Project: 2451 (Run 40, Clone 5, Gen 16) -- 0x79 error
jrweiss
Post by jrweiss »
Running 6.20r1 as a service, XP Pro SP3, IBM T42 laptop, P-M 1.8, 1.5 GB RAM.
Got 2 failures without even making 1%. First UNKNOWN_ERROR; second ERROR 0x79.
Ran qfix after 2nd error; deleted work and downloaded another WU.
--- Opening Log file [August 19 22:58:11 UTC]
# Windows CPU Console Edition
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: D:\Apps\F@H
Service: D:\Apps\F@H\FAH620.exe
Arguments: -svcstart -d D:\Apps\F@H -local -verbosity 9 -forceasm
Launched as a service.
Entered D:\Apps\F@H to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[22:58:11] - Ask before connecting: No
[22:58:11] - User name: jrweiss (Team 3074)
[22:58:11] - User ID: 2B7F108148B3B68B
[22:58:11] - Machine ID: 1
[22:58:11]
[22:58:11] Loaded queue successfully.
[22:58:11]
[22:58:11] + Processing work unit
[22:58:11] Core required: FahCore_78.exe
[22:58:11] Core found.
[22:58:11] - Autosending finished units... [August 19 22:58:11 UTC]
[22:58:11] Trying to send all finished work units
[22:58:11] + No unsent completed units remaining.
[22:58:11] - Autosend completed
[22:58:11] Working on queue slot 04 [August 19 22:58:11 UTC]
[22:58:11] + Working ...
[22:58:11] - Calling '.\FahCore_78.exe -dir work/ -suffix 04 -checkpoint 30 -service -forceasm -verbose -lifeline 2272 -version 620'
[22:58:14]
[22:58:14] *------------------------------*
[22:58:14] Folding@Home Gromacs Core
[22:58:14] Version 1.90 (March 8, 2006)
[22:58:14]
[22:58:14] Preparing to commence simulation
[22:58:14] - Ensuring status. Please wait.
[22:58:31] - Assembly optimizations manually forced on.
[22:58:31] - Not checking prior termination.
[22:58:33] - Expanded 395939 -> 6680577 (decompressed 1687.2 percent)
[22:58:33]
[22:58:33] Project: 2451 (Run 40, Clone 5, Gen 16)
[22:58:33]
[22:58:37] Assembly optimizations on if available.
[22:58:37] Entering M.D.
[22:58:45] Protein: p2451_Fragment-Receptor HDQ
[22:58:45]
[22:58:45] Writing local files
[23:07:05]
[23:07:05] Folding@home Core Shutdown: INTERRUPTED
[23:07:07] CoreStatus = 66 (102)
[23:07:07] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[23:07:08] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [August 19 23:08:25 UTC]
Warning:
 use of the flag.
[23:08:25] - Ask before connecting: No
[23:08:25] - User name: jrweiss (Team 3074)
[23:08:25] - User ID: 2B7F108148B3B68B
[23:08:25] - Machine ID: 1
[23:08:25]
[23:08:25] Loaded queue successfully.
[23:08:25]
[23:08:25] + Processing work unit
[23:08:25] Core required: FahCore_78.exe
[23:08:25] Core found.
[23:08:25] - Autosending finished units... [August 19 23:08:25 UTC]
[23:08:25] Trying to send all finished work units
[23:08:25] + No unsent completed units remaining.
[23:08:25] - Autosend completed
[23:08:25] Working on queue slot 04 [August 19 23:08:25 UTC]
[23:08:25] + Working ...
[23:08:25] - Calling '.\FahCore_78.exe -dir work/ -suffix 04 -checkpoint 30 -service -forceasm -verbose -lifeline 828 -version 620'
[23:08:27]
[23:08:27] *------------------------------*
[23:08:27] Folding@Home Gromacs Core
[23:08:27] Version 1.90 (March 8, 2006)
[23:08:27]
[23:08:27] Preparing to commence simulation
[23:08:27] - Assembly optimizations manually forced on.
[23:08:27] - Not checking prior termination.
[23:08:28] - Expanded 395939 -> 6680577 (decompressed 1687.2 percent)
[23:08:29]
[23:08:29] Project: 2451 (Run 40, Clone 5, Gen 16)
[23:08:29]
[23:08:29] Assembly optimizations on if available.
[23:08:29] Entering M.D.
[23:08:37] Protein: p2451_Fragment-Receptor HDQ
[23:08:37]
[23:08:37] Writing local files
[00:22:32] Gromacs error.
[00:22:32]
[00:22:32] Folding@home Core Shutdown: UNKNOWN_ERROR
[00:22:36] CoreStatus = 79 (121)
[00:22:36] Client-core communications error: ERROR 0x79
[00:22:36] This is a sign of more serious problems, shutting down.
[01:10:48] Service stop request received.
[01:10:48] ***** Got a SIGTERM signal (2)
[01:10:48] Killing all core threads
Re: Project: 2451 (Run 40, Clone 5, Gen 16) -- 0x79 error
There's no results returned for that WU :(
jrweiss
Post by jrweiss »
Persistent little beggar! Ran another WU, then got it again, and then another 0x79 error.
Ran qfix again, tried -send all again, deleted work again...
[01:15:17]
[01:15:17] *------------------------------*
[01:15:17] Folding@Home PMD Core
[01:15:17] Version 1.03 (September 7, 2005)
[01:15:17]
[01:15:17] Preparing to commence simulation
[01:15:17] - Assembly optimizations manually forced on.
[01:15:17] - Not checking prior termination.
[01:15:17] - Expanded 17317 -> 109522 (decompressed 632.4 percent)
[01:15:17]
[01:15:17] Project: 4596 (Run 26, Clone 185, Gen 43)
[01:15:17]
[01:15:17] Assembly optimizations on if available.
[01:15:17] Entering M.D.
[01:15:23] Protein: p4596_T0498-12_minout
[01:15:23]
[01:15:23] Completed 0 out of 2500000 steps  (0%)
[01:25:29] Writing local files
[01:25:29] Completed 25000 out of 2500000 steps  (1%)
[18:21:03] Completed 2500000 out of 2500000 steps  (100%)
[18:21:03] Writing checkpoint files
[18:22:03]
[18:22:03] Finished Work Unit:
[18:22:03] Leaving Run
[18:22:07] - Writing 316924 bytes of core data to disk...
[18:22:07]   ... Done.
[18:22:07] - Shutting down core
[18:22:07]
[18:22:07] Folding@home Core Shutdown: FINISHED_UNIT
[18:22:10] CoreStatus = 64 (100)
[18:22:10] Unit 1 finished with 97 percent of time to deadline remaining.
[18:22:10] Updated performance fraction: 0.969129
[18:22:10] Sending work to server
[18:22:10] Project: 4596 (Run 26, Clone 185, Gen 43)
[18:22:10] - Read packet limit of 540015616... Set to 524286976.
[18:22:10] + Attempting to send results [August 20 18:22:10 UTC]
[18:22:10] - Reading file work/wuresults_01.dat from core
[18:22:10]   (Read 316924 bytes from disk)
[18:22:10] Connecting to http://169.230.26.30:8080/
[18:22:13] Posted data.
[18:22:13] Initial: 0000; - Uploaded at ~103 kB/s
[18:22:13] - Averaged speed for that direction ~103 kB/s
[18:22:13] + Results successfully sent
[18:22:13] Thank you for your contribution to Folding@Home.
[18:22:13] + Number of Units Completed: 20
[18:22:17] Trying to send all finished work units
[18:22:17] + No unsent completed units remaining.
[18:22:17] - Preparing to get new work unit...
[18:22:17] + Attempting to get work packet
[18:22:17] - Will indicate memory of 1024 MB
[18:22:17] - Connecting to assignment server
[18:22:17] Connecting to http://assign.stanford.edu:8080/
[18:22:18] Posted data.
[18:22:18] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[18:22:18] + News From Folding@Home: Welcome to Folding@Home
[18:22:18] Loaded queue successfully.
[18:22:18] Connecting to http://171.65.103.162:8080/
[18:22:21] Posted data.
[18:22:21] Initial: 0000; - Receiving payload (expected size: 396451)
[18:22:22] - Downloaded at ~387 kB/s
[18:22:22] - Averaged speed for that direction ~210 kB/s
[18:22:22] + Received work.
[18:22:22] Trying to send all finished work units
[18:22:22] + No unsent completed units remaining.
[18:22:22] + Closed connections
[18:22:22]
[18:22:22] + Processing work unit
[18:22:22] Core required: FahCore_78.exe
[18:22:22] Core found.
[18:22:22] Working on queue slot 02 [August 20 18:22:22 UTC]
[18:22:22] + Working ...
[18:22:22] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 30 -service -forceasm -verbose -lifeline 4420 -version 620'
[18:22:23]
[18:22:23] *------------------------------*
[18:22:23] Folding@Home Gromacs Core
[18:22:23] Version 1.90 (March 8, 2006)
[18:22:23]
[18:22:23] Preparing to commence simulation
[18:22:23] - Assembly optimizations manually forced on.
[18:22:23] - Not checking prior termination.
[18:22:24] - Expanded 395939 -> 6680577 (decompressed 1687.2 percent)
[18:22:24] - Starting from initial work packet
[18:22:24]
[18:22:24] Project: 2451 (Run 40, Clone 5, Gen 16)
[18:22:24]
[18:22:24] Assembly optimizations on if available.
[18:22:24] Entering M.D.
[18:22:33] Protein: p2451_Fragment-Receptor HDQ
[18:22:33]
[18:22:33] Writing local files
[19:15:15] - Autosending finished units... [August 20 19:15:15 UTC]
[19:15:15] Trying to send all finished work units
[19:15:15] + No unsent completed units remaining.
[19:15:15] - Autosend completed
[19:29:50] Gromacs error.
[19:29:50]
[19:29:50] Folding@home Core Shutdown: UNKNOWN_ERROR
[19:29:52] CoreStatus = 79 (121)
[19:29:52] Client-core communications error: ERROR 0x79
[19:29:52] This is a sign of more serious problems, shutting down.
[20:22:21] Service stop request received.
[20:22:21] ***** Got a SIGTERM signal (2)
[20:22:21] Killing all core threads
--- Opening Log file [August 20 20:22:22 UTC]
Warning:
 use of the flag.
[20:22:22] - Ask before connecting: No
[20:22:22] - User name: jrweiss (Team 3074)
[20:22:22] - User ID: 2B7F108148B3B68B
[20:22:22] - Machine ID: 1
[20:22:22]
[20:22:22] Loaded queue successfully.
[20:22:22]
[20:22:22] + Processing work unit
[20:22:22] Core required: FahCore_78.exe
[20:22:22] Core found.
[20:22:22] - Autosending finished units... [August 20 20:22:22 UTC]
[20:22:22] Trying to send all finished work units
[20:22:22] + No unsent completed units remaining.
[20:22:22] - Autosend completed
[20:22:22] Working on queue slot 02 [August 20 20:22:22 UTC]
[20:22:22] + Working ...
[20:22:22] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 30 -service -forceasm -verbose -lifeline 5952 -version 620'
[20:22:23]
[20:22:23] *------------------------------*
[20:22:23] Folding@Home Gromacs Core
[20:22:23] Version 1.90 (March 8, 2006)
[20:22:23]
[20:22:23] Preparing to commence simulation
[20:22:23] - Ensuring status. Please wait.
[20:22:40] - Assembly optimizations manually forced on.
[20:22:40] - Not checking prior termination.
[20:22:41] - Expanded 395939 -> 6680577 (decompressed 1687.2 percent)
[20:22:41]
[20:22:41] Project: 2451 (Run 40, Clone 5, Gen 16)
[20:22:41]
[20:22:41] Assembly optimizations on if available.
[20:22:41] Entering M.D.
[20:22:49] Protein: p2451_Fragment-Receptor HDQ
[20:22:49]
[20:22:49] Writing local files
[21:13:29] Service stop request received.
[21:13:29] ***** Got a SIGTERM signal (2)
[21:13:29] Killing all core threads
--- Opening Log file [August 20 21:13:31 UTC]
Warning:
 use of the flag.
[21:13:31] - Ask before connecting: No
[21:13:31] - User name: jrweiss (Team 3074)
[21:13:31] - User ID: 2B7F108148B3B68B
[21:13:31] - Machine ID: 1
[21:13:31]
[21:13:31] Loaded queue successfully.
[21:13:31]
[21:13:31] + Processing work unit
[21:13:31] Core required: FahCore_78.exe
[21:13:31] Core found.
[21:13:31] - Autosending finished units... [August 20 21:13:31 UTC]
[21:13:31] Trying to send all finished work units
[21:13:31] + No unsent completed units remaining.
[21:13:31] - Autosend completed
[21:13:31] Working on queue slot 02 [August 20 21:13:31 UTC]
[21:13:31] + Working ...
[21:13:31] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 30 -service -forceasm -verbose -lifeline 5032 -version 620'
[21:13:31]
[21:13:31] *------------------------------*
[21:13:31] Folding@Home Gromacs Core
[21:13:31] Version 1.90 (March 8, 2006)
[21:13:31]
[21:13:31] Preparing to commence simulation
[21:13:31] - Assembly optimizations manually forced on.
[21:13:31] - Not checking prior termination.
[21:13:33] - Expanded 395939 -> 6680577 (decompressed 1687.2 percent)
[21:13:33]
[21:13:33] Project: 2451 (Run 40, Clone 5, Gen 16)
[21:13:33]
[21:13:33] Assembly optimizations on if available.
[21:13:33] Entering M.D.
[21:13:40] Protein: p2451_Fragment-Receptor HDQ
[21:13:40]
[21:13:40] Writing local files
[21:19:43] Service stop request received.
[21:19:43] ***** Got a SIGTERM signal (2)
[21:19:43] Killing all core threads
--- Opening Log file [August 20 21:21:34 UTC]
Executable: fah620
Arguments: -send all -local -verbosity 9 -forceasm
Warning:
 use of the flag.
[21:21:34] - Ask before connecting: No
[21:21:34] - User name: jrweiss (Team 3074)
[21:21:34] - User ID: 2B7F108148B3B68B
[21:21:34] - Machine ID: 1
[21:21:34]
[21:21:34] Loaded queue successfully.
[21:21:34] Attempting to return result(s) to server...
[21:21:34] Trying to send all finished work units
[21:21:34] + No unsent completed units remaining.
[21:21:34] ***** Got a SIGTERM signal (2)
[21:21:34] Killing all core threads
