Project: 3903 (Run 3505, Clone 3, Gen 7)
DAR
Post by DAR »
I finished this project at August 14. But I have not received credits for it.
This project stayed in the queue for a while. So maybe it was transmitted the 15th.
I had a backup. So I transmitted it a few times, but no credits.
Thanks,
DAR
Re: Project: 3903 (Run 3505, Clone 3, Gen 7)
Hi DAR (team 53650),
Your WU (P3903 R3505 C3 G7) was added to the stats database on 2008-08-14 02:39:51 for 0 points of credit.
Your WU (P3903 R3505 C3 G7) was added to the stats database on 2008-08-14 08:40:58 for 0 points of credit.
You're not alone with multiple reports for 0 points ... there is something strange going on here :(
PM sent.
Can you post a log from your client showing its startup ?
DAR
Post by DAR »
Hi,
Underneath the startup of my logfile.
I also have the .dat file of this finished project. It is 7628 Kb in size. If you want I can upload it to my website and send you a direct link. So you can download it and have a check.
--- Opening Log file [August 8 18:22:06 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\DAR\Bureaublad\new 4
Executable: C:\Documents and Settings\DAR\Bureaublad\new 4\fah622-win32-x86.exe
[18:22:06] - Ask before connecting: No
[18:22:06] - User name: DAR (Team 53650)
[18:22:06] - User ID: 14A54BB2CD59ADE
[18:22:06] - Machine ID: 4
[18:22:06]
[18:22:06] Work directory not found. Creating...
[18:22:06] Could not open work queue, generating new queue...
[18:22:06] - Preparing to get new work unit...
[18:22:06] + Attempting to get work packet
[18:22:06] - Connecting to assignment server
[18:22:07] - Successful: assigned to (171.64.122.83).
[18:22:07] + News From Folding@Home: Welcome to Folding@Home
[18:22:07] Loaded queue successfully.
[18:22:07] - Couldn't send HTTP request to server
[18:22:07]   (Got status 503)
[18:22:07] + Could not connect to Work Server
[18:22:07] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[18:22:22] + Attempting to get work packet
[18:22:22] - Connecting to assignment server
[18:22:23] - Successful: assigned to (171.64.122.83).
[18:22:23] + News From Folding@Home: Welcome to Folding@Home
[18:22:23] Loaded queue successfully.
[18:23:18] + Closed connections
[18:23:18]
[18:23:18] + Processing work unit
[18:23:18] Core required: FahCore_79.exe
[18:23:18] Core not found.
[18:23:18] - Core is not present or corrupted.
[18:23:18] - Attempting to download new core...
[18:23:18] + Downloading new core: FahCore_79.exe
[18:23:19] + 10240 bytes downloaded
[18:23:20] + 20480 bytes downloaded
[18:23:20] + 30720 bytes downloaded
[18:23:20] + 40960 bytes downloaded
[18:23:20] + 51200 bytes downloaded
[18:23:20] + 61440 bytes downloaded
[18:23:20] + 71680 bytes downloaded
[18:23:20] + 81920 bytes downloaded
[18:23:20] + 92160 bytes downloaded
[18:23:20] + 102400 bytes downloaded
[18:23:21] + 112640 bytes downloaded
[18:23:21] + 122880 bytes downloaded
[18:23:21] + 133120 bytes downloaded
[18:23:21] + 143360 bytes downloaded
[18:23:21] + 153600 bytes downloaded
[18:23:21] + 163840 bytes downloaded
[18:23:21] + 174080 bytes downloaded
[18:23:21] + 184320 bytes downloaded
[18:23:21] + 194560 bytes downloaded
[18:23:21] + 204800 bytes downloaded
[18:23:21] + 215040 bytes downloaded
[18:23:21] + 225280 bytes downloaded
[18:23:21] + 235520 bytes downloaded
[18:23:21] + 245760 bytes downloaded
[18:23:21] + 256000 bytes downloaded
[18:23:21] + 266240 bytes downloaded
[18:23:21] + 276480 bytes downloaded
[18:23:21] + 286720 bytes downloaded
[18:23:21] + 296960 bytes downloaded
[18:23:21] + 307200 bytes downloaded
[18:23:21] + 317440 bytes downloaded
[18:23:21] + 327680 bytes downloaded
[18:23:21] + 337920 bytes downloaded
[18:23:21] + 348160 bytes downloaded
[18:23:21] + 358400 bytes downloaded
[18:23:21] + 368640 bytes downloaded
[18:23:21] + 378880 bytes downloaded
[18:23:21] + 389120 bytes downloaded
[18:23:21] + 399360 bytes downloaded
[18:23:21] + 409600 bytes downloaded
[18:23:21] + 419840 bytes downloaded
[18:23:21] + 430080 bytes downloaded
[18:23:21] + 440320 bytes downloaded
[18:23:21] + 450560 bytes downloaded
[18:23:21] + 460800 bytes downloaded
[18:23:21] + 471040 bytes downloaded
[18:23:22] + 481280 bytes downloaded
[18:23:22] + 491520 bytes downloaded
[18:23:22] + 501760 bytes downloaded
[18:23:22] + 512000 bytes downloaded
[18:23:22] + 522240 bytes downloaded
[18:23:22] + 532480 bytes downloaded
[18:23:22] + 542720 bytes downloaded
[18:23:22] + 552960 bytes downloaded
[18:23:22] + 563200 bytes downloaded
[18:23:22] + 573440 bytes downloaded
[18:23:22] + 583680 bytes downloaded
[18:23:22] + 593920 bytes downloaded
[18:23:22] + 604160 bytes downloaded
[18:23:22] + 614400 bytes downloaded
[18:23:22] + 624640 bytes downloaded
[18:23:22] + 634880 bytes downloaded
[18:23:22] + 645120 bytes downloaded
[18:23:22] + 655360 bytes downloaded
[18:23:22] + 665600 bytes downloaded
[18:23:22] + 675840 bytes downloaded
[18:23:22] + 686080 bytes downloaded
[18:23:22] + 696320 bytes downloaded
[18:23:22] + 706560 bytes downloaded
[18:23:22] + 716800 bytes downloaded
[18:23:22] + 727040 bytes downloaded
[18:23:22] + 737280 bytes downloaded
[18:23:22] + 747520 bytes downloaded
[18:23:23] + 757760 bytes downloaded
[18:23:23] + 768000 bytes downloaded
[18:23:23] + 778240 bytes downloaded
[18:23:23] + 788480 bytes downloaded
[18:23:23] + 798720 bytes downloaded
[18:23:24] + 808960 bytes downloaded
[18:23:24] + 819200 bytes downloaded
[18:23:24] + 829440 bytes downloaded
[18:23:24] + 838702 bytes downloaded
[18:23:24] Verifying core Core_79.fah...
[18:23:24] Signature is VALID
[18:23:24]
[18:23:24] Trying to unzip core FahCore_79.exe
[18:23:24] Decompressed FahCore_79.exe (2334720 bytes) successfully
[18:23:29] + Core successfully engaged
[18:23:34]
[18:23:34] + Processing work unit
[18:23:34] Core required: FahCore_79.exe
[18:23:34] Core found.
[18:23:34] Working on queue slot 01 [August 8 18:23:34 UTC]
[18:23:34] + Working ...
[18:23:34]
[18:23:34] *------------------------------*
[18:23:34] Folding@Home Double Gromacs Core
[18:23:34] Version 1.91 (April 11, 2006)
[18:23:34]
[18:23:34] Preparing to commence simulation
[18:23:34] - Looking at optimizations...
[18:23:34] - Created dyn
[18:23:34] - Files status OK
[18:23:51] - Expanded 9506176 -> 34521892 (decompressed 363.1 percent)
[18:23:51] - Starting from initial work packet
[18:23:51]
[18:23:51] Project: 3903 (Run 3505, Clone 3, Gen 7)
[18:23:51]
[18:23:53] Assembly optimizations on if available.
[18:23:53] Entering M.D.
[18:24:14] Protein: IBX in water
[18:24:14]
[18:24:14] Writing local files
Why do you use a SMP client in uniprocessor mode ? Did you forget the -smp flag ?
DAR
Post by DAR »
toTOW wrote:Why do you use a SMP client in uniprocessor mode ? Did you forget the -smp flag ?
I use multiple machines. 1 quadcore, and 1 single core at work. Sometimes I use my quadcore to finish an almost completed project. Which can be done simultaneously with a running SMP project. And if I am late, I also receive a new project. Which I will finish at work.
I use the SMP client also at work, but not to run SMP's. But it turned out to be more stable.
Did you get the last r3 version of the 6.22 client : viewtopic.php?f=46&t=4913 :?: Uniprocessor mode might be affected by the ACK issue too ...
kasson
Pande Group Member
Post by kasson »
We're looking into it--it may be a problem stemming from the use of multiple machines.
The Stanford servers keep track of which client (and client ID) downloads a work unit, and expects it to come back from the same system, as a security measure. When you start moving work units around, you can cause problems.
For more info on the topic, see the Sneakernetting article in the FAH WIKI. If you follow those directions, you can avoid this problem.
DAR
Post by DAR »
I now also downloaded the R3 version. But the problems with my pc at work was solved when I started using the 620 client. With the 504 client my pc sometimes froze. But the 620 is not usable anymore, so I switched to the 622 client.
This P3903 project. I finished it at the same pc as where I downloaded it. So it should be no problem of sneaker-networking.
And I must say that I did not have problems with sneaker-networking before. And even just now I completed a project which came from another pc. And I received the credits.
But I will send the results of this P3903 also from another pc. Maybe it works. As I said, I still have the completed project.
