Can't even work out where to put the question
Fuzz
Post by Fuzz »
:lol:
SMP client...
GPU Core beta version 1.1 ??
Erm where should I post about an issue in setting this puppy up on two Graphics Cards's ? :?
Re: Can't even work out where to put the question
I'd say here : viewforum.php?f=49 (pick the correct section if it applies to NV, ATI or both).
Fuzz
Post by Fuzz »
Cheers
Fuzz
Post by Fuzz »
4 different links within the same page, some no help, others nvidia based, some a mix of the two, some talking about different clients
No better off than I was half hour ago, no matter. :(
The GPU FAQs on the project home page have info for setting up dual GPUs, so start there if you haven't been there yet. Same for the SMP setup. Otherwise...
The setup of the SMP client and the GPU client are separate issues. Create two new posts, once in the SMP section, and once in the GPU section with your GPU type.
If your topic is a duplicate of an existing thread, trust the Mods to merge it or move it to the correct location. Just go for it. The sooner you start folding, the better.
