Project: 2665 (Run 0, Clone 479, Gen 20)
Insidious
Appears to be a bad work unit. (0 steps completed prior to EUE)
Reason: edited title with correct WU data format
Leoslocks
- Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Re: Project: 2665 (Run 0, Clone 479, Gen 20)
I concur.
I was recovering from a hardware failure that took out my garden last night. Saw the EUE occur as I was checking out this machine. The client killed itself so I dropped in the Folding@Home Client Version 6.22 SMP Beta2r3
The EUE did not kill the client with the consecutive EUEs.
Cheers!
[16:02:49] Project: 2665 (Run 0, Clone 571, Gen 41)
[16:02:49] + Attempting to send results [August 24 16:02:49 UTC]
[16:10:12] + Results successfully sent
[16:10:12] Thank you for your contribution to Folding@Home.
[16:10:12] + Number of Units Completed: 2
[16:10:12] Using generic mpiexec calls
[16:12:15] - Preparing to get new work unit...
[16:12:15] + Attempting to get work packet
[16:12:15] - Connecting to assignment server
[16:12:16] - Successful: assigned to (171.64.65.64).
[16:12:16] + News From Folding@Home: Welcome to Folding@Home
[16:12:16] Loaded queue successfully.
[16:12:32] + Closed connections
[16:12:32]
[16:12:32] + Processing work unit
[16:12:32] Work type a1 not eligible for variable processors
[16:12:32] Core required: FahCore_a1.exe
[16:12:32] Core found.
[16:12:32] Using generic mpiexec calls
[16:12:32] Working on queue slot 03 [August 24 16:12:32 UTC]
[16:12:32] + Working ...
[16:12:32]
[16:12:32] *------------------------------*
[16:12:32] Folding@Home Gromacs SMP Core
[16:12:32] Version 1.74 (March 10, 2007)
[16:12:32]
[16:12:32] Preparing to commence simulation
[16:12:32] - Ensuring status. Please wait.
[16:12:37] - Starting from initial work packet
[16:12:38]
[16:12:38] Project: 2665 (Run 0, Clone 479, Gen 20)
[16:12:38]
[16:12:38] Assembly optimizations on if available.
[16:12:38] Entering M.D.
[16:12:59] al work packet
[16:12:59]
[16:12:59] Project: 2665 (Run 0, Clone 479, Gen 20)
[16:12:59]
[16:12:59] Entering M.D.
[16:13:00] ne 479, Gen 20)
[16:13:00]
[16:13:01] Entering M.D.
[16:13:08] Rejecting checkpoint
[16:13:10] Protein: HGG in waterExtra SSE boost OK.
[16:13:10]
[16:13:16] Extra SSE boost OK.
[16:13:17] what have done.
[16:13:17] logf- Failed to delete work/wudata_03.arc
[16:13:17] - FaileGromacs cannot continue further.
[16:13:17] Going to send back what have done.
[16:13:17] logfile size: 9422
[16:13:17] - Writing 9958 bytes of core data to disk...
[16:13:17] ... Done.
[16:13:17]
[16:13:17] Warning: check for stray files
[16:13:17] s
[16:13:17] - Failed to delete work/wudata_03.goe
[16:13:17] led to delete work/wudata_03.goe
[16:13:17]
[16:13:17] Folding@home Core Shutdown: EARLY_UNIT_END
[16:13:17] Finalizing output
[16:15:21] CoreStatus = 7B (123)
[16:15:21] Client-core communications error: ERROR 0x7b
[16:15:21] This is a sign of more serious problems, shutting down.
--- Opening Log file [August 24 18:09:54 UTC]
http://folding.stanford.edu
Launch directory: C:\F@H
Executable: C:\F@H\Folding@home-Win32-x86.exe
Arguments: -smp
[18:09:54] - Ask before connecting: No
[18:09:54] - User name: [inMEMORYof]_rangeral (Team 34878)
[18:09:54] - User ID: 1E6E8159239C24FA
[18:09:54] - Machine ID: 1
[18:09:54]
[18:09:55] Loaded queue successfully.
[18:09:55]
[18:09:55] + Processing work unit
[18:09:55] Work type a1 not eligible for variable processors
[18:09:55] Core required: FahCore_a1.exe
[18:09:55] Core found.
[18:09:55] Using generic mpiexec calls
[18:09:55] Working on queue slot 03 [August 24 18:09:55 UTC]
[18:09:55] + Working ...
[18:09:55]
[18:09:55] *------------------------------*
[18:09:55] Folding@Home Gromacs SMP Core
[18:09:55] Version 1.74 (March 10, 2007)
[18:09:55]
[18:09:55] Preparing to commence simulation
[18:09:55] - Looking at optimizations...
[18:09:55] - Created dyn
[18:09:55] - Files status OK
[18:09:55]
[18:09:55] Folding@home Core Shutdown: MISSING_WORK_FILES
[18:09:55] Finalizing output
[18:11:58] CoreStatus = 1 (1)
[18:11:58] Client-core communications error: ERROR 0x1
[18:11:58] Deleting current work unit & continuing...
[18:11:58] Using generic mpiexec calls
[18:14:19] - Preparing to get new work unit...
[18:14:19] + Attempting to get work packet
[18:14:19] - Connecting to assignment server
[18:14:19] - Successful: assigned to (171.64.65.64).
[18:14:19] + News From Folding@Home: Welcome to Folding@Home
[18:14:20] Loaded queue successfully.
[18:14:37] + Closed connections
[18:14:42]
[18:14:42] + Processing work unit
[18:14:42] Work type a1 not eligible for variable processors
[18:14:42] Core required: FahCore_a1.exe
[18:14:42] Core found.
[18:14:42] Using generic mpiexec calls
[18:14:42] Working on queue slot 04 [August 24 18:14:42 UTC]
[18:14:42] + Working ...
[18:14:42]
[18:14:42] *------------------------------*
[18:14:42] Folding@Home Gromacs SMP Core
[18:14:42] Version 1.74 (March 10, 2007)
[18:14:42]
[18:14:42] Preparing to commence simulation
[18:14:42] - Ensuring status. Please wait.
[18:14:59] - Looking at optimizations...
[18:14:59] - Working with standard loops on this execution.
[18:14:59] - Previous termination of core was improper.
[18:14:59] - Going to use standard loops.
[18:14:59] - Files status OK
[18:15:09] (decompressed 515.8 percent)
[18:15:09] - Starting from initial work packet
[18:15:09]
[18:15:09] Project: 2665 (Run 0, Clone 479, Gen 20)
[18:15:09]
[18:15:11] 65 (Run 0, Clone 479, Gen 20)
[18:15:11]
[18:15:12] Entering M.D.
[18:15:18] Rejecting checkpoint
[18:15:20] Protein: HGG in water
[18:15:20] Writing local files
[18:15:25] Extra SSE boost OK.
[18:15:25] 422
[18:15:25] - Writing 9958 bytes of core data to disk...
[18:15:25] ... Done.
[18:15:25] - Failed to delete work/wudata_04.arc
[18:15:25] - Failed to delete work/wudata_04.xtc
[18:15:25] No C.P. to delete.
[18:15:25] - Failed to - Failed to delete work/wudata_04.bed
[18:15:25] - Failed to delete work/wudata_04.sas
[18:15:25] - Failed to delete work/wudata_04.goe
[18:15:25] Warning: check for stray files
[18:15:25]
[18:15:25] Folding@home Core Shutdown: EARLY_UNIT_END
[18:15:25] Finalizing output
[18:17:26] END
[18:17:26] Finalizing output
[18:17:29] CoreStatus = 7B (123)
[18:17:29] Client-core communications error: ERROR 0x7b
[18:17:29] Deleting current work unit & continuing...
[18:17:29] Using generic mpiexec calls
[18:19:32] - Preparing to get new work unit...
[18:19:32] + Attempting to get work packet
[18:19:32] - Connecting to assignment server
[18:19:33] - Successful: assigned to (171.64.65.64).
[18:19:33] + News From Folding@Home: Welcome to Folding@Home
[18:19:33] Loaded queue successfully.
[18:19:55] + Closed connections
[18:20:00]
[18:20:00] + Processing work unit
[18:20:00] Work type a1 not eligible for variable processors
[18:20:00] Core required: FahCore_a1.exe
[18:20:00] Core found.
[18:20:00] Using generic mpiexec calls
[18:20:00] Working on queue slot 05 [August 24 18:20:00 UTC]
[18:20:00] + Working ...
[18:20:01]
[18:20:01] *------------------------------*
[18:20:01] Folding@Home Gromacs SMP Core
[18:20:01] Version 1.74 (March 10, 2007)
[18:20:01]
[18:20:01] Preparing to commence simulation
[18:20:01] - Ensuring status. Please wait.
[18:20:05] - Starting from initial work packet
[18:20:05]
[18:20:05] Project: 2665 (Run 0, Clone 479, Gen 20)
[18:20:05]
[18:20:06] Assembly optimizations on if available.
[18:20:06] Entering M.D.
[18:20:26] percent)
[18:20:27] - Starting from initial work packet
[18:20:27]
[18:20:27] Project: 2665 (Run 0, Clone 479, Gen 20)
[18:20:27]
[18:20:28] Entering M.D.
[18:20:35] Rejecting checkpoint
[18:20:36] Protein: HGG in water
[18:20:36] Writing local files
[18:20:41] Extra SSE boost OK.
[18:20:42] what have done.
[18:20:42] logfile size: 9421
[18:20:42] - Writing 9957 bytes of core dGromacs cannot continue further.
[18:20:42] Going to send back what have done.
[18:20:42] - Writing 9957 bytes of core data to disk...
[18:20:42] ... Done.
[18:20:42] ailed to delete work/wudata_05.sas
[18:20:42] - Failed to delete work/wudata_05.goe
[18:20:42] Warning: che
[18:20:42] Folding@home Core Shutdown: EARLY_UNIT_END
[18:20:42] Finalizing output
[18:20:42] files
[18:22:42] zing output
[18:22:42] e Core Shutdown: EARLY_UNIT_END
[18:22:42] Finalizing output
[18:22:46] CoreStatus = 7B (123)
[18:22:46] Client-core communications error: ERROR 0x7b
[18:22:46] - Attempting to download new core...
[18:22:46] + Downloading new core: FahCore_a1.exe
[18:22:47] + 10240 bytes downloaded
[18:22:47] + 20480 bytes downloaded
[18:22:47] + 30720 bytes downloaded
[18:22:47] + 40960 bytes downloaded
[18:22:47] + 51200 bytes downloaded
[18:22:47] + 61440 bytes downloaded
[18:22:47] + 71680 bytes downloaded
[18:22:47] + 81920 bytes downloaded
[18:22:47] + 92160 bytes downloaded
[18:22:47] + 102400 bytes downloaded
[18:22:47] + 112640 bytes downloaded
[18:22:47] + 122880 bytes downloaded
[18:22:47] + 133120 bytes downloaded
[18:22:47] + 143360 bytes downloaded
[18:22:47] + 153600 bytes downloaded
[18:22:47] + 163840 bytes downloaded
[18:22:48] + 174080 bytes downloaded
[18:22:48] + 184320 bytes downloaded
[18:22:48] + 194560 bytes downloaded
[18:22:48] + 204800 bytes downloaded
[18:22:48] + 215040 bytes downloaded
[18:22:48] + 225280 bytes downloaded
[18:22:48] + 235520 bytes downloaded
[18:22:48] + 245760 bytes downloaded
[18:22:48] + 256000 bytes downloaded
[18:22:48] + 266240 bytes downloaded
[18:22:48] + 276480 bytes downloaded
[18:22:48] + 286720 bytes downloaded
[18:22:48] + 296960 bytes downloaded
[18:22:48] + 307200 bytes downloaded
[18:22:48] + 317440 bytes downloaded
[18:22:48] + 327680 bytes downloaded
[18:22:48] + 337920 bytes downloaded
[18:22:48] + 348160 bytes downloaded
[18:22:48] + 358400 bytes downloaded
[18:22:48] + 368640 bytes downloaded
[18:22:48] + 378880 bytes downloaded
[18:22:48] + 389120 bytes downloaded
[18:22:48] + 399360 bytes downloaded
[18:22:48] + 409600 bytes downloaded
[18:22:48] + 419840 bytes downloaded
[18:22:48] + 430080 bytes downloaded
[18:22:48] + 440320 bytes downloaded
[18:22:48] + 450560 bytes downloaded
[18:22:48] + 460800 bytes downloaded
[18:22:48] + 471040 bytes downloaded
[18:22:48] + 481280 bytes downloaded
[18:22:48] + 491520 bytes downloaded
[18:22:48] + 501760 bytes downloaded
[18:22:48] + 512000 bytes downloaded
[18:22:48] + 522240 bytes downloaded
[18:22:48] + 532480 bytes downloaded
[18:22:48] + 542720 bytes downloaded
[18:22:48] + 552960 bytes downloaded
[18:22:48] + 563200 bytes downloaded
[18:22:48] + 573440 bytes downloaded
[18:22:48] + 583680 bytes downloaded
[18:22:48] + 593920 bytes downloaded
[18:22:48] + 604160 bytes downloaded
[18:22:48] + 614400 bytes downloaded
[18:22:48] + 624640 bytes downloaded
[18:22:48] + 634880 bytes downloaded
[18:22:48] + 645120 bytes downloaded
[18:22:48] + 655360 bytes downloaded
[18:22:48] + 665600 bytes downloaded
[18:22:48] + 675840 bytes downloaded
[18:22:48] + 686080 bytes downloaded
[18:22:48] + 696320 bytes downloaded
[18:22:49] + 706560 bytes downloaded
[18:22:49] + 716800 bytes downloaded
[18:22:49] + 727040 bytes downloaded
[18:22:49] + 737280 bytes downloaded
[18:22:49] + 747520 bytes downloaded
[18:22:49] + 757760 bytes downloaded
[18:22:49] + 768000 bytes downloaded
[18:22:49] + 778240 bytes downloaded
[18:22:49] + 788480 bytes downloaded
[18:22:49] + 789667 bytes downloaded
[18:22:49] Verifying core Core_a1.fah...
[18:22:49] Signature is VALID
[18:22:49]
[18:22:49] Trying to unzip core FahCore_a1.exe
[18:22:49] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[18:22:54] + Core successfully engaged
[18:22:54] Deleting current work unit & continuing...
[18:22:54] Using generic mpiexec calls
[18:24:56] - Preparing to get new work unit...
[18:24:56] + Attempting to get work packet
[18:24:56] - Connecting to assignment server
[18:24:57] - Successful: assigned to (171.64.65.64).
[18:24:57] + News From Folding@Home: Welcome to Folding@Home
[18:24:57] Loaded queue successfully.
[18:24:58] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[18:25:17] + Attempting to get work packet
[18:25:17] - Connecting to assignment server
[18:25:18] - Successful: assigned to (171.64.65.64).
[18:25:18] + News From Folding@Home: Welcome to Folding@Home
[18:25:18] Loaded queue successfully.
[18:25:36] + Closed connections
[18:25:41]
[18:25:41] + Processing work unit
[18:25:41] Work type a1 not eligible for variable processors
[18:25:41] Core required: FahCore_a1.exe
[18:25:41] Core found.
[18:25:41] Using generic mpiexec calls
[18:25:41] Working on queue slot 06 [August 24 18:25:41 UTC]
[18:25:41] + Working ...
[18:25:41]
[18:25:41] *------------------------------*
[18:25:41] Folding@Home Gromacs SMP Core
[18:25:41] Version 1.74 (March 10, 2007)
[18:25:41]
[18:25:41] Preparing to commence simulation
[18:25:41] - Ensuring status. Please wait.
[18:25:45] - Starting from initial work packet
[18:25:45]
[18:25:45] Project: 2665 (Run 1, Clone 307, Gen 44)
[18:25:45]
[18:25:46] Assembly optimizations on if available.
[18:25:46] Entering M.D.
[18:26:06] al work packet
[18:26:06]
[18:26:06] Project: 2665 (Run 1, Clone 307, Gen 44)
[18:26:06]
[18:26:07] 65 (Run 1, Clone 307, Gen 44)
[18:26:07]
[18:26:08] Entering M.D.
[18:26:14] Rejecting checkpoint
[18:26:16] Protein: IBX in water
[18:26:16] Writing local files
[18:26:21] Extra SSE boost OK.
[18:26:21] Writing local files
[18:26:21] Completed 0 out of 250000 steps (0 percent)The EUE did not kill the client with the consecutive EUEs.
Cheers!
There are a lot of reports for partial credit for this WU, but no one make it to 100%
