Can slow CPUs make a difference?
Minto
Post by Minto »
I have my ps3, 2 desktops and a laptop all with 3.0+GHZ CPUs running F@H, but I'm wondering should I use it with my little 900mhz CPU ? or even my 1.6ghz CPU? Would the slow processors make a difference,...enough of a difference to actually use them?
Trivolve
Hardware configuration: Core 2 Duo E6300@3.36Ghz/Scythe Ninja Plus
Asus Commando
2x2GB Corsair XMS2 DHX @ 960Mhz 5/5/5/18
Leadtek Nvidia 8800GTS 320mb @ 621/1438/999
2x250GB Seagate 7200.10 RAID 0
Samsung 931BF
Microsoft Wireless Desktop 3000
Re: Can slow CPUs make a difference?
Post by Trivolve »
Almost every CPU makes a difference.... as long as they can complete their WUs. Your 900Mhz CPU must use the uniprocessor, but it should be able to complete its WUs (i think the cut-off is about 400mhz for 24/7 folding to complete WUs).
If you think about it, there're are 209,951 active processor... so even if i have a 6ghz CPU it's only one processor out of 209,951... so of course every little bit counts =)
Team 134888 - Team Trivolve.
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Post by John Naylor »
The last I read about lowest that will finish before preferred deadlines was a Pentium 3 @ 550MHz. Your 900MHz and 1.6GHz CPUs are welcome to contribute, definitely :D Although for the 900MHz one it should run for a large part of the day to ensure it completes units in time.
And more importantly: Welcome to the forums!
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
divery4eyes
Hardware configuration: E2180 @1.08, 2Gb ddr2, 500Gb hd, Last XP, 8800 GT 1835 shader
AMD Athlon x2 2200, 2GB DDR2, ?? GB HD, Last XP, GT 240 1600 shader
Post by divery4eyes »
Every little bit helps.
For example, i run 1.2 Conroe chips, while not as fast as the "big"
boyz they hold their own.
over 30,000 werk units
"Everyone is in the same boat. Grab an oar, and paddle some WU's." -RAH
Still GPU folding with 8.2 teraflops
