3855 (Run 82, Clone 0, Gen 13) - WU Didn't Send
hello
im new, so i dont know what im doing haha
so i recently finished a WU, 3855 (Run 82, Clone 0, Gen 13). i finished last night, and I have already started a new WU, but it didnt update my points. i checked my log file and it was sucessfully sent.
heres my log file.
[03:17:47] Completed 200000 out of 200000 steps (100%)
[03:19:09]
[03:19:09] Finished Work Unit:
[03:19:09] - Reading up to 2176440 from "work/wudata_01.trr": Read 2176440
[03:19:11] - Reading up to 119432 from "work/wudata_01.xtc": Read 119432
[03:19:14] xvg file size: 155341
[03:19:16] logfile size: 66845
[03:19:18] Leaving Run
[03:19:18] - Writing 2604398 bytes of core data to disk...
[03:19:18] ... Done.
[03:19:18] - Shutting down core
[03:19:18]
[03:19:18] Folding@home Core Shutdown: FINISHED_UNIT
[03:19:22] CoreStatus = 64 (100)
[03:19:22] Sending work to server
[03:19:22] Project: 3855 (Run 82, Clone 0, Gen 13)
[03:19:22] + Attempting to send results [August 18 03:19:22 UTC]
[03:21:24] + Results successfully sent
[03:21:24] Thank you for your contribution to Folding@Home.
Thanks
heres my log file.
[03:19:09]
[03:19:18]
Thanks
Re: 3855 (Run 82, Clone 0, Gen 13) - WU Didn't Send
The stats db hasn't recovered from the power outage yet ... I can't help you
Can't connect to the stats database
is the db back up? it hasn't updated yet
You submitted this WU twice, with two different username/teamnumber but the same UserID :
Hi Anonymous (team 0),
Your WU (P3855 R82 C0 G13) was added to the stats database on 2008-08-09 18:38:49 for 450 points of credit.
Hi Chris_Jo (team 139798),
Your WU (P3855 R82 C0 G13) was added to the stats database on 2008-08-17 20:39:57 for 0 points of credit.
So what should I do?
I'm not quite sure why it sent it as anonymous (team 0)
the Chris_Jo (team 139798) is the correct one, that was my name and team prior to starting this WU
Look at the dates. I'm sure if you look back to a week earlier you'll find you were doing something with the same WU.
My WU sent right before the outage. and maybe it somehow got corrupted during the process? or my settings were reset or something? i dont know, just some thinking...
anyways, is there anything that can be done now?
like transfer the points?
thanks
thanks
Baowoulf
- Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
I had a WU in a similar situtation and it wasn't credited for at least a week or so afterward. I actually thought it was lost and moved on and suddenly I was credited for it.
Also you can use the boxes to make it easier to read logs. They don't transfer points once they are credited. For the anon contribution I'd check your name and team stats to see if they got reseted on any of your machines/PS3's.
I submitted a WU yesterday, and i didn't get accredited for it
so now my 2 most recent WUs didnt get credit (i did both of these on 6.20, every other WU i did on 5.03 and they worked, although im pretty sure they arnt involved.)
everything before that was ok
I can't do anything with this information. You need to provide the Project/Run/Clone/Gen numbers from the missing WUs and if possible, a copy of FAHlog showing when the WU was uploaded and to which server.Chris_Jo wrote:I submitted a WU yesterday, and i didn't get accredited for it
The title is still about Project: 3855 (Run 82, Clone 0, Gen 13) and we already know it was submitted first by Anonymous and then a duplicate was resubmitted from the same machine by Chris_Jo.
I can tell that you have edited client.cfg and corrupted it so your machine is now submitting results as Anonymous again. Client.cfg is a machine-readable file and you MUST NOT edit it. Instead, you must restart the client with the -config flag and enter your information again. If that sounds difficult, stop the client, delete client.cfg, and restart the client.
You must also be sure that you do not run two copies of the client in the same directory.
Please post the first page of FAHlog.txt or, if it's long, the last time you see the same sort of data repeated when you restarted the client.
