Project: 4432 (Run 339, Clone 1, Gen 12) - No Credit?
infiniteloop
Location: Buried under a steaming pile of COBOL code in Jurassic Park
Post by infiniteloop »
I (User name: infin8loop (Team 57391)) have not received credit for the last two WUs sent to server 171.64.122.78.
There is either an issue with the chicken (the server) or the eggs (the WU's). :ewink:
I posted this in the "Issues with a specific Server" forum at first and received no response.
A response to another folder with a similar issue instructed that folder to post here. So here goes.
Here is the first of two WU:
-- August 6, 2008 ---
[03:06:12] - Preparing to get new work unit...
[03:06:12] + Attempting to get work packet
[03:06:12] - Will indicate memory of 1014 MB
[03:06:12] - Connecting to assignment server
[03:06:12] Connecting to http://assign.stanford.edu:8080/
[03:06:13] Posted data.
[03:06:13] Initial: 40AB; - Successful: assigned to (171.64.122.78).
[03:06:13] + News From Folding@Home: Welcome to Folding@Home
[03:06:13] Loaded queue successfully.
[03:06:13] Connecting to http://171.64.122.78:8080/
[03:06:14] Posted data.
[03:06:14] Initial: 0000; - Receiving payload (expected size: 239313)
[03:06:15] - Downloaded at ~233 kB/s
[03:06:15] - Averaged speed for that direction ~139 kB/s
[03:06:15] + Received work.
[03:06:15] Trying to send all finished work units
[03:06:15] + No unsent completed units remaining.
[03:06:15] + Closed connections
[03:06:15]
[03:06:15] + Processing work unit
[03:06:15] Core required: FahCore_78.exe
[03:06:15] Core found.
[03:06:15] Working on Unit 03 [August 6 03:06:15]
[03:06:15] + Working ...
[03:06:15] - Calling 'FahCore_78.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 2372 -version 504'
[03:06:16]
[03:06:16] *------------------------------*
[03:06:16] Folding@Home Gromacs Core
[03:06:16] Version 1.90 (March 8, 2006)
[03:06:16]
[03:06:16] Preparing to commence simulation
[03:06:16] - Looking at optimizations...
[03:06:16] - Created dyn
[03:06:16] - Files status OK
[03:06:16] - Expanded 238801 -> 1168241 (decompressed 489.2 percent)
[03:06:16] - Starting from initial work packet
[03:06:16]
[03:06:16] Project: 4432 (Run 339, Clone 1, Gen 12)
[03:06:16]
[03:06:16] Assembly optimizations on if available.
[03:06:16] Entering M.D.
[03:06:22] Protein: p4432_Seq41_Amber03
[03:06:22]
[03:06:22] Writing local files
[03:08:11] Extra SSE boost OK.
[03:08:11] Writing local files
[03:08:11] Completed 0 out of 2500000 steps (0)
[03:23:11] Timered checkpoint triggered.
[03:33:54] Writing local files
[03:33:54] Completed 25000 out of 2500000 steps (1)
[03:48:54] Timered checkpoint triggered.
[03:59:36] Writing local files
[03:59:36] Completed 50000 out of 2500000 steps (2)
[04:14:36] Timered checkpoint triggered.
[04:28:40] Writing local files
[04:28:40] Completed 75000 out of 2500000 steps (3)
-- clipped, following part of log starts August 9, 2008 ---
[13:32:08] Writing local files
[13:32:08] Completed 2450000 out of 2500000 steps (98)
[13:48:07] Timered checkpoint triggered.
[13:56:36] Writing local files
[13:56:36] Completed 2475000 out of 2500000 steps (99)
[14:12:36] Timered checkpoint triggered.
[14:21:07] Writing local files
[14:21:07] Completed 2500000 out of 2500000 steps (100)
[14:21:07] Writing final coordinates.
[14:21:08] Past main M.D. loop
[14:22:08]
[14:22:08] Finished Work Unit:
[14:22:08] - Reading up to 1136160 from "work/wudata_03.arc": Read 1136160
[14:22:08] - Reading up to 550576 from "work/wudata_03.xtc": Read 550576
[14:22:08] goefile size: 0
[14:22:08] logfile size: 134353
[14:22:08] Leaving Run
[14:22:12] - Writing 1830685 bytes of core data to disk...
[14:22:13] Done: 1830173 -> 1602329 (compressed to 87.5 percent)
[14:22:13] ... Done.
[14:22:13] - Shutting down core
[14:22:13]
[14:22:13] Folding@home Core Shutdown: FINISHED_UNIT
[14:22:15] CoreStatus = 64 (100)
[14:22:15] Unit 3 finished with 94 percent of time to deadline remaining.
[14:22:15] Updated performance fraction: 0.959979
[14:22:15] Sending work to server
[14:22:15] + Attempting to send results
[14:22:15] - Reading file work/wuresults_03.dat from core
[14:22:15] (Read 1602841 bytes from disk)
[14:22:15] Connecting to http://171.64.122.78:8080/
[14:22:41] Posted data.
[14:22:42] Initial: 0000; - Uploaded at ~58 kB/s
[14:22:42] - Averaged speed for that direction ~55 kB/s
[14:22:42] + Results successfully sent
[14:22:42] Thank you for your contribution to Folding@Home.
[14:22:42] + Number of Units Completed: 31
[14:22:46] Trying to send all finished work units
[14:22:46] + No unsent completed units remaining.
Below is the log for the first part of the next WU that shows the date
[14:22:46] - Preparing to get new work unit...
[14:22:46] + Attempting to get work packet
[14:22:46] - Will indicate memory of 1014 MB
[14:22:46] - Connecting to assignment server
[14:22:46] Connecting to http://assign.stanford.edu:8080/
[14:22:47] Posted data.
[14:22:47] Initial: 40AB; - Successful: assigned to (171.64.122.78).
[14:22:47] + News From Folding@Home: Welcome to Folding@Home
[14:22:47] Loaded queue successfully.
[14:22:47] Connecting to http://171.64.122.78:8080/
[14:22:47] Initial: 0000; - Receiving payload (expected size: 239194)
[14:22:48] - Downloaded at ~233 kB/s
[14:22:48] - Averaged speed for that direction ~158 kB/s
[14:22:48] + Received work.
[14:22:48] Trying to send all finished work units
[14:22:48] + No unsent completed units remaining.
[14:22:48] + Closed connections
[14:22:48]
[14:22:48] + Processing work unit
[14:22:48] Core required: FahCore_78.exe
[14:22:49] Core found.
[14:22:49] Working on Unit 04 [August 9 14:22:49]
infiniteloop
Project: 4432 (Run 183, Clone 4, Gen 9) - No Credit?
There is either an issue with the chicken (the server) or the eggs (the WU's). :ewink: (Yes, I'm repeating myself, blah, blah, blah)
Here is the second of two WU:
[14:22:48]
[14:22:49] + Working ...
[14:22:49] - Calling 'FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 4828 -version 504'
[14:22:49]
[14:22:49] *------------------------------*
[14:22:49] Folding@Home Gromacs Core
[14:22:49] Version 1.90 (March 8, 2006)
[14:22:49]
[14:22:49] Preparing to commence simulation
[14:22:49] - Looking at optimizations...
[14:22:49] - Created dyn
[14:22:49] - Files status OK
[14:22:49] - Expanded 238682 -> 1168241 (decompressed 489.4 percent)
[14:22:49] - Starting from initial work packet
[14:22:49]
[14:22:49] Project: 4432 (Run 183, Clone 4, Gen 9)
[14:22:49]
[14:22:49] Assembly optimizations on if available.
[14:22:49] Entering M.D.
[14:22:55] Protein: p4432_Seq41_Amber03
[14:22:55]
[14:22:55] Writing local files
[14:24:40] Extra SSE boost OK.
[14:24:41] Writing local files
[14:24:41] Completed 0 out of 2500000 steps (0)
[14:40:40] Timered checkpoint triggered.
[14:49:11] Writing local files
[14:49:11] Completed 25000 out of 2500000 steps (1)
[15:05:10] Timered checkpoint triggered.
[15:13:42] Writing local files
[15:13:42] Completed 50000 out of 2500000 steps (2)
[15:29:42] Timered checkpoint triggered.
[15:38:12] Writing local files
[15:38:12] Completed 75000 out of 2500000 steps (3)
-- clipped, following part of log starts and ends August 11, 2008 ---
[09:04:32] Writing local files
[09:04:32] Completed 2450000 out of 2500000 steps (98)
[09:20:33] Timered checkpoint triggered.
[09:28:53] Writing local files
[09:28:53] Completed 2475000 out of 2500000 steps (99)
[09:44:54] Timered checkpoint triggered.
[09:53:16] Writing local files
[09:53:16] Completed 2500000 out of 2500000 steps (100)
[09:53:16] Writing final coordinates.
[09:53:16] Past main M.D. loop
[09:54:16]
[09:54:16] Finished Work Unit:
[09:54:16] - Reading up to 1136160 from "work/wudata_04.arc": Read 1136160
[09:54:16] - Reading up to 543388 from "work/wudata_04.xtc": Read 543388
[09:54:16] goefile size: 0
[09:54:16] logfile size: 100671
[09:54:16] Leaving Run
[09:54:20] - Writing 1789815 bytes of core data to disk...
[09:54:21] Done: 1789303 -> 1596829 (compressed to 89.2 percent)
[09:54:21] ... Done.
[09:54:21] - Shutting down core
[09:54:21]
[09:54:21] Folding@home Core Shutdown: FINISHED_UNIT
[09:54:24] CoreStatus = 64 (100)
[09:54:24] Unit 4 finished with 97 percent of time to deadline remaining.
[09:54:24] Updated performance fraction: 0.962225
[09:54:24] Sending work to server
[09:54:24] + Attempting to send results
[09:54:24] - Reading file work/wuresults_04.dat from core
[09:54:24] (Read 1597341 bytes from disk)
[09:54:24] Connecting to http://171.64.122.78:8080/
[09:54:51] Posted data.
[09:54:51] Initial: 0000; - Uploaded at ~57 kB/s
[09:54:51] - Averaged speed for that direction ~55 kB/s
[09:54:51] + Results successfully sent
[09:54:51] Thank you for your contribution to Folding@Home.
[09:54:51] + Number of Units Completed: 32
[09:54:55] Trying to send all finished work units
[09:54:55] + No unsent completed units remaining.
[09:54:55] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[09:54:55] Killing all core threads
Folding@Home Client Shutdown.
Re: Project: 4432 (Run 339, Clone 1, Gen 12) - No Credit?
Please see this thread, PandeGroup is aware of the issue : viewtopic.php?f=19&t=5025
