I'm going to move your post so that it's associated with the server discussion rather than as a problem with an individual WU.
zananzelm wrote:As in the subject it seems that i cannot upload a completed WU.
My connection is a single line isdn used not only for folding so a pretty slow one but The GPU Client has never had problem uploading a WU.
I have already had issues uploading CPU Client WUs but after some retry it has always been able to upload.
This time seems that there is no solution.
Already tried to upload it using -send command switch but i cannot make it work.
should i delete the WU or is there another solution?
Can someone help me solving this?
extract of the queue list:extract of the logfile:Code: Select all
Slot 02 Done Project: 3903 (Run 1626, Clone 2, Gen 7), Core: 79 Work server: 171.64.122.83:8080 Collection server: 171.64.122.76 Download date: August 18 07:44:12 Finished date: August 19 06:56:40 Failed uploads: 48
[15:26:11] Project: 3903 (Run 1626, Clone 2, Gen 7) [15:26:11] + Attempting to send results [August 26 15:26:11 UTC] [15:26:14] - Couldn't send HTTP request to server [15:26:14] (Got status 503) [15:26:14] + Could not connect to Work Server (results) [15:26:14] (171.64.122.83:8080) [15:26:14] + Retrying using alternative port [15:26:16] - Couldn't send HTTP request to server [15:26:16] (Got status 503) [15:26:16] + Could not connect to Work Server (results) [15:26:16] (171.64.122.83:80) [15:26:16] - Error: Could not transmit unit 02 (completed August 19) to work server. [15:26:16] + Attempting to send results [August 26 15:26:16 UTC] [15:26:18] - Couldn't send HTTP request to server [15:26:18] (Got status 503) [15:26:18] + Could not connect to Work Server (results) [15:26:18] (171.64.122.76:8080) [15:26:18] + Retrying using alternative port [15:26:20] - Couldn't send HTTP request to server [15:26:20] (Got status 503) [15:26:20] + Could not connect to Work Server (results) [15:26:20] (171.64.122.76:80) [15:26:20] Could not transmit unit 02 to Collection server; keeping in queue.
