250000 steps  (32 percent)
[21:06:36] -
[21:06:37] Completed 82500 out of 250000 steps  (33 percent)
[21:23:36] -
[21:23:37] Completed 85000 out of 250000 steps  (34 percent)
[21:40:36] -
[21:40:37] Completed 87500 out of 250000 steps  (35 percent)
[21:57:36] -
[21:57:37] Completed 90000 out of 250000 steps  (36 percent)
[22:14:35] -
[22:14:36] Completed 92500 out of 250000 steps  (37 percent)
[22:31:37] -
[22:31:37] Completed 95000 out of 250000 steps  (38 percent)
[22:48:36] -
[22:48:37] Completed 97500 out of 250000 steps  (39 percent)
[23:05:35] -
[23:05:36] Completed 100000 out of 250000 steps  (40 percent)
[23:09:18] Gromacs cannot continue further.
[23:09:18] Going to send back what have done.
[23:09:18] logfile size: 84069
[23:09:18] - Writing 84605 bytes of core data to disk...
[23:09:18]   ... Done.
[23:09:20] - Failed to delete work/wudata_03.sas
[23:09:20] - Failed to delete work/wudata_03.goe
[23:09:20] Warning:  check for stray files
[23:11:20]
[23:11:20] Folding@home Core Shutdown: EARLY_UNIT_END
[23:11:20]
[23:11:24] CoreStatus = 7B (123)
[23:11:24] Client-core communications error: ERROR 0x7b
[23:11:24] Deleting current work unit & continuing...
[23:13:28] - Preparing to get new work unit...
[23:13:28] + Attempting to get work packet
[23:13:28] - Connecting to assignment server
[23:13:28] - Successful: assigned to (171.64.65.63).
[23:13:28] + News From Folding@Home: Welcome to Folding@Home
[23:13:29] Loaded queue successfully.
[23:13:31] + Closed connections
[23:13:36]
[23:13:36] + Processing work unit
[23:13:36] Core required: FahCore_a1.exe
[23:13:36] Core found.
[23:13:36] Working on Unit 04 [August 22 23:13:36]
[23:13:36] + Working ...
[23:13:36]
[23:13:36] *------------------------------*
[23:13:36] Folding@Home Gromacs SMP Core
[23:13:36] Version 1.74 (March 10, 2007)
[23:13:36]
[23:13:36] Preparing to commence simulation
[23:13:36] - Ensuring status. Please wait.
[23:13:37] - Starting from initial work packet
[23:13:37]
[23:13:37] Project: 3062 (Run 2, Clone 129, Gen 46)
[23:13:37]
[23:13:37] Assembly optimizations on if available.
[23:13:37] Entering M.D.
[23:13:54]  percent)
[23:13:54] - Starting from initial work packet
[23:13:54]
[23:13:54] Project: 30Entering M.D.
[23:13:54] ne 129, Gen 46)
[23:13:54]
[23:13:54] Entering M.D.
[23:14:00] Rejecting checkpoint
[23:14:00] a SSE boost OK.
[23:14:00] ambda5_99sbExtra SSE boost OK.
[23:14:00]
[23:14:00] Extra SSE boost OK.
[23:14:00] -
[23:14:00] Completed 0 out of 5000000 steps  (0 percent)
[23:27:22] -
[23:27:22] Completed 50000 out of 5000000 steps  (1 percent)
[23:42:08] -
[23:42:08] Completed 100000 out of 5000000 steps  (2 percent)
[23:56:55] -
[23:56:55] Completed 150000 out of 5000000 steps  (3 percent)
[00:11:41] -
[00:11:41] Completed 200000 out of 5000000 steps  (4 percent)
[00:26:26] -
[00:26:26] Completed 250000 out of 5000000 steps  (5 percent)
[00:41:12] -
[00:41:12] Completed 300000 out of 5000000 steps  (6 percent)
[00:55:58] -
[00:55:58] Completed 350000 out of 5000000 steps  (7 percent)
[01:10:45] -
[01:10:45] Completed 400000 out of 5000000 steps  (8 percent)
[01:25:31] -
[01:25:31] Completed 450000 out of 5000000 steps  (9 percent)
[01:40:15] -
[01:40:15] Completed 500000 out of 5000000 steps  (10 percent)
[01:55:00] -
[01:55:00] Completed 550000 out of 5000000 steps  (11 percent)
[02:09:46] -
[02:09:46] Completed 600000 out of 5000000 steps  (12 percent)
[02:24:32] -
[02:24:32] Completed 650000 out of 5000000 steps  (13 percent)
[02:39:18] -
[02:39:18] Completed 700000 out of 5000000 steps  (14 percent)
[02:54:04] -
[02:54:04] Completed 750000 out of 5000000 steps  (15 percent)
[03:08:51] -
[03:08:51] Completed 800000 out of 5000000 steps  (16 percent)
[03:23:38] -
[03:23:38] Completed 850000 out of 5000000 steps  (17 percent)
[03:38:24] -
[03:38:24] Completed 900000 out of 5000000 steps  (18 percent)
[03:53:10] -
[03:53:10] Completed 950000 out of 5000000 steps  (19 percent)
[04:07:57] -
[04:07:57] Completed 1000000 out of 5000000 steps  (20 percent)
[04:22:42] -
[04:22:42] Completed 1050000 out of 5000000 steps  (21 percent)
[04:37:29] -
[04:37:29] Completed 1100000 out of 5000000 steps  (22 percent)
[04:52:15] -
[04:52:15] Completed 1150000 out of 5000000 steps  (23 percent)
[05:07:05] -
[05:07:05] Completed 1200000 out of 5000000 steps  (24 percent)
[05:21:51] -
[05:21:51] Completed 1250000 out of 5000000 steps  (25 percent)
[05:36:35] -
[05:36:35] Completed 1300000 out of 5000000 steps  (26 percent)
[05:51:21] -
[05:51:21] Completed 1350000 out of 5000000 steps  (27 percent)
[06:06:10] -
[06:06:10] Completed 1400000 out of 5000000 steps  (28 percent)
[06:20:57] -
[06:20:57] Completed 1450000 out of 5000000 steps  (29 percent)
[06:35:44] -
[06:35:44] Completed 1500000 out of 5000000 steps  (30 percent)
[06:50:31] -
[06:50:31] Completed 1550000 out of 5000000 steps  (31 percent)
[07:05:18] -
[07:05:18] Completed 1600000 out of 5000000 steps  (32 percent)
[07:20:04] -
[07:20:04] Completed 1650000 out of 5000000 steps  (33 percent)
[07:34:51] -
[07:34:51] Completed 1700000 out of 5000000 steps  (34 percent)
[07:49:37] -
[07:49:37] Completed 1750000 out of 5000000 steps  (35 percent)
[08:04:24] -
[08:04:24] Completed 1800000 out of 5000000 steps  (36 percent)
[08:19:11] -
[08:19:11] Completed 1850000 out of 5000000 steps  (37 percent)
[08:33:56] -
[08:33:56] Completed 1900000 out of 5000000 steps  (38 percent)
[08:48:42] -
[08:48:42] Completed 1950000 out of 5000000 steps  (39 percent)
[09:03:27] -
[09:03:27] Completed 2000000 out of 5000000 steps  (40 percent)
[09:18:14] -
[09:18:14] Completed 2050000 out of 5000000 steps  (41 percent)
[09:33:01] -
[09:33:01] Completed 2100000 out of 5000000 steps  (42 percent)
[09:47:48] -
[09:47:48] Completed 2150000 out of 5000000 steps  (43 percent)
[10:02:33] -
[10:02:33] Completed 2200000 out of 5000000 steps  (44 percent)
[10:17:19] -
[10:17:19] Completed 2250000 out of 5000000 steps  (45 percent)
[10:32:05] -
[10:32:05] Completed 2300000 out of 5000000 steps  (46 percent)
[10:46:51] -
[10:46:51] Completed 2350000 out of 5000000 steps  (47 percent)
[11:01:39] -
[11:01:39] Completed 2400000 out of 5000000 steps  (48 percent)
[11:16:27] -
[11:16:27] Completed 2450000 out of 5000000 steps  (49 percent)
[11:31:13] -
[11:31:13] Completed 2500000 out of 5000000 steps  (50 percent)
[11:46:00] -
[11:46:00] Completed 2550000 out of 5000000 steps  (51 percent)
[12:00:46] -
[12:00:46] Completed 2600000 out of 5000000 steps  (52 percent)
[12:15:32] -
[12:15:32] Completed 2650000 out of 5000000 steps  (53 percent)
[12:30:16] -
[12:30:16] Completed 2700000 out of 5000000 steps  (54 percent)
[12:45:01] -
[12:45:01] Completed 2750000 out of 5000000 steps  (55 percent)
[12:59:46] -
[12:59:46] Completed 2800000 out of 5000000 steps  (56 percent)
[13:14:33] -
[13:14:33] Completed 2850000 out of 5000000 steps  (57 percent)
[13:29:22] -
[13:29:22] Completed 2900000 out of 5000000 steps  (58 percent)
[13:44:10] -
[13:44:10] Completed 2950000 out of 5000000 steps  (59 percent)
[13:58:58] -
[13:58:58] Completed 3000000 out of 5000000 steps  (60 percent)
[14:13:45] -
[14:13:45] Completed 3050000 out of 5000000 steps  (61 percent)
[14:28:32] -
[14:28:32] Completed 3100000 out of 5000000 steps  (62 percent)
[14:43:20] -
[14:43:20] Completed 3150000 out of 5000000 steps  (63 percent)
[14:58:08] -
[14:58:08] Completed 3200000 out of 5000000 steps  (64 percent)
[15:12:54] -
[15:12:54] Completed 3250000 out of 5000000 steps  (65 percent)
[15:27:40] -
[15:27:40] Completed 3300000 out of 5000000 steps  (66 percent)
[15:42:26] -
[15:42:26] Completed 3350000 out of 5000000 steps  (67 percent)
[15:57:10] -
[15:57:10] Completed 3400000 out of 5000000 steps  (68 percent)
[16:11:56] -
[16:11:56] Completed 3450000 out of 5000000 steps  (69 percent)
[16:26:44] -
[16:26:44] Completed 3500000 out of 5000000 steps  (70 percent)
[16:41:30] -
[16:41:31] Completed 3550000 out of 5000000 steps  (71 percent)
[16:56:17] -
[16:56:17] Completed 3600000 out of 5000000 steps  (72 percent)
[17:11:05] -
[17:11:05] Completed 3650000 out of 5000000 steps  (73 percent)
[17:25:52] -
[17:25:52] Completed 3700000 out of 5000000 steps  (74 percent)
[17:40:38] -
[17:40:38] Completed 3750000 out of 5000000 steps  (75 percent)
[17:55:24] -
[17:55:24] Completed 3800000 out of 5000000 steps  (76 percent)
[18:10:12] -
[18:10:12] Completed 3850000 out of 5000000 steps  (77 percent)
[18:24:57] -
[18:24:57] Completed 3900000 out of 5000000 steps  (78 percent)
[18:39:43] -
[18:39:43] Completed 3950000 out of 5000000 steps  (79 percent)
[18:54:29] -
[18:54:29] Completed 4000000 out of 5000000 steps  (80 percent)
[19:09:16] -
[19:09:16] Completed 4050000 out of 5000000 steps  (81 percent)
[19:24:02] -
[19:24:02] Completed 4100000 out of 5000000 steps  (82 percent)
[19:38:48] -
[19:38:48] Completed 4150000 out of 5000000 steps  (83 percent)
[19:53:38] -
[19:53:38] Completed 4200000 out of 5000000 steps  (84 percent)
[20:08:24] -
[20:08:24] Completed 4250000 out of 5000000 steps  (85 percent)
[20:23:12] -
[20:23:12] Completed 4300000 out of 5000000 steps  (86 percent)
[20:38:01] -
[20:38:01] Completed 4350000 out of 5000000 steps  (87 percent)
[20:52:47] -
[20:52:47] Completed 4400000 out of 5000000 steps  (88 percent)
[21:07:33] -
[21:07:33] Completed 4450000 out of 5000000 steps  (89 percent)
[21:22:20] -
[21:22:20] Completed 4500000 out of 5000000 steps  (90 percent)
[21:37:07] -
[21:37:07] Completed 4550000 out of 5000000 steps  (91 percent)
[21:51:54] -
[21:51:54] Completed 4600000 out of 5000000 steps  (92 percent)
[22:06:40] -
[22:06:40] Completed 4650000 out of 5000000 steps  (93 percent)
[22:21:26] -
[22:21:26] Completed 4700000 out of 5000000 steps  (94 percent)
[22:36:13] -
[22:36:13] Completed 4750000 out of 5000000 steps  (95 percent)
[22:51:00] -
[22:51:00] Completed 4800000 out of 5000000 steps  (96 percent)
[23:05:45] -
[23:05:45] Completed 4850000 out of 5000000 steps  (97 percent)
[23:20:30] -
[23:20:30] Completed 4900000 out of 5000000 steps  (98 percent)
[23:35:17] -
[23:35:17] Completed 4950000 out of 5000000 steps  (99 percent)
[23:50:04] -
[23:50:04] Completed 5000000 out of 5000000 steps  (100 percent)
[23:50:04] Writing final coordinates.
[23:50:04] Past main M.D. loop
[23:50:04] Will end MPI now
[23:51:04]
[23:51:04] Finished Work Unit:
[23:51:04] - Reading up to 517920 from "work/wudata_04.arc": Read 517920
[23:51:04] - Reading up to 971312 from "work/wudata_04.xtc": Read 971312
[23:51:04] goefile size: 0
[23:51:04] logfile size: 140918
[23:51:04] Leaving Run
[23:51:09] - Writing 1831194 bytes of core data to disk...
[23:51:09]   ... Done.
[23:51:09] - Failed to delete work/wudata_04.sas
[23:51:09] - Failed to delete work/wudata_04.goe
[23:51:09] Warning:  check for stray files
[23:51:09] - Shutting down core
[23:53:09]
[23:53:09] Folding@home Core Shutdown: FINISHED_UNIT
[23:53:09]
[23:53:12] CoreStatus = 64 (100)
[23:53:12] Sending work to server
[23:53:12] + Attempting to send results
[23:53:22] + Results successfully sent
[23:53:22] Thank you for your contribution to Folding@Home.
[23:53:22] + Number of Units Completed: 6
[23:55:26] - Preparing to get new work unit...
[23:55:26] + Attempting to get work packet
[23:55:26] - Connecting to assignment server
[23:55:27] - Successful: assigned to (171.64.65.64).
[23:55:27] + News From Folding@Home: Welcome to Folding@Home
[23:55:27] Loaded queue successfully.
[23:55:40] + Closed connections
[23:55:40]
[23:55:40] + Processing work unit
[23:55:40] Core required: FahCore_a1.exe
[23:55:40] Core found.
[23:55:40] Working on Unit 05 [August 23 23:55:40]
[23:55:40] + Working ...
[23:55:40]
[23:55:40] *------------------------------*
[23:55:40] Folding@Home Gromacs SMP Core
[23:55:40] Version 1.74 (March 10, 2007)
[23:55:40]
[23:55:40] Preparing to commence simulation
[23:55:40] - Ensuring status. Please wait.
[23:55:45] - Starting from initial work packet
[23:55:45]
[23:55:45] Project: 2665 (Run 3, Clone 325, Gen 36)
[23:55:45]
[23:55:47] Assembly optimizations on if available.
[23:55:47] Entering M.D.
[23:56:08]  percent)
[23:56:08] - Starting from initial work packet
[23:56:08]
[23:56:08] Project: 2665 (Run 3, Clone 325, Gen 36)
[23:56:08]
[23:56:10] Entering M.D.
[23:56:16] Rejecting checkpoint
[23:56:18] Protein: HGG in water
[23:56:18] -
[23:56:25] Extra SSE boost OK.
[23:56:25] -
[23:56:26] Completed 0 out of 250000 steps  (0 percent)
[00:13:19] -
[00:13:20] Completed 2500 out of 250000 steps  (1 percent)
[00:30:19] -
[00:30:20] Completed 5000 out of 250000 steps  (2 percent)
[00:47:20] -
[00:47:20] Completed 7500 out of 250000 steps  (3 percent)
[01:04:22] -
[01:04:22] Completed 10000 out of 250000 steps  (4 percent)
[01:20:59] -
[01:20:59] Completed 12500 out of 250000 steps  (5 percent)
[01:38:11] -
[01:38:11] Completed 15000 out of 250000 steps  (6 percent)
[01:55:12] -
[01:55:13] Completed 17500 out of 250000 steps  (7 percent)
[02:12:14] -
[02:12:15] Completed 20000 out of 250000 steps  (8 percent)
[02:29:17] -
[02:29:18] Completed 22500 out of 250000 steps  (9 percent)
[02:46:18] -
[02:46:19] Completed 25000 out of 250000 steps  (10 percent)
[03:03:20] -
[03:03:21] Completed 27500 out of 250000 steps  (11 percent)
[03:20:22] -
[03:20:22] Completed 30000 out of 250000 steps  (12 percent)
[03:37:24] -
[03:37:24] Completed 32500 out of 250000 steps  (13 percent)
[03:54:26] -
[03:54:27] Completed 35000 out of 250000 steps  (14 percent)
[04:11:28] -
[04:11:29] Completed 37500 out of 250000 steps  (15 percent)
[04:28:31] -
[04:28:32] Completed 40000 out of 250000 steps  (16 percent)
[04:45:34] -
[04:45:35] Completed 42500 out of 250000 steps  (17 percent)
[05:02:37] -
[05:02:38] Completed 45000 out of 250000 steps  (18 percent)
[05:19:39] -
[05:19:40] Completed 47500 out of 250000 steps  (19 percent)
[05:36:41] -
[05:36:42] Completed 50000 out of 250000 steps  (20 percent)
[05:53:44] -
[05:53:45] Completed 52500 out of 250000 steps  (21 percent)
[06:10:47] -
[06:10:48] Completed 55000 out of 250000 steps  (22 percent)
[06:27:51] -
[06:27:52] Completed 57500 out of 250000 steps  (23 percent)
[06:44:51] -
[06:44:52] Completed 60000 out of 250000 steps  (24 percent)
[07:01:53] -
[07:01:54] Completed 62500 out of 250000 steps  (25 percent)
[07:18:56] -
[07:18:57] Completed 65000 out of 250000 steps  (26 percent)
[07:35:57] -
[07:35:58] Completed 67500 out of 250000 steps  (27 percent)
[07:53:00] -
[07:53:01] Completed 70000 out of 250000 steps  (28 percent)
[08:10:01] -
[08:10:02] Completed 72500 out of 250000 steps  (29 percent)
[08:27:02] -
[08:27:02] Completed 75000 out of 250000 steps  (30 percent)
[08:44:01] -
[08:44:02] Completed 77500 out of 250000 steps  (31 percent)
[09:01:02] -
[09:01:02] Completed 80000 out of 250000 steps  (32 percent)
[09:18:02] -
[09:18:03] Completed 82500 out of 250000 steps  (33 percent)
[09:35:05] -
[09:35:06] Completed 85000 out of 250000 steps  (34 percent)
[09:52:06] -
[09:52:06] Completed 87500 out of 250000 steps  (35 percent)
[10:09:05] -
[10:09:06] Completed 90000 out of 250000 steps  (36 percent)
[10:26:05] -
[10:26:05] Completed 92500 out of 250000 steps  (37 percent)
[10:43:06] -
[10:43:07] Completed 95000 out of 250000 steps  (38 percent)
[11:00:06] -
[11:00:06] Completed 97500 out of 250000 steps  (39 percent)
[11:17:07] -
[11:17:08] Completed 100000 out of 250000 steps  (40 percent)
[11:20:50] Gromacs cannot continue further.
[11:20:50] Going to send back what have done.
[11:20:50] logfile size: 84069
[11:20:50] - Writing 84605 bytes of core data to disk...
[11:20:50]   ... Done.
[11:20:52] - Failed to delete work/wudata_05.sas
[11:20:52] - Failed to delete work/wudata_05.goe
[11:20:52] Warning:  check for stray files
[11:22:52]
[11:22:52] Folding@home Core Shutdown: EARLY_UNIT_END
[11:22:52]
[11:22:56] CoreStatus = 7B (123)
[11:22:56] Client-core communications error: ERROR 0x7b
[11:22:56] Deleting current work unit & continuing...
[11:25:00] - Preparing to get new work unit...
[11:25:00] + Attempting to get work packet
[11:25:00] - Connecting to assignment server
[11:25:00] - Successful: assigned to (171.64.65.64).
[11:25:00] + News From Folding@Home: Welcome to Folding@Home
[11:25:01] Loaded queue successfully.
[11:25:13] + Closed connections
[11:25:18]
[11:25:18] + Processing work unit
[11:25:18] Core required: FahCore_a1.exe
[11:25:18] Core found.
[11:25:18] Working on Unit 06 [August 24 11:25:18]
[11:25:18] + Working ...
[11:25:19]
[11:25:19] *------------------------------*
[11:25:19] Folding@Home Gromacs SMP Core
[11:25:19] Version 1.74 (March 10, 2007)
[11:25:19]
[11:25:19] Preparing to commence simulation
[11:25:19] - Ensuring status. Please wait.
[11:25:24] - Starting from initial work packet
[11:25:24]
[11:25:24] Project: 2665 (Run 3, Clone 325, Gen 36)
[11:25:24]
[11:25:25] Assembly optimizations on if available.
[11:25:25] Entering M.D.
[11:25:47] al work pa- Starting from initial work packet
[11:25:47]
[11:25:47] Project: 2665 (Run 3, Clone 325, Gen 36)
[11:25:47]
[11:25:49] Entering M.D.
[11:25:55] Rejecting checkpoint
[11:25:56] Protein: HGG in water
[11:25:56] -
[11:26:04] Extra SSE boost OK.
[11:26:04] -
[11:26:05] Completed 0 out of 250000 steps  (0 percent)
[11:43:21] -
[11:43:22] Completed 2500 out of 250000 steps  (1 percent)
[12:00:20] -
[12:00:21] Completed 5000 out of 250000 steps  (2 percent)
[12:17:21] -
[12:17:22] Completed 7500 out of 250000 steps  (3 percent)
[12:34:23] -
[12:34:23] Completed 10000 out of 250000 steps  (4 percent)
[12:51:24] -
[12:51:24] Completed 12500 out of 250000 steps  (5 percent)
[13:08:25] -
[13:08:26] Completed 15000 out of 250000 steps  (6 percent)
[13:25:26] -
[13:25:27] Completed 17500 out of 250000 steps  (7 percent)
[13:42:28] -
[13:42:28] Completed 20000 out of 250000 steps  (8 percent)
[13:59:30] -
[13:59:32] Completed 22500 out of 250000 steps  (9 percent)
[14:16:32] -
[14:16:33] Completed 25000 out of 250000 steps  (10 percent)
[14:33:34] -
[14:33:34] Completed 27500 out of 250000 steps  (11 percent)
[14:50:36] -
[14:50:36] Completed 30000 out of 250000 steps  (12 percent)
[15:07:37] -
[15:07:38] Completed 32500 out of 250000 steps  (13 percent)
[15:24:38] -
[15:24:39] Completed 35000 out of 250000 steps  (14 percent)
[15:41:41] -
[15:41:42] Completed 37500 out of 250000 steps  (15 percent)
[15:58:44] -
[15:58:45] Completed 40000 out of 250000 steps  (16 percent)
[16:15:46] -
[16:15:47] Completed 42500 out of 250000 steps  (17 percent)
[16:32:50] -
[16:32:51] Completed 45000 out of 250000 steps  (18 percent)
[16:49:54] -
[16:49:55] Completed 47500 out of 250000 steps  (19 percent)
[17:06:55] -
[17:06:57] Completed 50000 out of 250000 steps  (20 percent)
[17:23:58] -
[17:23:59] Completed 52500 out of 250000 steps  (21 percent)
[17:41:01] -
[17:41:02] Completed 55000 out of 250000 steps  (22 percent)
[17:58:03] -
[17:58:04] Completed 57500 out of 250000 steps  (23 percent)
[18:15:06] -
[18:15:07] Completed 60000 out of 250000 steps  (24 percent)
[18:32:08] -
[18:32:09] Completed 62500 out of 250000 steps  (25 percent)
[18:49:10] -
[18:49:11] Completed 65000 out of 250000 steps  (26 percent)
[19:06:11] -
[19:06:12] Completed 67500 out of 250000 steps  (27 percent)
[19:23:15] -
[19:23:15] Completed 70000 out of 250000 steps  (28 percent)
[19:40:15] -
[19:40:16] Completed 72500 out of 250000 steps  (29 percent)
[19:57:16] -
[19:57:16] Completed 75000 out of 250000 steps  (30 percent)
[20:14:17] -
[20:14:18] Completed 77500 out of 250000 steps  (31 percent)
[20:31:17] -
[20:31:17] Completed 80000 out of 250000 steps  (32 percent)
[20:48:16] -
[20:48:17] Completed 82500 out of 250000 steps  (33 percent)
[21:05:16] -
[21:05:17] Completed 85000 out of 250000 steps  (34 percent)
[21:22:16] -
[21:22:17] Completed 87500 out of 250000 steps  (35 percent)
[21:39:15] -
[21:39:16] Completed 90000 out of 250000 steps  (36 percent)
[21:56:15] -
[21:56:16] Completed 92500 out of 250000 steps  (37 percent)
[22:13:16] -
[22:13:17] Completed 95000 out of 250000 steps  (38 percent)
[22:30:15] -
[22:30:16] Completed 97500 out of 250000 steps  (39 percent)
[22:47:14] -
[22:47:15] Completed 100000 out of 250000 steps  (40 percent)
[22:50:57] Gromacs cannot continue further.
[22:50:57] Going to send back what have done.
[22:50:57] logfile size: 84069
[22:50:57] - Writing 84605 bytes of core data to disk...
[22:50:57]   ... Done.
[22:50:59] - Failed to delete work/wudata_06.sas
[22:50:59] - Failed to delete work/wudata_06.goe
[22:50:59] Warning:  check for stray files
[22:52:59]
[22:52:59] Folding@home Core Shutdown: EARLY_UNIT_END
[22:52:59]
[22:53:02] CoreStatus = 7B (123)
[22:53:02] Client-core communications error: ERROR 0x7b
[22:53:02] Deleting current work unit & continuing...
[22:55:07] - Preparing to get new work unit...
[22:55:07] + Attempting to get work packet
[22:55:07] - Connecting to assignment server
[22:55:07] - Successful: assigned to (171.64.65.64).
[22:55:07] + News From Folding@Home: Welcome to Folding@Home
[22:55:07] Loaded queue successfully.
[22:55:22] + Closed connections
[22:55:27]
[22:55:27] + Processing work unit
[22:55:27] Core required: FahCore_a1.exe
[22:55:27] Core found.
[22:55:27] Working on Unit 07 [August 24 22:55:27]
[22:55:27] + Working ...
[22:55:27]
[22:55:27] *------------------------------*
[22:55:27] Folding@Home Gromacs SMP Core
[22:55:27] Version 1.74 (March 10, 2007)
[22:55:27]
[22:55:27] Preparing to commence simulation
[22:55:27] - Ensuring status. Please wait.
[22:55:32] - Starting from initial work packet
[22:55:32]
[22:55:32] Project: 2665 (Run 3, Clone 325, Gen 36)
[22:55:32]
[22:55:34] Assembly optimizations on if available.
[22:55:34] Entering M.D.
[22:55:56]  percent)
[22:55:56] - Starting from initial work packet
[22:55:56]
[22:55:56] Project: 2665 (Run 3, Clone 325, Gen 36)
[22:55:56]
[22:55:59] Entering M.D.
[22:56:05] Rejecting checkpoint
[22:56:06] Protein: HGG in water
[22:56:06] -
[22:56:14] Extra SSE boost OK.
[22:56:14] -
[22:56:15] Completed 0 out of 250000 steps  (0 percent)
[23:12:52] -
[23:12:53] Completed 2500 out of 250000 steps  (1 percent)
[23:29:52] -
[23:29:53] Completed 5000 out of 250000 steps  (2 percent)
[23:46:53] -
[23:46:54] Completed 7500 out of 250000 steps  (3 percent)
[00:03:54] -
[00:03:55] Completed 10000 out of 250000 steps  (4 percent)
[00:20:56] -
[00:20:57] Completed 12500 out of 250000 steps  (5 percent)
[00:37:57] -
[00:37:57] Completed 15000 out of 250000 steps  (6 percent)
[00:54:57] -
[00:54:58] Completed 17500 out of 250000 steps  (7 percent)
[01:11:58] -
[01:11:59] Completed 20000 out of 250000 steps  (8 percent)
[01:29:00] -
[01:29:01] Completed 22500 out of 250000 steps  (9 percent)
[01:46:03] -
[01:46:03] Completed 25000 out of 250000 steps  (10 percent)
[02:03:04] -
[02:03:05] Completed 27500 out of 250000 steps  (11 percent)
[02:20:06] -
[02:20:07] Completed 30000 out of 250000 steps  (12 percent)
[02:37:07] -
[02:37:08] Completed 32500 out of 250000 steps  (13 percent)
[02:54:08] -
[02:54:09] Completed 35000 out of 250000 steps  (14 percent)
[03:11:12] -
[03:11:13] Completed 37500 out of 250000 steps  (15 percent)
[03:28:16] -
[03:28:17] Completed 40000 out of 250000 steps  (16 percent)
[03:45:20] -
[03:45:20] Completed 42500 out of 250000 steps  (17 percent)
[04:02:24] -
[04:02:25] Completed 45000 out of 250000 steps  (18 percent)
[04:19:27] -
[04:19:28] Completed 47500 out of 250000 steps  (19 percent)
[04:36:29] -
[04:36:30] Completed 50000 out of 250000 steps  (20 percent)
[04:53:32] -
[04:53:33] Completed 52500 out of 250000 steps  (21 percent)
[05:10:35] -
[05:10:37] Completed 55000 out of 250000 steps  (22 percent)
[05:27:38] -
[05:27:38] Completed 57500 out of 250000 steps  (23 percent)
[05:44:38] -
[05:44:38] Completed 60000 out of 250000 steps  (24 percent)
[06:01:39] -
[06:01:40] Completed 62500 out of 250000 steps  (25 percent)
[06:18:41] -
[06:18:42] Completed 65000 out of 250000 steps  (26 percent)
[06:35:43] -
[06:35:44] Completed 67500 out of 250000 steps  (27 percent)
[06:52:39] -
[06:52:40] Completed 70000 out of 250000 steps  (28 percent)
[07:10:04] -
[07:10:05] Completed 72500 out of 250000 steps  (29 percent)
[07:27:04] -
[07:27:05] Completed 75000 out of 250000 steps  (30 percent)
[07:44:04] -
[07:44:05] Completed 77500 out of 250000 steps  (31 percent)
[08:01:03] -
[08:01:04] Completed 80000 out of 250000 steps  (32 percent)
[08:18:03] -
[08:18:04] Completed 82500 out of 250000 steps  (33 percent)
[08:35:03] -
[08:35:03] Completed 85000 out of 250000 steps  (34 percent)
[08:52:02] -
[08:52:03] Completed 87500 out of 250000 steps  (35 percent)
[09:09:03] -
[09:09:03] Completed 90000 out of 250000 steps  (36 percent)
[09:26:03] -
[09:26:04] Completed 92500 out of 250000 steps  (37 percent)
[09:43:04] -
[09:43:04] Completed 95000 out of 250000 steps  (38 percent)
[10:00:03] -
[10:00:04] Completed 97500 out of 250000 steps  (39 percent)
[10:17:03] -
[10:17:04] Completed 100000 out of 250000 steps  (40 percent)
[10:20:46] Gromacs cannot continue further.
[10:20:46] Going to send back what have done.
[10:20:46] logfile size: 84069
[10:20:46] - Writing 84605 bytes of core data to disk...
[10:20:46]   ... Done.
[10:20:47] - Failed to delete work/wudata_07.sas
[10:20:47] - Failed to delete work/wudata_07.goe
[10:20:47] Warning:  check for stray files
[10:22:48]
[10:22:48] Folding@home Core Shutdown: EARLY_UNIT_END
[10:22:48]
[10:22:51] CoreStatus = 7B (123)
[10:22:51] Client-core communications error: ERROR 0x7b
[10:22:51] - Attempting to download new core...
[10:22:51] + Downloading new core: FahCore_a1.exe
[10:22:51] + 10240 bytes downloaded
[10:22:52] + 20480 bytes downloaded
[10:22:52] + 30720 bytes downloaded
[10:22:52] + 40960 bytes downloaded
[10:22:52] + 51200 bytes downloaded
[10:22:52] + 61440 bytes downloaded
[10:22:52] + 71680 bytes downloaded
[10:22:52] + 81920 bytes downloaded
[10:22:52] + 92160 bytes downloaded
[10:22:52] + 102400 bytes downloaded
[10:22:52] + 112640 bytes downloaded
[10:22:52] + 122880 bytes downloaded
[10:22:52] + 133120 bytes downloaded
[10:22:52] + 143360 bytes downloaded
[10:22:52] + 153600 bytes downloaded
[10:22:52] + 163840 bytes downloaded
[10:22:52] + 174080 bytes downloaded
[10:22:52] + 184320 bytes downloaded
[10:22:52] + 194560 bytes downloaded
[10:22:52] + 204800 bytes downloaded
[10:22:52] + 215040 bytes downloaded
[10:22:52] + 225280 bytes downloaded
[10:22:52] + 235520 bytes downloaded
[10:22:52] + 245760 bytes downloaded
[10:22:52] + 256000 bytes downloaded
[10:22:52] + 266240 bytes downloaded
[10:22:52] + 276480 bytes downloaded
[10:22:52] + 286720 bytes downloaded
[10:22:52] + 296960 bytes downloaded
[10:22:52] + 307200 bytes downloaded
[10:22:52] + 317440 bytes downloaded
[10:22:52] + 327680 bytes downloaded
[10:22:52] + 337920 bytes downloaded
[10:22:52] + 348160 bytes downloaded
[10:22:52] + 358400 bytes downloaded
[10:22:52] + 368640 bytes downloaded
[10:22:52] + 378880 bytes downloaded
[10:22:52] + 389120 bytes downloaded
[10:22:52] + 399360 bytes downloaded
[10:22:52] + 409600 bytes downloaded
[10:22:52] + 419840 bytes downloaded
[10:22:52] + 430080 bytes downloaded
[10:22:52] + 440320 bytes downloaded
[10:22:52] + 450560 bytes downloaded
[10:22:52] + 460800 bytes downloaded
[10:22:52] + 471040 bytes downloaded
[10:22:52] + 481280 bytes downloaded
[10:22:52] + 491520 bytes downloaded
[10:22:52] + 501760 bytes downloaded
[10:22:52] + 512000 bytes downloaded
[10:22:52] + 522240 bytes downloaded
[10:22:52] + 532480 bytes downloaded
[10:22:52] + 542720 bytes downloaded
[10:22:52] + 552960 bytes downloaded
[10:22:52] + 563200 bytes downloaded
[10:22:52] + 573440 bytes downloaded
[10:22:52] + 583680 bytes downloaded
[10:22:52] + 593920 bytes downloaded
[10:22:53] + 604160 bytes downloaded
[10:22:53] + 614400 bytes downloaded
[10:22:53] + 624640 bytes downloaded
[10:22:53] + 634880 bytes downloaded
[10:22:53] + 645120 bytes downloaded
[10:22:53] + 655360 bytes downloaded
[10:22:53] + 665600 bytes downloaded
[10:22:53] + 675840 bytes downloaded
[10:22:53] + 686080 bytes downloaded
[10:22:53] + 696320 bytes downloaded
[10:22:53] + 706560 bytes downloaded
[10:22:53] + 716800 bytes downloaded
[10:22:53] + 727040 bytes downloaded
[10:22:53] + 737280 bytes downloaded
[10:22:53] + 747520 bytes downloaded
[10:22:53] + 757760 bytes downloaded
[10:22:53] + 768000 bytes downloaded
[10:22:53] + 778240 bytes downloaded
[10:22:53] + 788480 bytes downloaded
[10:22:53] + 789667 bytes downloaded
[10:22:53] Verifying core Core_a1.fah...
[10:22:53] Signature is VALID
[10:22:53]
[10:22:53] Trying to unzip core FahCore_a1.exe
[10:22:53] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[10:22:53] + Core successfully engaged
[10:22:53] Deleting current work unit & continuing...
[10:24:57] - Preparing to get new work unit...
[10:24:57] + Attempting to get work packet
[10:24:57] - Connecting to assignment server
[10:24:57] - Successful: assigned to (171.64.65.64).
[10:24:57] + News From Folding@Home: Welcome to Folding@Home
[10:24:57] Loaded queue successfully.
[10:25:10] + Closed connections
[10:25:15]
[10:25:15] + Processing work unit
[10:25:15] Core required: FahCore_a1.exe
[10:25:15] Core found.
[10:25:15] Working on Unit 08 [August 25 10:25:15]
[10:25:15] + Working ...
[10:25:15]
[10:25:15] *------------------------------*
[10:25:15] Folding@Home Gromacs SMP Core
[10:25:15] Version 1.74 (March 10, 2007)
[10:25:15]
[10:25:15] Preparing to commence simulation
[10:25:15] - Ensuring status. Please wait.
[10:25:20] - Starting from initial work packet
[10:25:20]
[10:25:20] Project: 2665 (Run 3, Clone 325, Gen 36)
[10:25:20]
[10:25:22] Assembly optimizations on if available.
[10:25:22] Entering M.D.
[10:25:45] al work packet
[10:25:45]
[10:25:45] Project: 2665 (Run 3, Clone 325, Gen 36)
[10:25:45]
[10:25:45] 65 (Run 3, Clone 325, Gen 36)
[10:25:45]
[10:25:47] Entering M.D.
[10:25:53] Rejecting checkpoint
[10:25:54]
[10:25:54] -
[10:25:55]
[10:25:55] -
[10:26:02] Extra SSE boost OK.
[10:26:02] -
[10:26:03] Completed 0 out of 250000 steps  (0 percent)
[10:42:36] -
[10:42:37] Completed 2500 out of 250000 steps  (1 percent)
[10:59:37] -
[10:59:38] Completed 5000 out of 250000 steps  (2 percent)
[11:16:37] -
[11:16:38] Completed 7500 out of 250000 steps  (3 percent)
[11:33:38] -
[11:33:39] Completed 10000 out of 250000 steps  (4 percent)
[11:50:40] -
[11:50:41] Completed 12500 out of 250000 steps  (5 percent)
[12:07:41] -
[12:07:42] Completed 15000 out of 250000 steps  (6 percent)
[12:24:42] -
[12:24:43] Completed 17500 out of 250000 steps  (7 percent)
[12:41:42] -
[12:41:43] Completed 20000 out of 250000 steps  (8 percent)
[12:58:44] -
[12:58:45] Completed 22500 out of 250000 steps  (9 percent)
[13:15:46] -
[13:15:47] Completed 25000 out of 250000 steps  (10 percent)
[13:32:47] -
[13:32:48] Completed 27500 out of 250000 steps  (11 percent)
[13:49:48] -
[13:49:49] Completed 30000 out of 250000 steps  (12 percent)
[14:06:49] -
[14:06:51] Completed 32500 out of 250000 steps  (13 percent)
[14:23:50] -
[14:23:51] Completed 35000 out of 250000 steps  (14 percent)
[14:40:52] -
[14:40:53] Completed 37500 out of 250000 steps  (15 percent)
[14:57:54] -
[14:57:55] Completed 40000 out of 250000 steps  (16 percent)
[15:14:56] -
[15:14:57] Completed 42500 out of 250000 steps  (17 percent)
[15:31:58] -
[15:31:59] Completed 45000 out of 250000 steps  (18 percent)
[15:49:01] -
[15:49:02] Completed 47500 out of 250000 steps  (19 percent)
[16:06:02] -
[16:06:04] Completed 50000 out of 250000 steps  (20 percent)
[16:23:05] -
[16:23:06] Completed 52500 out of 250000 steps  (21 percent)
[16:40:08] -
[16:40:09] Completed 55000 out of 250000 steps  (22 percent)
[16:57:10] -
[16:57:11] Completed 57500 out of 250000 steps  (23 percent)
[17:14:10] -
[17:14:11] Completed 60000 out of 250000 steps  (24 percent)
[17:31:12] -
[17:31:13] Completed 62500 out of 250000 steps  (25 percent)
[17:48:13] -
[17:48:14] Completed 65000 out of 250000 steps  (26 percent)
[18:05:14] -
[18:05:15] Completed 67500 out of 250000 steps  (27 percent)
[18:22:16] -
[18:22:17] Completed 70000 out of 250000 steps  (28 percent)
[18:39:17] -
[18:39:18] Completed 72500 out of 250000 steps  (29 percent)
[18:56:18] -
[18:56:18] Completed 75000 out of 250000 steps  (30 percent)
[19:13:18] -
[19:13:18] Completed 77500 out of 250000 steps  (31 percent)
[19:30:18] -
[19:30:18] Completed 80000 out of 250000 steps  (32 percent)
[19:47:18] -
[19:47:19] Completed 82500 out of 250000 steps  (33 percent)
[20:04:17] -
[20:04:18] Completed 85000 out of 250000 steps  (34 percent)
[20:21:17] -
[20:21:18] Completed 87500 out of 250000 steps  (35 percent)
[20:38:16] -
[20:38:17] Completed 90000 out of 250000 steps  (36 percent)
[20:55:16] -
[20:55:17] Completed 92500 out of 250000 steps  (37 percent)
[21:12:16] -
[21:12:17] Completed 95000 out of 250000 steps  (38 percent)
[21:29:16] -
[21:29:17] Completed 97500 out of 250000 steps  (39 percent)
[21:46:16] -
[21:46:17] Completed 100000 out of 250000 steps  (40 percent)
[21:49:59] Gromacs cannot continue further.
[21:49:59] Going to send back what have done.
[21:49:59] logfile size: 84069
[21:49:59] - Writing 84605 bytes of core data to disk...
[21:49:59]   ... Done.
[21:50:00] - Failed to delete work/wudata_08.sas
[21:50:00] - Failed to delete work/wudata_08.goe
[21:50:00] Warning:  check for stray files
[21:52:00]
[21:52:00] Folding@home Core Shutdown: EARLY_UNIT_END
[21:52:00]
[21:52:05] CoreStatus = 7B (123)
[21:52:05] Client-core communications error: ERROR 0x7b
[21:52:05] Deleting current work unit & continuing...
[21:54:09] - Preparing to get new work unit...
[21:54:09] + Attempting to get work packet
[21:54:09] - Connecting to assignment server
[21:54:10] - Successful: assigned to (171.64.65.64).
[21:54:10] + News From Folding@Home: Welcome to Folding@Home
[21:54:10] Loaded queue successfully.
[21:54:26] + Closed connections
[21:54:31]
[21:54:31] + Processing work unit
[21:54:31] Core required: FahCore_a1.exe
[21:54:31] Core found.
[21:54:31] Working on Unit 09 [August 25 21:54:31]
[21:54:31] + Working ...
[21:54:31]
[21:54:31] *------------------------------*
[21:54:31] Folding@Home Gromacs SMP Core
[21:54:31] Version 1.74 (March 10, 2007)
[21:54:31]
[21:54:31] Preparing to commence simulation
[21:54:31] - Ensuring status. Please wait.
[21:54:36] - Starting from initial work packet
[21:54:36]
[21:54:36] Project: 2665 (Run 3, Clone 325, Gen 36)
[21:54:36]
[21:54:38] Assembly optimizations on if available.
[21:54:38] Entering M.D.
[21:54:59]  percent)
[21:54:59] - Starting from initial work packet
[21:54:59]
[21:54:59] Project: 2665 (Run 3, Clone 325, Gen 36)
[21:54:59]
[21:55:01] Entering M.D.
[21:55:07] Rejecting checkpoint
[21:55:09] Protein: HGG in water
[21:55:09] -
[21:55:16] Extra SSE boost OK.
[21:55:16] -
[21:55:17] Completed 0 out of 250000 steps  (0 percent)
[22:12:11] -
[22:12:11] Completed 2500 out of 250000 steps  (1 percent)
[22:29:10] -
[22:29:11] Completed 5000 out of 250000 steps  (2 percent)
[22:46:11] -
[22:46:12] Completed 7500 out of 250000 steps  (3 percent)
[23:03:13] -
[23:03:14] Completed 10000 out of 250000 steps  (4 percent)
[23:20:14] -
[23:20:15] Completed 12500 out of 250000 steps  (5 percent)
[23:37:15] -
[23:37:15] Completed 15000 out of 250000 steps  (6 percent)
[23:54:15] -
[23:54:17] Completed 17500 out of 250000 steps  (7 percent)
[00:11:16] -
[00:11:17] Completed 20000 out of 250000 steps  (8 percent)
[00:28:17] -
[00:28:18] Completed 22500 out of 250000 steps  (9 percent)
[00:45:19] -
[00:45:20] Completed 25000 out of 250000 steps  (10 percent)
[01:02:20] -
[01:02:21] Completed 27500 out of 250000 steps  (11 percent)
[01:19:21] -
[01:19:22] Completed 30000 out of 250000 steps  (12 percent)
[01:36:22] -
[01:36:23] Completed 32500 out of 250000 steps  (13 percent)
[01:53:24] -
[01:53:24] Completed 35000 out of 250000 steps  (14 percent)
[02:10:26] -
[02:10:27] Completed 37500 out of 250000 steps  (15 percent)
[02:27:28] -
[02:27:29] Completed 40000 out of 250000 steps  (16 percent)
[02:44:30] -
[02:44:31] Completed 42500 out of 250000 steps  (17 percent)
[03:01:33] -
[03:01:34] Completed 45000 out of 250000 steps  (18 percent)
[03:18:35] -
[03:18:35] Completed 47500 out of 250000 steps  (19 percent)
[03:35:36] -
[03:35:37] Completed 50000 out of 250000 steps  (20 percent)
[03:52:39] -
[03:52:39] Completed 52500 out of 250000 steps  (21 percent)
[04:09:42] -
[04:09:42] Completed 55000 out of 250000 steps  (22 percent)
[04:26:43] -
[04:26:44] Completed 57500 out of 250000 steps  (23 percent)
[04:43:44] -
[04:43:45] Completed 60000 out of 250000 steps  (24 percent)
[05:00:46] -
[05:00:47] Completed 62500 out of 250000 steps  (25 percent)
[05:17:48] -
[05:17:49] Completed 65000 out of 250000 steps  (26 percent)
[05:34:50] -
[05:34:50] Completed 67500 out of 250000 steps  (27 percent)
[05:51:52] -
[05:51:53] Completed 70000 out of 250000 steps  (28 percent)
[06:08:53] -
[06:08:53] Completed 72500 out of 250000 steps  (29 percent)
[06:25:54] -
[06:25:55] Completed 75000 out of 250000 steps  (30 percent)
[06:42:54] -
[06:42:54] Completed 77500 out of 250000 steps  (31 percent)
[06:59:54] -
[06:59:55] Completed 80000 out of 250000 steps  (32 percent)
[07:16:54] -
[07:16:55] Completed 82500 out of 250000 steps  (33 percent)
[07:33:54] -
[07:33:55] Completed 85000 out of 250000 steps  (34 percent)
[07:50:54] -
[07:50:54] Completed 87500 out of 250000 steps  (35 percent)
[08:07:53] -
[08:07:54] Completed 90000 out of 250000 steps  (36 percent)
[08:24:53] -
[08:24:54] Completed 92500 out of 250000 steps  (37 percent)
[08:41:54] -
[08:41:54] Completed 95000 out of 250000 steps  (38 percent)
[08:58:53] -
[08:58:53] Completed 97500 out of 250000 steps  (39 percent)
[09:15:52] -
[09:15:53] Completed 100000 out of 250000 steps  (40 percent)
[09:19:35] Gromacs cannot continue further.
[09:19:35] Going to send back what have done.
[09:19:35] logfile size: 84069
[09:19:35] - Writing 84605 bytes of core data to disk...
[09:19:35]   ... Done.
[09:19:37] - Failed to delete work/wudata_09.sas
[09:19:37] - Failed to delete work/wudata_09.goe
[09:19:37] Warning:  check for stray files
[09:21:37]
[09:21:37] Folding@home Core Shutdown: EARLY_UNIT_END
[09:21:37]
[09:21:41] CoreStatus = 7B (123)
[09:21:41] Client-core communications error: ERROR 0x7b
[09:21:41] Deleting current work unit & continuing...
[09:23:45] - Preparing to get new work unit...
[09:23:45] + Attempting to get work packet
[09:23:45] - Connecting to assignment server
[09:23:46] - Successful: assigned to (171.64.65.64).
[09:23:46] + News From Folding@Home: Welcome to Folding@Home
[09:23:46] Loaded queue successfully.
[09:23:59] + Closed connections
[09:24:04]
[09:24:04] + Processing work unit
[09:24:04] Core required: FahCore_a1.exe
[09:24:04] Core found.
[09:24:04] Working on Unit 00 [August 26 09:24:04]
[09:24:04] + Working ...
[09:24:04]
[09:24:04] *------------------------------*
[09:24:04] Folding@Home Gromacs SMP Core
[09:24:04] Version 1.74 (March 10, 2007)
[09:24:04]
[09:24:04] Preparing to commence simulation
[09:24:04] - Ensuring status. Please wait.
[09:24:09] - Starting from initial work packet
[09:24:09]
[09:24:09] Project: 2665 (Run 3, Clone 325, Gen 36)
[09:24:09]
[09:24:10] Assembly optimizations on if available.
[09:24:10] Entering M.D.
[09:24:32]  percent)
[09:24:33] - Starting from initial work packet
[09:24:33] Project: 2665 (Run 3, Clone 325, Gen 36)
[09:24:35] Entering M.D.
[09:24:41] Rejecting checkpoint
[09:24:42] Protein: HGG in water
[09:24:50] Extra SSE boost OK.
[09:24:51] Completed 0 out of 250000 steps  (0 percent)
[09:41:16] Completed 2500 out of 250000 steps  (1 percent)
[09:58:16] Completed 5000 out of 250000 steps  (2 percent)
[10:15:17] Completed 7500 out of 250000 steps  (3 percent)
[10:32:18] Completed 10000 out of 250000 steps  (4 percent)
[10:49:20] Completed 12500 out of 250000 steps  (5 percent)
[11:06:20] Completed 15000 out of 250000 steps  (6 percent)
[11:23:21] Completed 17500 out of 250000 steps  (7 percent)
[11:40:23] Completed 20000 out of 250000 steps  (8 percent)
[11:57:25] Completed 22500 out of 250000 steps  (9 percent)
[12:14:26] Completed 25000 out of 250000 steps  (10 percent)
[12:31:26] Completed 27500 out of 250000 steps  (11 percent)
[12:48:20] Completed 30000 out of 250000 steps  (12 percent)
[13:05:20] Completed 32500 out of 250000 steps  (13 percent)
[13:22:28] Completed 35000 out of 250000 steps  (14 percent)
[13:39:23] Completed 37500 out of 250000 steps  (15 percent)
[13:56:15] Completed 40000 out of 250000 steps  (16 percent)
[14:13:09] Completed 42500 out of 250000 steps  (17 percent)
[14:30:02] Completed 45000 out of 250000 steps  (18 percent)
[14:46:56] Completed 47500 out of 250000 steps  (19 percent)
[15:03:50] Completed 50000 out of 250000 steps  (20 percent)
[15:20:43] Completed 52500 out of 250000 steps  (21 percent)
[15:37:37] Completed 55000 out of 250000 steps  (22 percent)
[15:54:29] Completed 57500 out of 250000 steps  (23 percent)
[16:11:23] Completed 60000 out of 250000 steps  (24 percent)
[16:28:17] Completed 62500 out of 250000 steps  (25 percent)
[16:45:12] Completed 65000 out of 250000 steps  (26 percent)
[17:02:03] Completed 67500 out of 250000 steps  (27 percent)
[17:19:04] Completed 70000 out of 250000 steps  (28 percent)
[17:35:57] Completed 72500 out of 250000 steps  (29 percent)
[17:52:57] Completed 75000 out of 250000 steps  (30 percent)
[18:09:49] Completed 77500 out of 250000 steps  (31 percent)
[18:26:40] Completed 80000 out of 250000 steps  (32 percent)
[18:43:39] Completed 82500 out of 250000 steps  (33 percent)
[19:00:33] Completed 85000 out of 250000 steps  (34 percent)
[19:17:25] Completed 87500 out of 250000 steps  (35 percent)
[19:34:15] Completed 90000 out of 250000 steps  (36 percent)
[19:51:07] Completed 92500 out of 250000 steps  (37 percent)
[20:08:02] Completed 95000 out of 250000 steps  (38 percent)
[20:25:00] Completed 97500 out of 250000 steps  (39 percent)
[20:41:52] Completed 100000 out of 250000 steps  (40 percent)
[20:45:32] Gromacs cannot continue further.
[20:45:32] Going to send back what have done.
[20:45:32] logfile size: 84069
[20:45:32] - Writing 84605 bytes of core data to disk...
[20:45:32]   ... Done.
[20:45:34] - Failed to delete work/wudata_00.sas
[20:45:34] - Failed to delete work/wudata_00.goe
[20:45:34] Warning:  check for stray files
[20:47:34] Folding@home Core Shutdown: EARLY_UNIT_END
[20:47:38] CoreStatus = 7B (123)
[20:47:38] Client-core communications error: ERROR 0x7b
[20:47:38] - Attempting to download new core...
[20:47:38] + Downloading new core: FahCore_a1.exe
[20:47:38] + 10240 bytes downloaded
[20:47:38] + 20480 bytes downloaded
[20:47:38] + 30720 bytes downloaded
[20:47:38] + 40960 bytes downloaded
[20:47:38] + 51200 bytes downloaded
[20:47:38] + 61440 bytes downloaded
[20:47:38] + 71680 bytes downloaded
[20:47:38] + 81920 bytes downloaded
[20:47:38] + 92160 bytes downloaded
[20:47:38] + 102400 bytes downloaded
[20:47:38] + 112640 bytes downloaded
[20:47:38] + 122880 bytes downloaded
[20:47:38] + 133120 bytes downloaded
[20:47:38] + 143360 bytes downloaded
[20:47:39] + 153600 bytes downloaded
[20:47:39] + 163840 bytes downloaded
[20:47:39] + 174080 bytes downloaded
[20:47:39] + 184320 bytes downloaded
[20:47:39] + 194560 bytes downloaded
[20:47:39] + 204800 bytes downloaded
[20:47:39] + 215040 bytes downloaded
[20:47:39] + 225280 bytes downloaded
[20:47:39] + 235520 bytes downloaded
[20:47:39] + 245760 bytes downloaded
[20:47:39] + 256000 bytes downloaded
[20:47:39] + 266240 bytes downloaded
[20:47:39] + 276480 bytes downloaded
[20:47:39] + 286720 bytes downloaded
[20:47:39] + 296960 bytes downloaded
[20:47:39] + 307200 bytes downloaded
[20:47:39] + 317440 bytes downloaded
[20:47:39] + 327680 bytes downloaded
[20:47:39] + 337920 bytes downloaded
[20:47:39] + 348160 bytes downloaded
[20:47:39] + 358400 bytes downloaded
[20:47:39] + 368640 bytes downloaded
[20:47:39] + 378880 bytes downloaded
[20:47:39] + 389120 bytes downloaded
[20:47:39] + 399360 bytes downloaded
[20:47:39] + 409600 bytes downloaded
[20:47:39] + 419840 bytes downloaded
[20:47:39] + 430080 bytes downloaded
[20:47:39] + 440320 bytes downloaded
[20:47:39] + 450560 bytes downloaded
[20:47:39] + 460800 bytes downloaded
[20:47:39] + 471040 bytes downloaded
[20:47:39] + 481280 bytes downloaded
[20:47:39] + 491520 bytes downloaded
[20:47:39] + 501760 bytes downloaded
[20:47:39] + 512000 bytes downloaded
[20:47:39] + 522240 bytes downloaded
[20:47:39] + 532480 bytes downloaded
[20:47:39] + 542720 bytes downloaded
[20:47:39] + 552960 bytes downloaded
[20:47:39] + 563200 bytes downloaded
[20:47:39] + 573440 bytes downloaded
[20:47:39] + 583680 bytes downloaded
[20:47:39] + 593920 bytes downloaded
[20:47:39] + 604160 bytes downloaded
[20:47:39] + 614400 bytes downloaded
[20:47:39] + 624640 bytes downloaded
[20:47:39] + 634880 bytes downloaded
[20:47:39] + 645120 bytes downloaded
[20:47:39] + 655360 bytes downloaded
[20:47:39] + 665600 bytes downloaded
[20:47:39] + 675840 bytes downloaded
[20:47:39] + 686080 bytes downloaded
[20:47:39] + 696320 bytes downloaded
[20:47:39] + 706560 bytes downloaded
[20:47:39] + 716800 bytes downloaded
[20:47:39] + 727040 bytes downloaded
[20:47:39] + 737280 bytes downloaded
[20:47:39] + 747520 bytes downloaded
[20:47:39] + 757760 bytes downloaded
[20:47:39] + 768000 bytes downloaded
[20:47:39] + 778240 bytes downloaded
[20:47:39] + 788480 bytes downloaded
[20:47:39] + 789667 bytes downloaded
[20:47:39] Verifying core Core_a1.fah...
[20:47:39] Signature is VALID
[20:47:39] Trying to unzip core FahCore_a1.exe
[20:47:39] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[20:47:39] + Core successfully engaged
[20:47:39] Deleting current work unit & continuing...
[20:49:43] - Preparing to get new work unit...
[20:49:43] + Attempting to get work packet
[20:49:43] - Connecting to assignment server
[20:49:44] - Successful: assigned to (171.64.65.64).
[20:49:44] + News From Folding@Home: Welcome to Folding@Home
[20:49:44] Loaded queue successfully.
[20:50:06] + Closed connections
[20:50:11] + Processing work unit
[20:50:11] Core required: FahCore_a1.exe
[20:50:11] Core found.
[20:50:11] Working on Unit 01 [August 26 20:50:11]
[20:50:11] + Working ...
[20:50:11] *------------------------------*
[20:50:11] Folding@Home Gromacs SMP Core
[20:50:11] Version 1.74 (March 10, 2007)
[20:50:11] Preparing to commence simulation
[20:50:11] - Ensuring status. Please wait.
[20:50:16] - Starting from initial work packet
[20:50:16] Project: 2665 (Run 3, Clone 325, Gen 36)
[20:50:17] Assembly optimizations on if available.
[20:50:17] Entering M.D.
[20:50:40] al work pa- Starting from initial work packet
[20:50:40] Project: 2665 (Run 3, Clone 325, Gen 36)
[20:50:42] Entering M.D.
[20:50:48] Rejecting checkpoint
[20:50:50] Protein: HGG in water
[20:50:57] Extra SSE boost OK.
[20:50:58] Completed 0 out of 250000 steps  (0 percent)
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Re: Project 2665 (Run 3, Clone 325, Gen 36)
Post by Leoslocks »
Getting that client over and over is just plain wrong.
Stop client. Delete the fahcore, work folder, unitinfo.txt, and queue.dat file. Start client.
lobuxracer
Yeah, I know to do that, but I'm getting an EUE so I'm not losing points, and there is some value in sending the EUE - at least they know there is an issue with this WU. It just seems a waste to have it recycle so many times.
lobuxracer
Re: Project: 2665 (Run 3, Clone 325, Gen 36)
**UPDATE** This little gem continued to be the bane of my folding. I counted a total of 10 attempts to run this WU, all 10 failed at 40%. I finally succumbed and killed the work folder, unitinfo, queue, and Fahcore to ensure everything was fresh. If I see it again, I'll delete it with extreme prejudice.
Try to use qfix on this one ...
rbrandman
Pande Group Member
Post by rbrandman »
Thanks for the updates on this work unit. I'll let the researcher in charge of this project (Peter Kasson) know so he can look into it.
Relly
